ETC Posted October 1 Posted October 1 On 30/09/2025 at 21:15, Spinny said: Not clear to me what this third party company is you refer to. Building Control can be done by the Local Authority, OR you can pay a private BC company to do this (or I think possibly a licenced individual ?). You choose. I think generally the view is the LA is thorough, but can perhaps sometimes be jobsworth over some aspects, and might take days to turn up on site to inspect things, inconveniencing or delaying build. Private BC typically turn up quickly within 24 hours or so, and can be more pragmatic and less pedantic - many seem to be ex builders. However, it can feel cursory, and they may not look under the rug at all the details. I have the impression builders prefer private BC - Builders are the poachers, BC is the game keeper - so that maybe says something. Architects process is - PP Drawings, then detailed Design & Construction Drawings, then Statement of Work, tender and contract award, then contract administration and oversight/support. You can choose to stop with them at any stage. We went through the full process except contract admin and oversight/support. Architect recommended a structural engineer. Structural engineer specified all the structural things - lintels, joists, beams, foundations, concrete slab spec and calcs in a report to accompany the detailed architect plans as input to BC for plans approval. All quite costly for us. But you get a lot defined clearly. Some builders barely read the SoW, but it becomes part of the contract with the drawings, and SE report. We paid the architect by the hour for support during build, unless it was drawing errors. An awful lot depends on (a) your budget, and (b) your knowledge, time, desire, and abilities both technically and managerially and (c) how much you care about how close the build is to your spec. and (d) how much you are doing yourself, (e) your ability to deal with problems. Tight change management and change management records is ESSENTIAL. Regular meetings and communications is ESSENTIAL. Remember the builder's/contractor's objectives are DIFFERENT, from your objectives. Builder/contractor wants no change, and can charge you what he likes for change. He is trying to make money, get the job done, and get the cash in. He will buy whatever is on the shelf at his favoured local merchant. He likes cheap, light stuff, hates special heavy stuff. Someone has to be gamekeeper. When it goes wrong - as it did for us - it is horrendous and expensive. Once a builder starts smashing up your house, or gets well into the build he has you by the ghoolies. Other builders don't like taking on part built jobs. Other builders will take probably a year to find and start any work. It can take 6-12months to terminate a contract. Your builder knows this. You need a detailed quote - don't accept estimates for electrics and plumbing - builders estimates can be half the actual quote. Keep a written paper daily diary. Who will project manage ? Who will be on site ? Project management is demanding. I have had to do a lot of it because builders may not do any more than the basics. You want some item not in stock at the favoured merchant - you may have to source it and order it. The builder/contractor may potentially, ignore the spec, challenge the spec, change the spec, buy the wrong materials, use out of date materials, not turn up. Best to know and choose what builders or contractors you are going to use before you start. If it doesn't go well, you WILL need support. The builder/contractor may essentially ignore you questioning work - you need someone with all the letters after their name to tell them the same thing you said before they will do it. Be able to call in the SE or the Architect or even a QS - someone authoratative and suitably politely assertive. BC only do BC, they don't care what you specified, only whether it meets minimum regs. Sorry if this sounds bad - our single experience bad. Many good people out there no doubt, and on this forum. In general they are busy and challenging to find. Not trying to tar all with the same brush at all. Alternatively use a CONTRACT…..and have extremely detailed drawings including a start date a completion date, liquidated damages……this will concentrate any contractors mind and sharpen his pencil. Get rid of the fag packet “quotes” and employ a QS to do a detailed BoQ priced before you tender the works so you know exactly what it should cost. The only variables will be foundations and possibly materials costs depending on contract chosen. JCT is ok but NEC seems to be the contract of choice these days for “equality” between contractor and client. 1
ETC Posted October 1 Posted October 1 23 hours ago, Gus Potter said: This is a good response. I'll come to this later. The following is a bit of a summary, but provide a bit of context and I've included a nugget at the end for those that take the time to read this post all the way though. For folk that are not VAT exempt also see end. I'm an SE that also does Architectural design, oh and I was a Contractor for the first 20 years of my carear. In the round I probably know more than most about what an Architect does, how they behave when under pressure for example. If you pay an experienced Architect a fair rate for a fair days pay then you will benefit. I'm not bad at Architectural Design and I work with Architects that not that bad at SE design! The process is collaborative and after you have done it for a while it's inevitable that a good Architect will have a good feel for the SE stuff. It's not a competition between SE's and Architects and we all love seeing stuff we have had a hand in designing getting built. On the face of it it takes a university degree and a further 3 -4 years to become an Architect.. and then you have a lot more learning to do, experience to gather. During that time you learn the craft of how planning, BC compliance works, get to know builders, when they try and pull the wool over your eyes, we learn a LOT of stuff; could be about heating systems, glazing, tiling @nod.. the nuts an bolts of how you build stuff and make it look good! Ok lets delve a bit deeper. When I was a builder the BC officers used to come out and inspect my work. But now we speak as I'm now the agent gettting planning and BC permissions for my Clients. There is nothing underhand here.. it just I know who to phone, where to to apply pressure and write in a way that sort planning and BC issues. An experienced Architect can do the same. That has value.. you pay for one professional to sort things out with one another. I agree. But in fairness on BH there are also many who will pay you a reasonable rate for a fair days pay. There are indeed some vocal folk on BH who view designers as just a tooL, to abuse to get BC / planning permission. But many will end up paying too much for their build as they were not willing to say.. hey this designer might be able to save me more than their design fee or maybe have somne contact that they can introduce me to. In England you have this building notice system.. it looks like a good deal but is it really? If you cut corners at the deisgn stage then it could come back to bite you big time! BH is by it's nature probably populated by folk that have an element of common sense and experience of the construction industry so what you see on BH is not truly reflective of real life. So @ETC, you can lead a horse to water! Keep your head up! Ok you mention fees! The fundamental problem as I see it is that Architects / desingers/ SE's (probaly the worst communicators) have not got with the programme and explain to Clients what they do, the spin off tacit benefits, contacts, after sale support (phone friend if you build starts to play up and in general that we want to help get stuff built. Over the last few years I've included when I think it will help the Clinet in my design brief the time it take me to complete each element. From the dimensional survey to getting BC approval. For all on BH here is how you can do a designer quote for an extension. Dear xx Thank you for inviting me to xx last week to discuss making alterations to the house. I've partitioned the design brief below based us taking down part or all the wall between the existing kitchen and dining room, installing French type doors in the east gable wall (off the dining room), possibly infilling the existing back door, changing the general arrangement of the kitchen and lastly considering a porch type extension at the front which would include a wc and whb. As discussed the council permissions can be split into two areas, planning and building warrant. For the French doors and altering any of the openings on the rear elevation I recommend that you first apply for a certificate of lawfulness as the gable can be viewed from the road. The same would apply for a front porch type extension. Taking down the wall internally only requires a building warrant. For transparency I've shown my allocated times. Should you accept my brief then the initial consultation fee of £100.00 will be waived. Initial design and planning approvals: Stage 1: Site visit to carry out a dimensional survey, initial structural inspection. I anticipate that this will take me initially 1.5 days. Draw the floor plan of the two floors (this allows me to calculate the structural loads) and two elevation drawings with some ideas based on your initial requirements (3 days). Return to site to pick up other detailed dimensions (that come to light) as necessary when preparing the first set of drawings and meet with you for a concept design discussion. (0.5 day). Stage 2: Revise the drawings to account for stage 1 design meetings and meet with you again. (1.0 day). In terms of the kitchen unit detailed design I would leave the detail to you but would show the basic outline on the drawings necessary to support any council applications. Stage 3: Complete the drawing work up to a stage where we could seek a planning certificate of lawfulness for all or part of the work. Act as your agent and make a certificate of lawfulness application on your behalf. (0.5 days). Currently the council fee for a certificate of lawfulness is £178.50, i.e. 50% of the full planning fee. Any council fees are over and above my design fee. Total time for stages one to three inclusive = 6.5 days. Building warrant application: The above stages provide us with a pretty good set of layout drawings that then get worked up with more detail to support a building warrant application. In terms of structural design. Stage 4: Prepare a set of drawings, structural calculations and structural drawings to support a building warrant application. At this stage we don't know the extent of the works but taking the key elements: (a) Take down the wall between the kitchen and dining room for the calculations and drawings etc (2 days) (b) French doors and external landing, calculations and drawings 2.0 days (c) Front porch 4 days, essentially a small extension. (d) Design meetings, 1 day Act as your agent and make a building warrant application on your behalf, 0.5 days. The above time span would then be either 2.0 + 2.0 + 1 + 0.5 = 5.5 days for items a,b and d or 2.0 + 2.0 + 4.0 + 1 +0.5 = 9.5 days. Time range for stage four 5.5 to 9.5 days. The Council fees for a building warrant application vary depending on the value of the builder work excluding VAT. For example work valued at: £15,001 to £16,000 fee is £558.00 £20,001 to £30,000 fee is £728.00 £30,001 to £40,000 fee is £806.00 £40,001 to £50,000 fee is £884.00 Stage 5: Provide an element of assistance and advice on selection of a building contractor and be available to answer any queries as work progresses on site. My design fees: I would request the following design fees. VAT is not applicable to my fees. For transparency I've taken an average of the Structural design rate and the Architectural design rate as £275.00 per day. Stages 1 to 3 and 5 inclusive 6.5 days x £ 275.00 = £1787.50 Stage 4 and 5 range from 5.5 x 275 = £ 1512.50 to 9.5 x 275 = 2612.50 I would request that payment of stages 1 to 3 inclusive is made within 14 days from the time that this design work is ready for submission to the council. Stages 4 and 5 paid within 14 days from the time that the building warrant application is ready for submission to the council. Design information will be provided in electronic format, usually pdf. Now my lovelies on BH. This works for me. The above is written as I've already spent time with the Clent. But what I have done by being transparent is to make the Client aware what a fair days work entails and what I also bring to the table. Note my terms of payment. But it's not often I lose a job that I want to do. @ETC I don't want to hear you have been trousering a £100.00 five nights a week consulting but not actually doing any jobs! I often charge £100.00 as lots of folk.. like some on BH will milk you and they can f off! I wouldn’t get out of bed for £100!😁
ETC Posted October 1 Posted October 1 11 hours ago, SilverShadow said: Another few dumb Q's please guys 🙃 1. We're assuming we want to specify our build budget up front to the architect, so he can design/spec accordingly. Would this seem like a sage approach? (I've heard some folks say keep quiet & see what the end result is, but that seems daft imo) Specify your budget up front. Take VAT, statutory fees and consultants fees off and you will have your “construction” budget. Keeping this information to yourself wastes your time and your “architect’s” time. 2. Is it typical an Architect's role is complete once design & structural drawings are done and everything signed off for construction to commence?Not necessarily. Ask your architect for a schedule of services. This will normally be for their input before construction, tendering, contract administration on-site inspection, valuation, certification, completion and post completion services - please note architects DO NOT supervise works on site - they periodically inspect the works. If so then I guess we pay them 'per visit or hour' if we need theor help with builder/Bc disputes? Yes if you agree for them to do it and pay them for it. 3. Would the architect reach out to builders to quote for the work? We assumed we'd do that, but it may be something they're happy to provide. Yes. Tender action is or can be part of the service they can give you. Again ask for a schedule of services. Sounds like we need a project Mgr for this. It's a modest extension of 3 new rooms, possibly to take 3-4 months (according to 1 builder) & just a reasonably basic build but to a good standard. We don't have loads of time/experience in this area, so hence the numerous q's to arm ourselves with as much info as possible 😉 Please, please protect yourself by employing a good architect or other professional who knows what he/she is doing. Get a contract signed with your appointed professional and with any contractor you appoint to do the work. It’s not fool-proof but at least it should give you some peace of mind that you aren’t getting royally ripped off. 1
ETC Posted October 1 Posted October 1 11 hours ago, torre said: I think that's pretty reductive and unkind. What you're describing, especially on this forum, is the inexperience of people who are heavily vested in a once in a lifetime self build and often juggling a limited budget across all areas. Any self help forum also tends to focus on fixing issues rather than praising successful outcomes too. People tend to get swayed by opinions of their builders because they're often more approachable and available. Some architects need to explain better to such inexperienced clients what they do and how that's reflected in charges, and also how that may help clients save money and have their project run more smoothly down the line. RIBA's 8 stages can seem more reflective of much larger works and at concept design some architects are guilty of prioritising design over budget prepared at earlier stages. Concept design is also a stage where self builders in particular are likely to have strong ideas about what they want and have their good ideas incorporated while their less workable ideas are improved by the architect. We've had a good experience with the architect we chose, found a good balance of input, oversight and charges that reflected what both they as architect and we as clients and also as main contractors could contribute. It's easy to see though that a different architect could have brought plenty of creative and technical design and oversight to the project but fail to respect the client's own constraints and hopes for a project they've been dreaming of for years. There's a mix of real experiences on the forum of people who've paid little and had a poor experience alongside others who have paid a great deal and felt let down. What I see are posters gloating at their ability to save a few quid by employing the local plan drawer under the guise of “an architect” when in reality their architect is a local plan drawer who can knock up a plan in his back bedroom for next to nothing perpetuating the myth that a) architects don’t know what they are doing, can’t design or build to save their life and cause all sorts of problems on site by sh*t drawings and b) that if you can knock up a plan you are an “architect” I see this so often - daily in fact - where plan drawers are referred to as an architect when in fact they are no more than a glorified cad monkey. I daily see the results of extremely badly drawn and inaccurate “construction” drawings costing builders time and you the home owner money. No wonder architects get a bad name! The ARB - the organisation for all “real” architects (the word is legally protected by the way) have a very good website and offer free impartial advice. Architects are required to set out what they are going to do and the cost for doing so BEFORE they do anything for you which should be set out in a schedule of services. The document is easy to read, sets out the obligations of both parties and should be clear and concise. If it’s not say so - and make sure everything is explained to you in words you can understand. I agree that architects in the past may have been too up their own you know what and have put what they think as good design above their clients needs and budget but I think those days are passing quickly - the market is too competitive to allow grand-standing and that pedestal is getting too high. The RIBA’s plan of work is supposed to be all encompassing when it comes to project management and on the whole should work quite capably with small projects as well as large projects. Here endeth the lesson……..for the moment.
Gus Potter Posted October 2 Posted October 2 22 hours ago, ETC said: wouldn’t get out of bed for £100!😁 Interesting comment. In a previous post I copied in a design brief as a rough guide. Many on BH know I come from a contracting background and have run a larger contracting business before I reinvented myself as an SE / Designer. I now work for myself as a designer and compete with Architects for work. To enable that I have to generate business and make no mistake this domestic building game is very much a people and a competetive business and I'm up against Architects most of the time. But they don't have the SE knowledge and the younger ones lack the hard nosed business and practical skills. One Key one here is to recognise in this day in age is design flair is not enough, we need to let our Clients see we can deliver boots on the ground and control cost. There are members of BH that are chippies, brickies, trades people. The expectation of customers is that trades folk will come to site, look at their drawings, spend time quoting which can take lots of unpaid hours, the customer milks the good ones for their knowledge and then selects the cheapest quote. I charge a fee for an intial consultation mainly because I feel that it encourages folk to take the process seriously. If you look on the internet you see that Architect's might want £750.00 to have a chat (initail consultation) with you. I just use a different business model that suits me. Now funnily, some Clients ask how much do you think this will cost. I can often give them a ball park figures but then say.. I can offer you two options if you want more certainty. First, I work with a QS so you'll get a high level cost breakdown ( good if you need lending) for a fee or I can ask one of the builders that I work with regularly to spend say half a day putting a price on it... but you'll need to pay them for their time. This also means that when I go to tender the builders and Clients have confidence in me that I will be fair when asked to arbitrate any contract. The builder is happy as I have recognised their skills. Some of the builders I work with are qualified engineers, expert trades people andhave extensive experience , in certain areas, lots more than I have. But I can tell you this.. see when I want a design brief, I usually get it. There is a common law of business that applies to small builders / trades folk contracting. If you are pricing jobs from unsolicited enquiries and you get 50% then you are too cheep, if you are pricing and not getting 1 in 4-5 then you are loosing money and expending too much resource. @saveasteading, @nod , @ProDave et all may be able to add a bit here. @ETC my work is also my hobby and I schedule my consultations in the evenings, you get out the office, meet folk, it's not a bad life. So add up a few £100.00 and.. if you are a budding Architect that want's to set up on their own then maybe my set up might suit you? In the round though. A good Architect will posess all the design and business skills I have, yes they won't be an SE but they should be able to make a go of it if they set up on their own and are able to get along with folk. They key is often to get the basic bread and butter work that pays for the cad license, insurance, the mortgage and then you can look for the profitable jobs.
saveasteading Posted October 2 Posted October 2 2 hours ago, Gus Potter said: a common law of business that applies to small builders / trades folk contracting. Prompted by @Gus Potter Every business is different. But I would give the same quote to a prospective client who openly say 'you come recommended, and we would like a building to do this' ... as I would in formal competitive tender. The former looks like a blank cheque, to add a bit of profit. But it's going to be an easier job, and collaborative, and our reputation hangs on it. Meanwhile the formal one will have the client's consultants all over it trying to show how clever and tough they are. In discussion with a big contractor's MD today , he said publicly that there are about 5 or 6 Architects practices he would refuse to work with, based on very extensive experience. and that collaboration and trust are best for all parties. My attitude was much the same, but includes not liking the attitude of the potential client.... will they pay basically. If a client won't say how many contractors they are asking, then you might be one of 6, with one of them being desperate for work and pricing at a tiny margin. wasting our time, and resources, and with the job suffering on quaity and programme. So no thankyou. 1
SilverShadow Posted October 4 Author Posted October 4 Thanks again for the wide array of responses guys - it's obviously a hugely evocative subject 😅 Apologies again, if this has stirred up ill feelings A few more questions, if you guys would indulge further..... Our architect has stated that revisions are included in the quote (a full redraw would naturally cost extra though). For revisions: 1. Presumably, these can occur even after planning phase (ie: during construction phase), if the design changes for whatever reason? 2. Can anyone specify what is classed as a revision, or redraw - or is this best to clarify with the architect? (i'd assume revisions would be something reasonably minor, eg: not knocking down a partition wall/adding a downstairs 'under the stairs' loo, and redraw would be to start from scratch). It's that fine line where a change is so big it's no longer class as a revision, that's the most intriguing thing 3. If we decide not to do all the proposed work/ require slight changes, then do we need architects drawings updating to reflect this for BC to sign off/approve the build? (I guess it depends on what the deviation from plan is) Regardng bullet point 3: our plan is for the architect to design all our requirements, then likely scale back once costs are known. We were wondering if scaling back needs extra drawing revisions in order for BC to be happy...... Huge thanks as always chaps! Shadow
Nickfromwales Posted October 4 Posted October 4 1 hour ago, SilverShadow said: Apologies again, if this has stirred up ill feelings No need to apologise, they’re all grown ups who are just getting their 2 cents out and onto the table. 1 hour ago, SilverShadow said: Thanks again for the wide array of responses guys - it's obviously a hugely evocative subject 😅 Apologies again, if this has stirred up ill feelings A few more questions, if you guys would indulge further..... Our architect has stated that revisions are included in the quote (a full redraw would naturally cost extra though). For revisions: 1. Presumably, these can occur even after planning phase (ie: during construction phase), if the design changes for whatever reason? 2. Can anyone specify what is classed as a revision, or redraw - or is this best to clarify with the architect? (i'd assume revisions would be something reasonably minor, eg: not knocking down a partition wall/adding a downstairs 'under the stairs' loo, and redraw would be to start from scratch). It's that fine line where a change is so big it's no longer class as a revision, that's the most intriguing thing 3. If we decide not to do all the proposed work/ require slight changes, then do we need architects drawings updating to reflect this for BC to sign off/approve the build? (I guess it depends on what the deviation from plan is) Regardng bullet point 3: our plan is for the architect to design all our requirements, then likely scale back once costs are known. We were wondering if scaling back needs extra drawing revisions in order for BC to be happy...... Huge thanks as always chaps! Shadow Best to simply ask your chosen architect? It’s their contract that has their unique terms within, so in actuality you should already be in possession of those terms; it should be available to you from day 1, contained within their terms of business and T&C’s? 1 1
torre Posted October 4 Posted October 4 3 hours ago, SilverShadow said: Apologies again, if this has stirred up ill feelings If you'd started a basic builders/trades etc thread instead I think you'd see a similar mix of views, coloured by individual good and bad experiences rather than anything intended to offend contributors. 1
SilverShadow Posted December 4 Author Posted December 4 For anyone still keeping tabs on this thread (and i wouldn't blame anyone for not doing so! 😆) Has anyone had experience of using some of these big name architect companies, like: Arkiplan Homz Planning by design They seem to be more of an online service, but appear to have a wealth of services to offer & can provide a comprehensive 'all in 1' package for several £k cheaper than others we've had quotes from. We definitely won't skimp unnecessarily at this step of the process, but likewise would be happy to try these companies if folks have had positive experiences with them For the record: we are still hoping to use a local architect if possible, but been let down recently & so exploring all options to try and push ahead Cheers, all Shadow
Nickfromwales Posted December 4 Posted December 4 3 hours ago, SilverShadow said: For anyone still keeping tabs on this thread (and i wouldn't blame anyone for not doing so! 😆) Has anyone had experience of using some of these big name architect companies, like: Arkiplan Homz Planning by design They seem to be more of an online service, but appear to have a wealth of services to offer & can provide a comprehensive 'all in 1' package for several £k cheaper than others we've had quotes from. We definitely won't skimp unnecessarily at this step of the process, but likewise would be happy to try these companies if folks have had positive experiences with them For the record: we are still hoping to use a local architect if possible, but been let down recently & so exploring all options to try and push ahead Cheers, all Shadow Fwiw, and FYI I have zero knowledge of any of the above, it’s a melting pot. Some are good at A,B,C…..others H,I,J…..and then there’s X,Y,Z. Very few seem to have a complete, overarching knowledge / skill set, and still way too many putting their own personal preference ahead of their clients. Look at their portfolios and decide for yourself if you think you’ll have some synergy, as there’s the pot of gold imho. 1
SilverShadow Posted December 7 Author Posted December 7 Cheers, NFW - tbh, i like the sound of Planning By Design, as they seem to offer services throughout the whole process. Arguably, an online service perhaps doesn't have the ability to see things 'on site'. But we've struggled with getting local architects on board (a lack of engagement, when we've tried to contact them). With a larger company like this, the service is likely to be less-bespoke - but at least we're likely to always have someone to hand! While cost is a factor, having a team there every step of the way is equally vital (especially, as we think getting PP approval from 1 of our neighbours might be tricky). I have noticed a number of side extensions in our area that don't appear 'subservient' to the main building (ie - they are flush with front elevation & in some cases roof continues at the same height). Seems like council rules are 'malleable', if you know how....🤔
saveasteading Posted December 7 Posted December 7 On 07/12/2025 at 15:19, SilverShadow said: think getting PP approval from 1 of our neighbours might be tricky They can object, but must give reasons that link to planning policy. They don't get a vote or veto. 1
SilverShadow Posted December 10 Author Posted December 10 (edited) Many thanks, SAS I have no clear insight into how they'll react. But they have recently gone very quiet after the initial positive dialogue we had. I can't be certain whether they're just waiting to see the plans or have some fundamental concerns, but think IF they do object it'll be possibly be due to Loss of Light. Hopefully though, it'll be fairly minimal, due to the building orientation and the gardens being south-facing, so the sun won't hopefully overshadow their property too badly (aside from the side of their house, which has no windows). We'll just have to see i guess - but if we can find some online service to check light/overshadowing that would be extremely helpful We've also found a service that does a 'Pre-Application' planning appraisal (for £100+VAT), that will take the basic extension requirements and assess the likelihood of PP success the the local Planning Authority (based on previous applications in the area). I'm not sure if this is just gimicky, but this sounds like a valuable service, to increase (not guarantee) the likelihood of PP approval Edited December 10 by SilverShadow
Nickfromwales Posted December 10 Posted December 10 25 minutes ago, SilverShadow said: Many thanks, SAS I have no clear insight into how they'll react. But they have recently gone very quiet after the initial positive dialogue we had. I can't be certain whether they're just waiting to see the plans or have some fundamental concerns, but think IF they do object it'll be possibly be due to Loss of Light. Hopefully though, it'll be fairly minimal, due to the building orientation and the gardens being south-facing, so the sun won't hopefully overshadow their property too badly (aside from the side of their house, which has no windows). We'll just have to see i guess - but if we can find some online service to check light/overshadowing that would be extremely helpful We've also found a service that does a 'Pre-Application' planning appraisal (for £100+VAT), that will take the basic extension requirements and assess the likelihood of PP success the the local Planning Authority (based on previous applications in the area). I'm not sure if this is just gimicky, but this sounds like a valuable service, to increase (not guarantee) the likelihood of PP approval Prob better to use the £100 for beer as nobody can get the application approved. The architect should be advising as part of their ‘professional advice’. 2
SilverShadow Posted December 13 Author Posted December 13 (edited) Thanks again, NFW 😁 Several architects have advised us, but it really seems like a mixed bag. Some we've spoken to err on the side of caution, and would produce a 'safe' design. Others seem a little more open to interpretation of the rules, and think that in our case we might attempt trying to maximise our footprint, due to the orientation of ours & the neighbours house Obviously no-one knows till it goes for submission, & we don't expect any cast iron guarantees. But this (for us) is where we really want their gut feeling & experience to shine through . This is where we feel they can really provide their worth. From what some have said, if the council rejects & asks for a wall to be moved slightly to comply, it can be classed as a minor revision & part of the original proposal. Thus incur no extra fees or restart the process. Is anyone able to verify if this assumption is correct? Edited December 13 by SilverShadow
Gus Potter Posted December 14 Posted December 14 8 hours ago, SilverShadow said: Several architects have advised us, but it really seems like a mixed bag. I've got a couple of projects on my books at the moment, one is a new build the other is a refurb / extension. The planners on the new build have opened the gambit by saying, they think the garden will be over shadowed, the planning officer said they had just been promoted, but here were initial comments essencially pre the formal application ( it's complicated at the council admin went of piste) it was a can kicking excercise. One the other project I have a privacy issue as I'm relocating a conservatory. Below is the kind of extra work I've put into my planning submission. Don't forget I had to survey the site so I could produce a drawing that will become part of the legal planning submission, that takes time and a lot of thought as the levels are not horizontal. One part of the art here is to recognise the obvious things the planners will clock, but not be too technical and indavertantly introduce things they have not thought of which can then invite them to use you as a "free training " excercise, part of their CPD. What I do in these cases is to lead and inform my Clients, each time I say, "I think this might work" I back it up by evidence. I provide info such as the attached so the Client can read and see for themselves the aguements I might want to put forward. I've attached two typical documents I sent to my Clients, one is Scottish based, don't knock it! It's easy to get your head round. This "easy document is based on the UK guidance, BRE 209 which is quite technical so to get your head round that you need to read the easy document first. Now all this does not come for free. There is mention of say getting an Architect for a few grand. But many desingers have special skill sets you need to be prepared to pay for and recognise that this strength and depth of design skill takes many years to develop. 8 hours ago, SilverShadow said: ut this (for us) is where we really want their gut feeling & experience to shine through . Best thing you can do is to read through what I've attached, use AI to help you on terminology, but always check? it's not always right! 8 hours ago, SilverShadow said: Is anyone able to verify if this assumption is correct? It's incorrect as it seems no one has spent the time or effort to put together and evidenced based design. At the end of the day you will probably kick youselves if you later find out you chucked in the towel before you even got started. 8 hours ago, SilverShadow said: Obviously no-one knows till it goes for submission You designers should know enough to say, this has got no chance, if so then why are you taking the risk. OR they should say we think this can be justified, there is latent risk and, refer to the documents I've attached. Now don't forget the Planners can't just run around being loose cannons. Some planning decisions go to appeal, this costs the councils lots of money in hours spent. If they keep losing appeals then their bosses hold their feet to the fire. In summary if you inform yourself a bit more then you'll find a design that embraces your enthusiasm and you'll likely make great progress. All the best and keep your heads up! Daylight and Sunlight guidance 17-06-21.pdf BRE 209 Site Layout Planning for Daylight and Sunlight BRE 2022.pdf 1
Gus Potter Posted December 14 Posted December 14 9 hours ago, SilverShadow said: Is anyone able to verify if this assumption is correct? I got timed out on adding a bit more so here it is which should be apended to my last post: To add a bit! Lots of younger designers, Architects included, have great ideas, some have good old common sense. But they lack the strength and depth of experience to comminicate that to you and then be able to present the business case to you and then explain how they are going to present a planning application, they forget who is paying thier wages... you! One fundamental that you need to instill in young designers is that.. you can be as talented as you like, but if non of your stuff can be affordably built then you are on a sticky wicket! But on the other hand if you sell yourself too cheep then that also leads to a hiding to nothing. I'm ah.. a little older, my problem is keeping ahead of the game as all these young folk are taking no prisoners! The rules change regularly, I have to keep up.. I can't claim grandfathers rights, it's an open competition. @SilverShadow Have confidence in your own ability. From experience I can tell you that many desingers will embrace an informed Client, builders also!. Yes, they may ask you for a bit more fee money but that is a fair days work for fair days pay. Builders like certainty.. if you have Client that keeps changing thier mind the cost often goes up, then they have the hassle of try to get paid for the extras. If the Architect /Designer has not done a detailed job then it all becomes tricky. Builders know this, I used to be one so sometimes added on a "fanny" factor if I though the Client could be a dick head. If I got the job and they turned out to be great I would often do some extras for free, then I stood a better chance of getting recommendation as.. everyone loves a builder that comes in under budget! Now if you think ahead to the build. By going through this process you'll possibly identify other potential savings. A good trades man costs say £ 250.00 - £300.00 a day. If you hit it off with your designer they could easily wash their face fee wise. Think strategically. 1
SilverShadow Posted December 14 Author Posted December 14 (edited) Cheers, Gus - those documents are excellent!! Really informative & clear. From what i can tell, the 2 main factors to consider in the design are: Orientation - avoiding a 'terraced' effect with other properties & being overly imposing Daylight & Sunlight - ensuring the proposal has no impact deemed significant enough for loss of light I've considered it as follows, for our side extension: Orientation: Our house is set back approx 2m from the neightbours There is a 3m gap between buildings The neighbours house is 1-2m naturally higher than ours Their roof is gable end, ours is sloped Our extension is 1m from the boundary line (neighbours building is 2m from theirs), making the 3m gap mentioned above Our side 2 storey extension 1st floor guttering is likely to be about mid-point between their ground floor and 1st floor rear windows Neither property has windows overlooking the boundary, nor will the extension There are a reasonable number of existing 2 storey side extensions in the neighbourhood, where they have built flush with the house front, and closer to their adjacent house, and in some cases not subservient in terms of profile or roof height (we'd add more details of the properties at submission time) It's likely we'd apply for party wall agreement, due to being only 1m from the boundary line Daylight & sunlight: Neither property has side windows, so the 25' rule shouldn't apply The 45' rule (horizontally from their kitchen window) - i can see by eye, that we currently don't cross this line with the existing garage, so wouldn;t anticipate the 1st floor extension to either The 45' rule (vertically from kitchen window - i wasn't aware of this until now!). It's unlikely we'd cross this from our 1st floor guttering level, but it would be within a meter i'd imagine Pitched roof - as ours will be a pitched roof, then it seems like we take the 45' vertical rule from the midpoint, in which case we'd definitely be fine. Is this pitched roof midpoint interpretation correct? Sunlight - both houses rear gardens are Southern facing (South-East, to be precise, so there might be some shadows cast early morning on their front lawn, side of house early afternoon & maybe the rear late evening/sunset As the roof is sloping and 1st floor halfway between their ground floor and 1st floor window, the amount of shadow is far less than it would be on even ground. The shadows would likely hit the side of their house (with no windows) likely no more than halfway up. There are a number of mature trees on the road that could obscure their property from sunlight, regardless of our extension, so hopefully we won't be causing any major impact We don't believe a VSC would be required, given the above All the above is only a high level appraisal, and would need more accurate measurements and assessments. But we feel this is a good starting point for our case This is a crude drawing of the proposed side extension (in orange). The footprint remains unchanged to the existing one, except for moving the front edge forwards 3/4m, in line with the existing front This is not to ask whether you consider the proposal would be successful, but more to enquire if there are other things we should consider when designing & applying...... Edited December 14 by SilverShadow
Gus Potter Posted December 16 Posted December 16 On 14/12/2025 at 16:50, SilverShadow said: Is this pitched roof midpoint interpretation correct? Don't know as can't quite visualise what you have. Can you post some hand sketches of the elevations of both houses. Others on BH will likely chip in so you'll get a variety of views and comment. Glad the documents helped. Thee BRE on can be a bit heavy reading. For all. One way of keeping the professional design fees down is to try and get an understanding yourself of what he issues are and this save time / cost when discussing with your designers. Remember that designers need to know and remember a huge amount, it's just not possible for them to retain all that at their fingertips. what they do need is a big library and know how to find specialist documents when they need to. A well informed Client can thus often prompt designers and engage in a healthy discussion... you all end up working together as a proper team, sharing and discussing ideas and solving problems. 2
SilverShadow Posted Saturday at 11:53 Author Posted Saturday at 11:53 Hi again, Gus - hope you had a great Xmas, buddy 😁 Apologies for the late reply, but it's always a hectic time of year! 🍻 I've enclosed some very basic drawings, which I hope help a little. Apologies, if they're a little crude, but hopefully they give a clearer idea. I can also provide a rear elevation if that helps - but maybe this already gives you a clear enough idea. Please ignore our property's exact roof layout, as it depends on final plans. But it should show it's (currently) a pyramid shape & the neighbours have a gable end facing us I've shaded our new extension a little, to highlight the changes we're hoping to construct I've also put a few rough measurements & projection lines on, to give an idea of overall perspective of us with the neighbour To recap: Their property front elevation is at least 2m forward of ours (& ours probably 2m further back from theirs, at the rear elevation). I'd guess their ground floor is 2-2.5m higher than ours. We also have the 3m gap between properties. The sun hits the rear elevation 1st & swings clockwise (the side away from the neighbour) to the front Hope that gives a better idea, buddy - feel free to ask anything else & I'll happily provide 👍
Gus Potter Posted Saturday at 22:49 Posted Saturday at 22:49 (edited) 10 hours ago, SilverShadow said: I've enclosed some very basic drawings Hope you had a fun time toooo! These sketch drawings are very good! Well done. In terms of the daylight to next door you're allowed a certain reduction before it becomes material. It's somewhere in the docs I think. The overshaddowing of the neighbours doesn't seem to be much of an issue, yet to see the rear elevation, I suspect that may well be ok. Your house is significanlty lower. On 14/12/2025 at 16:50, SilverShadow said: avoiding a 'terraced' effect with other properties & being overly imposing This is a good observation. But the houses are still well separated and you're proposed new roof still significantly lower. If you project a roof line of the terrace down the hill what you are proposing is stil below that. If push comes to shove you could set back the face of the extension a little and / or tweak the roof so the gutter is a little lower than the main house, makes it more subservient / less mass. Usually 1.0m is accepted but I would go for 500mm if pressed as a first offer. Don't offer this up to start with, stick to what you want. If you can sketch like this then have you thought about doing you own scaled hand drawings and submitting a planning application under your own steam? This at least will let you see, what if any, concerns the planners may have and leaves you in full control over the design process at your end. If you do your own application then there is other stuff you need to submit, but that applies in all cases. Here is a quick, but not comprehensive list of things that help build a planning application like this. 1/ A site location plan, OS or say from UK Planning Maps etc, main thing is that it has a copyright number, address and a grid reference. 2/ A block plan showing the site and as you have trees you need to identify these, both within and adjacent your site. Also hedges, fences and heights. I often do a little table and annotate the drawing. Also show existing parking and proposed parking provision, bin storage area and access (also width) to rear garden. The block plan should also show the neighbours with some basic dimensions where the planners might be interested.. You also need to show the garden area and that there is sufficient garden (curtilage) left after you have built the extension. You'll find a guide in the permitted development (PD) guide. In this case you may need to do a block plan on elevation similar to what I posted earlier. Like this: 3/ Site photographs. 4/ Drawings as a minimum. All existing and proposed: Elevations, ground and first floor plans with the rooms annotated, associated with parking provision not least. A roof plan with the roof slopes indicated. Make sure you add a drawing title box, scale bar, a north point on the plan drawings and identify each elevation clearly. 5/ Some water boards are a bit touchy about adding a roof area and connecting the rainwater run off into the existing drainage system. Do a bit of research on this and keep your findings under your hat for now. 6/ Try not to be overly helpful and avoid highlighting things that "might" be debatable say if you were trying to argue some wierd technical planning detail down the pub. Let the planners do their job and come back to you with any requests for more detail. If you fancy doing the drawings yourself then you'll get loads of tips on BH about what and what not to do and, also how to avoid excessive work. Edited Saturday at 22:49 by Gus Potter
