Identify this please
Pocster
I thought this would be easy to find. presumably I don't know exactly what it is called.
Screw fitting is 32mm
So it's an elbow but the thread is reversed i.e. it screws upwards. So like a 90degree conversion bend but screws upwards ( hope that makes sense )
I looked at
threaded elbow
drain threaded elbow
32mm elbow
can't seem to find it...
Nearest I've found is this
https://www.bes.co.uk/polypipe-32-mm-white-threaded-coupling-solvent-11867/
or maybe this?
https://www.toolstation.com/mcalpine-compression-bsp-connections-bend-90/p62086?store=null&utm_source=googleshopping&utm_medium=feed&utm_campaign=googleshoppingfeed&mkwid=_dc&pcrid=null&pkw=null&pmt=null&gad_source=1&gbraid=0AAAAAD-vLcVa5oxgpUmv6KLSvo8W1HJDI&gclid=CjwKCAiA0rW6BhAcEiwAQH28IpW2puBtiAGeNWUHrUg0QczTpzLtjOM2H1swydNIFvQ9tGmzuqwRIhoCJEQQAvD_BwE&gclsrc=aw.ds
Assume the 'ribbed' end isn't an issue... could stick rubber washers over it I guess...
What is it called!
Just now, ProDave said:
What is it from?  If it's one part of a packaged waste trap, the intermediate parts are often not a standard size that will tit much else.
It came with the mvhr - I need another . It’s the drain vent outlet . So screws into that then smooth end slides into water less flexible trap .
Just now, AliG said:
Yep - I found that . Wasn’t keen on 50 quid for the lot !
Screwfix do something similar but ribbed again
Just now, FuerteStu said:
Just a thought.. But surely at some point it goes into a standard sized pipe. Could you not try and joint to that rather than bodge two standard fittings into each other?
The end goes into a rubber trap . That then has a reducing rubber which takes it down to 21mm pipe . The mvhr came with all this - so obviously I just used it . Making another seems more trouble than it’s worth . I’ve sourced everything else just this fitting .
14 minutes ago, ProDave said:
Just a point.  You kept confusing me with this "ribbed end"  It is not ribbed, it is threaded.  Perhaps you were thinking of something else?
Yes . I guess maybe to stop confusing to the other threaded end . But @ProDave when the action is on you ain’t gonna care if it’s screw or ribbed 😉
12 minutes ago, ProDave said:
Of course, me being me and liking a challenge, if that was the nearest available but I didn't want a thread on the right hand part, I would be tempted to put that on my lathe and turn the thread off
Pah! that's taking the easy route.  You should put the  pipe it goes into on the lathe and cut a female thread in it 😜
Edited by Benpointer
