graeme m Posted January 14, 2018 Author Share Posted January 14, 2018 On 1/9/2018 at 13:23, PeterW said: Thats just carbon film electric underfloor heating - no different to any of the systems that are used under laminate flooring. Be aware it can only be used under certain floor types too. For about a third of the cost you can fit standard under tile electric UFH at the outset and if you don’t want to use it, just switch it off ... I think there's more to it than normal LV UFH. It only heats up where it's needed. If the sun is shining on a patch of floor that patch will not heat. Link to comment Share on other sites More sharing options...
PeterW Posted January 14, 2018 Share Posted January 14, 2018 4 minutes ago, graeme m said: I think there's more to it than normal LV UFH. It only heats up where it's needed. If the sun is shining on a patch of floor that patch will not heat. Thats a standard property of carbon film resistance heating - the warmer it gets the less it conducts. It doesn’t care if the heat is from the electrical resistance or from an external heat source, it will self regulate. It’s the same technology that has been used in trace heating tape for years. Link to comment Share on other sites More sharing options...
graeme m Posted January 18, 2018 Author Share Posted January 18, 2018 On 1/14/2018 at 21:42, PeterW said: Thats a standard property of carbon film resistance heating - the warmer it gets the less it conducts. It doesn’t care if the heat is from the electrical resistance or from an external heat source, it will self regulate. It’s the same technology that has been used in trace heating tape for years. I never said it was a new thing. Link to comment Share on other sites More sharing options...
Luckylad Posted January 18, 2018 Share Posted January 18, 2018 On 11/01/2018 at 14:39, Moira Niedzwiecka said: @le-cerveau Thank you for your reply. It is just me by myself. I will go back & question BPC a bit more. They are my preferred option. I will ask them to put me in touch with an installer. Does anyone have any other ideas for a supply & fit? Hello how did you get on with bpc? I’m thinking of using them. thanks. Link to comment Share on other sites More sharing options...
Simplysimon Posted January 18, 2018 Share Posted January 18, 2018 glad to see this coming back on topic as i'm starting to look as well Link to comment Share on other sites More sharing options...
Moira Niedzwiecka Posted February 12, 2018 Share Posted February 12, 2018 @Luckylad Sorry not to respond before. I have not had a chance to look into this further yet. Lots of other more urgent stuff going on. BPC have always been helpful in the past. Link to comment Share on other sites More sharing options...
graeme m Posted February 14, 2018 Author Share Posted February 14, 2018 I'm now looking at the Nilan Compact P system. I like everything in one box. Ducting is blooming expensive though. http://www.nilan.dk/en-gb/frontpage/solutions/domestic-solutions/compact-solutions/compact-p Link to comment Share on other sites More sharing options...
Gone West Posted February 14, 2018 Share Posted February 14, 2018 3 hours ago, graeme m said: I'm now looking at the Nilan Compact P system. I like everything in one box. Ducting is blooming expensive though. That looks very similar to the Genvex Combi 185LS that I have installed in our house. It provides ventilation, hot water and warm air heating. I used plastic ducting which has worked well. Link to comment Share on other sites More sharing options...
graeme m Posted February 16, 2018 Author Share Posted February 16, 2018 Peter dare I ask the price? Link to comment Share on other sites More sharing options...
Gone West Posted February 16, 2018 Share Posted February 16, 2018 3 minutes ago, graeme m said: Peter dare I ask the price? Just over £5000 direct from Denmark. Just over £8500 in bought in the UK. Link to comment Share on other sites More sharing options...
graeme m Posted February 16, 2018 Author Share Posted February 16, 2018 Does that include the ducting? Link to comment Share on other sites More sharing options...
graeme m Posted February 16, 2018 Author Share Posted February 16, 2018 6 hours ago, PeterStarck said: Just over £5000 direct from Denmark. Just over £8500 in bought in the UK. How does the warm air heating work? Is the only heating you have? Link to comment Share on other sites More sharing options...
Gone West Posted February 16, 2018 Share Posted February 16, 2018 14 minutes ago, graeme m said: How does the warm air heating work? Is the only heating you have? It has a built in EASHP which heats the water and heats the ventilation supply air up to 40C. That is supplementary heating because we also have electric towel rails in each of the three 'bathrooms'. These are 300W but are turned down to around 200W and are on eight hours a day. The heat from these is recovered and heats the supply air. We are not living in the house yet but it's kept at around 19C/20C. The Genvex Combi185LS has worked well for us so far but ours is a very low energy house. Link to comment Share on other sites More sharing options...
Gone West Posted February 16, 2018 Share Posted February 16, 2018 44 minutes ago, graeme m said: Does that include the ducting? No I bought plastic ducting and fittings which I fitted myself. I did design the system myself so it was easy to work out was was required. Link to comment Share on other sites More sharing options...
graeme m Posted February 20, 2018 Author Share Posted February 20, 2018 On 16/02/2018 at 16:25, PeterStarck said: It has a built in EASHP which heats the water and heats the ventilation supply air up to 40C. That is supplementary heating because we also have electric towel rails in each of the three 'bathrooms'. These are 300W but are turned down to around 200W and are on eight hours a day. The heat from these is recovered and heats the supply air. We are not living in the house yet but it's kept at around 19C/20C. The Genvex Combi185LS has worked well for us so far but ours is a very low energy house. I'm building Passive certified. The Nilan is similar but it's £5000 here plus the tubing which is £2500 (silver lined apparently). Link to comment Share on other sites More sharing options...
Gone West Posted February 20, 2018 Share Posted February 20, 2018 2 minutes ago, graeme m said: I'm building Passive certified. The Nilan is similar but it's £5000 here plus the tubing which is £2500 (silver lined apparently). The silver coating is to prevent bacteria etc forming on the inside surface. I don't know if that is overkill or not, sounds like it might be to me. Do you have to use their ducting, so it would invalid a warranty if you don't for instance. Link to comment Share on other sites More sharing options...
graeme m Posted February 20, 2018 Author Share Posted February 20, 2018 I don't know as only spoke briefly with the supplier. I'm waiting on the revised PHPP before making taking things further. Link to comment Share on other sites More sharing options...
stratman90 Posted February 20, 2018 Share Posted February 20, 2018 Anybody experience in dealing with Beam when it comes to MVHR? I'm getting a quote this week from them. From the sound of things it sounds like I need to speak to BPC too! Link to comment Share on other sites More sharing options...
dpmiller Posted February 20, 2018 Share Posted February 20, 2018 they rebrand Titon units IIRC. Link to comment Share on other sites More sharing options...
JOE187 Posted February 25, 2018 Share Posted February 25, 2018 https://www.electrical2go.co.uk/heatrae-sadia-hru-eco-4-apartment-unit-hrueco4apart.html?utm_source=google_shopping&gclid=EAIaIQobChMIk-C0vtnA2QIVSrftCh204w7iEAQYCiABEgKGqfD_BwE I installed this unit over 2 floors 5 extracts and 5 supply vents with wireless controllers. Power consumption is 6 watts slow speed, 12 watts on mid speed, and 48 watts on boost! Runs on slow speed continually and boost when required humidity is very comfortable. Filters are easy to source and replace around £20 a set. Link to comment Share on other sites More sharing options...
