junglejim Posted July 23, 2024 Posted July 23, 2024 Looking for recommendations on how to attach the breather membrane beneath counter batten. I’m thinking staples but worried about compromising the fabric. any tips?
junglejim Posted July 24, 2024 Author Posted July 24, 2024 I’ve read somewhere about using staples ands tape to attach membrane and mark stud locations. In struggling to picture this. Any ideas?
Russell griffiths Posted July 24, 2024 Posted July 24, 2024 If your putting a counter batten on your going to be punching dozens of holes in the membrane the staples are only to hold it in place while you fit the counter batten. you can get a butyl tape that fits on the back of the counter batten to seal any penetrations. I’ve never seen anyone use it.
junglejim Posted July 24, 2024 Author Posted July 24, 2024 22 minutes ago, Russell griffiths said: If your putting a counter batten on your going to be punching dozens of holes in the membrane the staples are only to hold it in place while you fit the counter batten. you can get a butyl tape that fits on the back of the counter batten to seal any penetrations. I’ve never seen anyone use it. Thanks. That’s interesting so should I be aiming to staple where the counter batten will be positioned?
Redbeard Posted July 24, 2024 Posted July 24, 2024 There are 2 schools of thought: 1. A hole with a fixing in it (a staple in this case) is not a hole at all and 2. (The more pessimistic one: A hole with a staple in might leave a residual hole). Both are valid! If you are at all concerned get a roll of suitable external-grade air-tightness tape (I know this is not an a/t issue, but some tapes are waterproof too) and stick a small piece over each staple. Tedious, but you can tick that off and proceed to the next issue. The butyl tape would work too - double-sided for pref. A mall piece wherever a nail is going through and Robert is your parent's sibling.
junglejim Posted July 24, 2024 Author Posted July 24, 2024 1 hour ago, Redbeard said: There are 2 schools of thought: 1. A hole with a fixing in it (a staple in this case) is not a hole at all and 2. (The more pessimistic one: A hole with a staple in might leave a residual hole). Both are valid! If you are at all concerned get a roll of suitable external-grade air-tightness tape (I know this is not an a/t issue, but some tapes are waterproof too) and stick a small piece over each staple. Tedious, but you can tick that off and proceed to the next issue. The butyl tape would work too - double-sided for pref. A mall piece wherever a nail is going through and Robert is your parent's sibling. Thanks, that’s really helpful. Can you recommend a stapler… the manual ones I’ve tried previously struggle to go into osb.
Redbeard Posted July 24, 2024 Posted July 24, 2024 38 minutes ago, junglejim said: Thanks, that’s really helpful. Can you recommend a stapler… the manual ones I’ve tried previously struggle to go into osb. I regret not, but there are compressed air staplers starting at under £50 in places like 'ToolFixstation'. Of course you'd need to buy or hire a compressor but they exist to buy at £100+, and presumably might be useful to you in the next stages of the job.
Tosh Posted July 24, 2024 Posted July 24, 2024 1 hour ago, junglejim said: Can you recommend a stapler… the manual ones I’ve tried previously struggle to go into osb. Hammer tacker
markocosic Posted January 6, 2025 Posted January 6, 2025 On 24/07/2024 at 11:50, Russell griffiths said: you can get a butyl tape that fits on the back of the counter batten to seal any penetrations. I’ve never seen anyone use it. Common in Lithuania for what it's worth. Not butyl tape, but a thin later of sticky back foam on the battens holding down membranes. Easier than aiming for a blob of sealant with the screw/nail. Airtightness testing of all new builds is a thing for building regs signoff though. It also helps mitigate roof rain noise when using (common here) metal roofing.
saveasteading Posted January 6, 2025 Posted January 6, 2025 On 24/07/2024 at 12:24, junglejim said: Can you recommend a stapler… An old thread resurrected. But I have just bought a wickes stapler for about £15. Fixes membrane to osb nicely, also dpc to timber. I would want something less manual if doing a very big area.
joe90 Posted January 6, 2025 Posted January 6, 2025 I used one of these, dead easy to use, one handed use, reasonably priced. https://www.deubaxxl.co.uk/hammer-tacker-stainless-steel/105471/?gad_source=1&gbraid=0AAAAABwmGWKbaubbZFwbS5ukBqQXMrwoN&gclid=CjwKCAiAm-67BhBlEiwAEVftNncvbi3sDeqLHatNY5kZgG2DhlhNuZtZcHGEhPruJ4A0Kl6JqszWFhoCA8YQAvD_BwE
jack Posted January 6, 2025 Posted January 6, 2025 19 minutes ago, joe90 said: I used one of these, dead easy to use, one handed use, reasonably priced. https://www.deubaxxl.co.uk/hammer-tacker-stainless-steel/105471/?gad_source=1&gbraid=0AAAAABwmGWKbaubbZFwbS5ukBqQXMrwoN&gclid=CjwKCAiAm-67BhBlEiwAEVftNncvbi3sDeqLHatNY5kZgG2DhlhNuZtZcHGEhPruJ4A0Kl6JqszWFhoCA8YQAvD_BwE The guys who did our build used one of those. Super fast, easier to use over a wide area without having to move around so much, and waaay less stress on the wrists. 1
saveasteading Posted January 6, 2025 Posted January 6, 2025 I decided against a hammer tacker because of the proximity of the hammer to the other hand, holding the membrane....my left thumb is virtually hurting even as I write the words. 1
joe90 Posted January 6, 2025 Posted January 6, 2025 I get that but mostly you can pull the membrane from a distance,
miike Posted January 6, 2025 Posted January 6, 2025 I got a DeWalt heavy duty stapler that has no issues going into OSB. It requires quite a bit of pressure to use though, which you can certainly feel after a few thousand staples.
junglejim Posted January 6, 2025 Author Posted January 6, 2025 I used a hammer tacker in the end… really easy and quick to use… found it invaluable. 1
DownSouth Posted January 7, 2025 Posted January 7, 2025 https://arrowfastener.com/tool/t50/ our TF erection team had one of these, a cut above our Stanley’s one which was always jamming. Easy to use, very solid.
Alan Ambrose Posted January 7, 2025 Posted January 7, 2025 (edited) Tacwise, of course, have all sorts of cheap electric staplers and small nailers. I think manual, electric, battery and air driven. They have stainless staples also if you need them. I have a couple of the small electric staplers. They need a bit of downwards pressure. No safety nose on the ones I have so I’m careful with them. Useful for fixing into softwoods and can take small brads too. Edited January 7, 2025 by Alan Ambrose
