Insulated raft done
kandgmitchell
Just to add to the wealth of knowledge on here.
We have just completed our insulated raft using xps with concrete 250mm thick at 100m2. Installed the foul drains and surface water out to a soakaway.
All in,  including labour it's come to £26K and a bit. Hope this might help with others budgeting.
This is to take a DanWood timber frame. The frame sits on the edge of the slab with the exterior insulation overhanging. More insulation goes ontop of the slab and an insulated former is used at door openings (from what I can see from the details provided). No special shuttering although we backed the vertical insulation with scaffold boards just in case. Be honest I doubt if they were needed though. It was a Green Raft that uses a vertical plastic joining strip between the horizontal and vertical insulation panels.
Idid look at that
but as we have 700mm original granite walls  it was not possible
webasically have a modern wood framed house inside granite walls
so we went for concrete sub floor --100mm of pir and up the walls then ufh and going screed ontop of that
Edited by scottishjohn
44 minutes ago, Dunc said:
May I ask: how big is the raft (square meterage) and roughly what shape (simple rectangle vs something fancy)?
Nigh on 100m2 simple rectangle but with two pairs of 200mm x 850mm "outshoots" which support an open gable feature on the rear and front elevations.
Final two photo's 8053 is the steel, sorry it was getting dark when I rembered to take this. Layer of A393 mesh in bottom and top with a further layer of A393 min 1.0 m wide around the upper perimeter (we just used the 1.4m offcuts from the main mesh). A couple of embedded beams using 16mm bars where the main load bearing walls are.
8059 is the finished raft with a muddy surface due to the state of the ground whilst the rain water drainage was being done. I'll power wash it off before the frame arrives.
  • Like 3
Could you tell me how thick was the XPS as it will affect the budget if I go thicker. Thanks.
The stone was MOT1 type stuff which I think is max 30mm downwards. It packed tight with a 2T vibrating roller.
I used 150mm xps for the insulation because the Dan Wood spec uses 90mm of insulation across the top of the raft. I could have added more but it was diminishing returns really.
  • 4 weeks later...
Just to add to this with a bit of experience of what I would do differently "next time".
I had installed 50mm twin wall duct for the electric supply. After completing the raft that duct was extended by the groundworkers to the electric kiosk with the meter some 20 odd metres away.
Only later did I consider the cable needs - 3 phase 25mm. Upon picking it up from the suppliers I could immediately sense a problem coming. A) it was heavy and B) it didn't bend well.
This week I discovered drawing it through a 50mm duct was not practical - should have used 80mm at least. Also the bends in the duct made pulling the cable through a nightmare. Luckily, after a struggle we got it outside the raft (all of 3 metres) but had to dig down to it and cut it open to get past the first (of several) too tight bends. Finally have strained back trying to pull it the last 5 metres - can't even bend over at present! Resourceful wife asked two random men in a family of four passing by to help and they very kindly stepped in and pulled it the last bit while I sat on the floor in a lot of pain.
So, 1) work out cable needs in advance.
       2) use a bigger duct than you think you need
       3) consider running the cable through the duct laid out in a straight line, then placing both duct and cable in place in one go so you know it will bend where you need it to!
       4) just get someone else younger and fitter to do it!
  • Like 3
  • 9 months later...
Congrats, you must feel that’s a major step forward. Thanks for posting the images and the ‘what not to do’ hints.
Any chance of an anonymised drawing? I’m interested in the position of dpcs, barriers etc. I think xps a much better choice than, say, Kore. Mind if I ask how you got the drains and ducts (a) in the right place and (b) held in the right place during the pour?
50 minutes ago, AartWessels said:
Just out of curiosity, how did you 'sleeve' any of the ducting through the insulation?
Why would you sleeve the ducting through the insulation.
the duct is the sleeve, the cable or pipe passes through the duct, the duct should be sealed tightly to the insulation.
