nwnw Posted November 7 Posted November 7 (edited) I'm doing all the building control drawings myself, mostly in Sketchup. These will be backed up by 'mark-up' details and structural report by the structural engineer. I have a couple of examples of building control drawings to reference, but I could really do with more. Is anyone willing to share their drawings with me? Especially those covering a timber frame extension! Once nearly done (about 75% there just now) and once complete I'll stick my drawings up here for you all to rip apart! 🙂 --------------- Edit: I meant to say, if you'd rather not put up in public then feel free to DM me. Thx Edited November 7 by nwnw
Gus Potter Posted November 8 Posted November 8 10 hours ago, nwnw said: Is anyone willing to share their drawings with me? No, because I feel if you want to save money then you need to put in the leg work first, there is no free lunch. Your starting point is to learn how you put together a timber frame, how the lateral stability system works and so on. If you make a good go at your TFand post your drawings then I may chip in as an SE / designer to give you some tips etc.. but I'm not going to share my intellectual property with you until I'm sure you have done the leg work. 2
nwnw Posted Sunday at 15:07 Author Posted Sunday at 15:07 Ok, fair enough. Not complete and meeting with structural engineer tomorrow, but here we go...attached are some of the drawings as they stand. I'm based in North East Scotland so Scottish Building Standards apply. I'll post some images too for reference. Existing sunroom... New structure... If anyone wants to see any specific areas then just ask. Oh, and please not that the steel has been reduced in size slightly so the flat roof timber looks like it's floating 50mm above it. I'm not updating the structure yet as engineer might change things anyway. All comments welcome!! <<Moderator Edit: The previously attached drawings have been removed and they will be reposted further down the thread.>>
nwnw Posted Sunday at 15:18 Author Posted Sunday at 15:18 New open plan space, utility to right and cloakroom/entrance top left.
nwnw Posted Monday at 08:49 Author Posted Monday at 08:49 On 08/11/2025 at 00:27, Gus Potter said: No, because I feel if you want to save money then you need to put in the leg work first, there is no free lunch. Your starting point is to learn how you put together a timber frame, how the lateral stability system works and so on. If you make a good go at your TFand post your drawings then I may chip in as an SE / designer to give you some tips etc.. but I'm not going to share my intellectual property with you until I'm sure you have done the leg work. @Gus Potter Hopefully you can see that I have 'done the legwork'. 🙂 For me it's as much about having ownership as saving money. I'm an engineer to trade so I have a good handle on loads & forces and can do all the calculations (although I'm engaging a structural eng to make the approvals process smoother). But with regards the drawings, I want to make sure I get all the info on there that the BCO will be expecting. 1
Mr Punter Posted Monday at 10:06 Posted Monday at 10:06 A few small points: Maybe look at a fire resistant membrane on the walls. The box gutter may fail at some stage and possibly rot out the walls. The Kingspan phenolic insulation is good (better insulation and fire rating) but expensive.
nwnw Posted Tuesday at 11:04 Author Posted Tuesday at 11:04 On 10/11/2025 at 10:06, Mr Punter said: A few small points: Maybe look at a fire resistant membrane on the walls. The box gutter may fail at some stage and possibly rot out the walls. The Kingspan phenolic insulation is good (better insulation and fire rating) but expensive. Thanks for the feedback. Any suggestions for membrane and I can have a look? I'd like, if possible, not to have ugly guttering round the front of the cladding. Any other ways round this? My assumption was that EPDM would be pretty bomb-proof if done by a professional outfit, given the amount of flat-roofs done like this.
markc Posted Tuesday at 11:17 Posted Tuesday at 11:17 (edited) Gutter on outside of the envelope and then cladding in front with access to downpipes if needed (removable cladding section etc). haven’t read rest of post/s so might be barking up the wrong tree Edited Tuesday at 11:19 by markc
nwnw Posted Thursday at 16:58 Author Posted Thursday at 16:58 On 11/11/2025 at 11:17, markc said: Gutter on outside of the envelope and then cladding in front with access to downpipes if needed (removable cladding section etc). haven’t read rest of post/s so might be barking up the wrong tree I sort of get the gist, but do you have any examples or x-sections of how this could be achieved?
Russdl Posted Thursday at 17:54 Posted Thursday at 17:54 On 11/11/2025 at 11:04, nwnw said: My assumption was that EPDM would be pretty bomb-proof if done by a professional outfit, I would say it’s pretty bomb-proof if you do it yourself, it’s very easy and you’re more likely to take greater care than most pro’s. 1
Roger440 Posted Thursday at 21:02 Posted Thursday at 21:02 Sketch-up! You must have the patience of a saint.
Russdl Posted Thursday at 23:42 Posted Thursday at 23:42 2 hours ago, Roger440 said: Sketch-up! You must have the patience of a saint. When you get it. You get it. It’s brilliant. 2
nwnw Posted 23 hours ago Author Posted 23 hours ago One kind person pointed out that I had some personal details on the drawings posted so I have redacted and re-attached... Layout - Proposed - Rev2.pdfElevations - Proposed - Rev1.pdfBuilding Control Report - redacted.pdfDetail02 - Roof - Rev2.pdfDetail01-Wall - Rev3.pdf I've also made a few changes. Structural engineer recommended going with a beam under the existing roof joists to keep the build simpler and cheaper. After chatting through and thinking of the implications of the old timbers being varying lengths and sizes I've grudgingly agreed and changed the design. Means I have a boxed in steel in the middle of the room but after modelling it doesn't look as bad as I expected. He also suggested landing the beam on the stonework and underpinning, rather than 'goalpost' steel supports and pads.
nwnw Posted 23 hours ago Author Posted 23 hours ago 13 hours ago, Russdl said: When you get it. You get it. It’s brilliant. Indeed. I was frustrated with Sketchup for years then I took some time to learn to use it properly. Once I started to group features, make components and use tags (layers) all my problems disappeared (problems: usually dragging features by mistake and noticing 2 days later after everything was totally messed up).
Spinny Posted 20 hours ago Posted 20 hours ago Some random thoughts... Where will the TV go ? Where will kitchen and utility extractors go ? Outside tap and powerpoint ? Consider creating a lighting plan now so you can avoid lights clashing with ceiling joists or steel etc Consider the potential for rain noise from the flat roof - was an unexpected issue for us using single ply PVC membrane - perhaps EPDM is better for noise - acoustic insulation ? Pity about the beam. That new larch looks nice but will presumably actually be grey within a year or two ? Don't fancy a rooflight then ? Shame to have steps down onto the patio area - consider raising decking/patio ? Does the big window have a view and would you want some seating that looks through it ? Seating seems to focus towards the utility door ? Outside door to the utility ?
JohnMo Posted 19 hours ago Posted 19 hours ago Basic comments - drawing for planning and warrant will be different, so you will not have combined drawings. So do you have planning permission already - if so drop the planning permission from the drawing title or vice versa. All drawings are light on detail. Should include details of proposed build-up etc or make reference to additional drawings. 3 hours ago, nwnw said: Means I have a boxed in steel in the middle of the room but after modelling it doesn't look as bad as I expected. If this steel interacts with the outside world it will insulating. Not sure if it also need fire proofing - ask your structural engineer. 3 hours ago, nwnw said: One kind person pointed out that I had some personal details on the drawings posted so I have redacted and re-attached... Still has address on one or more drawings Larch Cladding, in 'rain screen' formation with 8mm gaps. - be prepared for a wasp invasion, they will love it. Your ventilation fans really should be upgraded to dMEV, so you have silent ventilation that works. Intermittent fans are awful - the work of the devil.
ETC Posted 18 hours ago Posted 18 hours ago Very quick look: Not keen on the clash of the old and new - would have been nicer (IMO) to keep the existing eaves. Not keen on the angle in the plan - is there a reason? CO to living room for stove. Probably need eaves ventilation at roof junctions.
Roger440 Posted 16 hours ago Posted 16 hours ago 20 hours ago, Russdl said: When you get it. You get it. It’s brilliant. I treid. I tried hard. I didnt get it. So user unfriendly.
Russdl Posted 4 hours ago Posted 4 hours ago That’s a bit like me with CAD software. I’m a God with Sketchup I’m a Dog with CAD. But I’m determined to get there.
