WiltshireLink Posted December 23, 2023 Share Posted December 23, 2023 Hi All, No it's not sprout related... We have been progressing well with the Nudura but this wind is causing havoc. We haven't got scaffold or alignment system yet as we weren't that high but getting blocks up to the near joist level and the wind is just blowing it over or off the DPC block. Would the scaffold/alignment really combat the wind? Any tips? I thought about bracing it vertically to the concrete filled DPC level to strengthen it Cheers 1 1 Link to comment Share on other sites More sharing options...
Russell griffiths Posted December 23, 2023 Share Posted December 23, 2023 I didn’t get the braces on site until I had the whole structure up to 2.7m we had some bad wind and only lost a block or two. Start at the corners and leave some gaps out in the middle to let the wind through. You will need loads of scaffolding boards for when the braces come, I don’t think many bracing systems hire out with boards, so you might as well get 20 boards now and a bundle of batten and get it propped, ready for the bracing system. 2 1 Link to comment Share on other sites More sharing options...
WiltshireLink Posted December 23, 2023 Author Share Posted December 23, 2023 perfect thats what I was thinking cheers! Link to comment Share on other sites More sharing options...
ProDave Posted December 23, 2023 Share Posted December 23, 2023 @ToughButterCup Will give you the low down on this. Link to comment Share on other sites More sharing options...
JohnMo Posted December 23, 2023 Share Posted December 23, 2023 Our ICF build (Durisol) I did 6 blocks high and then concrete filled. 1 Link to comment Share on other sites More sharing options...
FM2015 Posted December 23, 2023 Share Posted December 23, 2023 Brace as you go either with timber or alignment system. Broken blocks might only reveal any damage when you come to pour. Bridge between your rising walls and your ground floor. Fix down as well as laterally. Close off your cavities rather than cutting holes in corners. Building off a ladder holding a box kite is as fun as it sounds. 1 Link to comment Share on other sites More sharing options...
WiltshireLink Posted December 23, 2023 Author Share Posted December 23, 2023 3 hours ago, Russell griffiths said: I didn’t get the braces on site until I had the whole structure up to 2.7m we had some bad wind and only lost a block or two. Start at the corners and leave some gaps out in the middle to let the wind through. You will need loads of scaffolding boards for when the braces come, I don’t think many bracing systems hire out with boards, so you might as well get 20 boards now and a bundle of batten and get it propped, ready for the bracing system. Did you brace vertically on the inside too? Link to comment Share on other sites More sharing options...
Russell griffiths Posted December 24, 2023 Share Posted December 24, 2023 10 hours ago, WiltshireLink said: Did you brace vertically on the inside too? What do you mean, temporarily or for pouring. If temporarily then do whatever you feel needs doing. Same for the pour really, I over braced everything, but didn’t have a single issue apart from one reveal that I had actually forgotten to put screws in some timber. Half a dozen screws later it was all fixed. too much bracing??? probably. Did I have any problems?? no. 1 Link to comment Share on other sites More sharing options...
saveasteading Posted December 24, 2023 Share Posted December 24, 2023 1 hour ago, Russell griffiths said: 11 hours ago, WiltshireLink said: Did you brace vertically on the inside too? What do you mean, temporarily or for pouring. If temporarily then do whatever you feel needs doing. Same for the pour really, I over braced everything, but didn’t have a single issue apart from one reveal that I had actually forgotten to put screws in some timber. Half a dozen screws later it was all fixed. too much bracing??? probably I'd say no. The power of the wind is amazing, and it especially likes to damage partly built structures. Link to comment Share on other sites More sharing options...
WiltshireLink Posted December 24, 2023 Author Share Posted December 24, 2023 3 hours ago, Russell griffiths said: What do you mean, temporarily or for pouring. If temporarily then do whatever you feel needs doing. Same for the pour really, I over braced everything, but didn’t have a single issue apart from one reveal that I had actually forgotten to put screws in some timber. Half a dozen screws later it was all fixed. too much bracing??? probably. Did I have any problems?? no. No sorry, just whilst awaiting pour, I will using alignment and scaffold for when pouring etc. Cheers Link to comment Share on other sites More sharing options...
Jenki Posted December 24, 2023 Share Posted December 24, 2023 I built ICF (Poly Steel), in the Highlands, and wind needed thinking about from the start. We had to strap our block pallets to each other to stop them blowing away. I used scaffolding on the inside, and timber bracing as I went. 1 Link to comment Share on other sites More sharing options...
WiltshireLink Posted January 6 Author Share Posted January 6 The wind defences are going in! Been longing to do this all week. Thanks all for your help Link to comment Share on other sites More sharing options...
saveasteading Posted January 6 Share Posted January 6 Just interested, and I have no advice to offer. Is there any stipulation on constructing in vertical stages? For a structural concrete wall it would only be done with a lot of attention , and steel, at the overlaps. But if it was hollow concrete blocks I would certainly want to do it in stages, just for convenience. And with this lightweight system there would be the advantage of the dead weight and strength. I guess it isn't allowed. Link to comment Share on other sites More sharing options...
ChrisJ Posted January 7 Share Posted January 7 On 06/01/2024 at 14:56, saveasteading said: Just interested, and I have no advice to offer. Is there any stipulation on constructing in vertical stages? For a structural concrete wall it would only be done with a lot of attention , and steel, at the overlaps. But if it was hollow concrete blocks I would certainly want to do it in stages, just for convenience. And with this lightweight system there would be the advantage of the dead weight and strength. I guess it isn't allowed. Typically you try and have the ICF bracing system on site prior to start and install as soon as needed, building ICF in vertical stages would typically make the project cost prohibitive just in concrete pump trucks plus the additional .5-1 m3 of concrete needed each time you place concrete. With the exception of tornado style winds, ICF when braced prior to concrete placement holds up quite well, perhaps a bit of adjustment needed after the winds prior to placing concrete 1 1 Link to comment Share on other sites More sharing options...
