MJNewton Posted 22 hours ago Share Posted 22 hours ago 3 hours ago, Pocster said: The water I assume must be from ‘extract from dwelling ‘ . Still confused how this happens …. Remember the 'extract from dwelling' air will have some heat extracted from it thus raising its relative humidity which, at the saturation point, will cause condensation to form. Link to comment Share on other sites More sharing options...
Pocster Posted 22 hours ago Author Share Posted 22 hours ago 3 minutes ago, MJNewton said: Remember the 'extract from dwelling' air will have some heat extracted from it thus raising its relative humidity which, at the saturation point, will cause condensation to form. So perhaps its ’normal ‘ ?? Link to comment Share on other sites More sharing options...
MJNewton Posted 22 hours ago Share Posted 22 hours ago 2 minutes ago, Pocster said: So perhaps its ’normal ‘ ?? Yeah, and of the four air sections I'd expect it to be the only one where water would appear. (Okay, perhaps the occasional stray raindrop might get sucked in through the outside air intake too.) There's still the issue of why this water wasn't draining away though. Or have you solved that? Link to comment Share on other sites More sharing options...
ProDave Posted 22 hours ago Share Posted 22 hours ago So you know both sides collect condensate, and both have a hole in the bottom. So find another fitting then tee both condensate outlets to your drain. Think of it as a product upgrade. Link to comment Share on other sites More sharing options...
Pocster Posted 22 hours ago Author Share Posted 22 hours ago (edited) Well ! vent axis instructions insist on ONE drain . Apparently according to them - 2 drains can conflict and cause vacuum on the other . So drain on left side as instructions dictate . Water on right - as there is no drain . I want to know why vent axia don’t mention this …. I simply can’t be the only person ever to experience this . Edited 22 hours ago by Pocster Link to comment Share on other sites More sharing options...
Canski Posted 21 hours ago Share Posted 21 hours ago I’m having a similar problem with one of my in-line fans. It was noisy from day one so the plumber turned the power down. It still passed the ventilation test but since then got louder and louder then silent apart from the sound of trickling water. He’s just been up in the loft to inspect and drained some water out and turned it back up a notch. It sounds fine at the moment but ( while it’s still under guarantee) he’s going to order a replacement and switch them over. There is a very slight rise (about 10 mm in 250 mm) from the extractor to the condense trap but he thinks this won’t be the cause of the problem. When he installs the replacement he will raise it up anyway. 1 Link to comment Share on other sites More sharing options...
Mike Posted 20 hours ago Share Posted 20 hours ago I can't help with that system, but: Condensation should only form on the exhaust ("to atmosphere") side. In winter, warm moist air from the house is being chilled by the incoming air, so the air will no longer be able to hold as much water, causing condensation if the temperature drops enough. If a unit isn't built with good enough insulation between the supply and exhaust sides, or if it allows air to leak from one side to the other to any great extent, then theoretically condensation could form on the wrong side. I've not heard of that happening though, and it would be surprising if that happened only after 3 years of use. Unless the heat exchanger has been removed and hasn't been seated correctly afterwards? You definitely don't want two drainage points; that would be a route for air to leak between the intake and the exhaust. 1 Link to comment Share on other sites More sharing options...
Pocster Posted 8 hours ago Author Share Posted 8 hours ago 12 hours ago, Mike said: I can't help with that system, but: Condensation should only form on the exhaust ("to atmosphere") side. In winter, warm moist air from the house is being chilled by the incoming air, so the air will no longer be able to hold as much water, causing condensation if the temperature drops enough. If a unit isn't built with good enough insulation between the supply and exhaust sides, or if it allows air to leak from one side to the other to any great extent, then theoretically condensation could form on the wrong side. I've not heard of that happening though, and it would be surprising if that happened only after 3 years of use. Unless the heat exchanger has been removed and hasn't been seated correctly afterwards? You definitely don't want two drainage points; that would be a route for air to leak between the intake and the exhaust. Condensation is as you say on the exhaust pipes ( to atmosphere ) . So as expected . I’ve never removed the heat exchanger unit now so *assume* it’s in the right way round ! . How can I tell ? I think it would fit in either way which sounds like bad design imho . Heat exchanger is a snug fit so no chance of sitting incorrectly. Link to comment Share on other sites More sharing options...
Pocster Posted 8 hours ago Author Share Posted 8 hours ago So it’s dripping again from the front . Opened both valve caps empty of water . So the heat exchanger I assume . Do I clean it ? Just rinse water through it ?? Link to comment Share on other sites More sharing options...
Pocster Posted 7 hours ago Author Share Posted 7 hours ago Notice felt guide on one side bent . Other side fell off . Ct1 that side back on ? Is this enough to cause water to run forwards ? Link to comment Share on other sites More sharing options...
Pocster Posted 7 hours ago Author Share Posted 7 hours ago Stuck a small spirit level inside it as best I could . Assume really I want it to be slightly tilted back so water runs away from the front and to the left where my drain is . Seems to be the opposite in both axis !! Link to comment Share on other sites More sharing options...
Pocster Posted 5 hours ago Author Share Posted 5 hours ago (edited) I managed to pack it off the wall at the base . So it tips a bit more backwards . At this point in time as it’s run flawlessly for 4 yrs - I can only assume it’s moved slightly causing water to pool forwards and to the right ( bit with no drain ) . Or maybe dirt/ dust in the heat exchanger changing water flow direction ??? . How best clean that ? . Just sit in the bath and run hot water and detergent through it ?? All back together now . Want too see that water out the front has been solved . Then it’s in the lap of the gods if it flows left ( hurrah ) or right ( boo ) Edited 5 hours ago by Pocster Link to comment Share on other sites More sharing options...
Eric Posted 4 hours ago Share Posted 4 hours ago Just wash the heat exchanger in the bath, I’m sure I read somewhere that it has to be fully dry before it’s fitted though? I had to pack my vent axia unit out a touch at the bottom as I had water coming out of the front but only slightly, this helped the issue. I was shocked at how much water the unit produced in the winter as I was catching it in a bucket until I got the drain sorted. Mine was in a cold attic & insulated as good as I could get it. 1 Link to comment Share on other sites More sharing options...
Pocster Posted 4 hours ago Author Share Posted 4 hours ago 7 minutes ago, Eric said: Just wash the heat exchanger in the bath, I’m sure I read somewhere that it has to be fully dry before it’s fitted though? I had to pack my vent axia unit out a touch at the bottom as I had water coming out of the front but only slightly, this helped the issue. I was shocked at how much water the unit produced in the winter as I was catching it in a bucket until I got the drain sorted. Mine was in a cold attic & insulated as good as I could get it. I’ll let it run for tonight and see . When I did take the heat exchanger out it did have a surprisingly large amount of water in it . Link to comment Share on other sites More sharing options...
