Onoff Posted January 1, 2024 Posted January 1, 2024 If filling a pallet wall with insulation, what's the best stuff to use? PIR would be a complete pain to do I'm thinking. Something fluffy I guess?
JohnBishop Posted January 7, 2024 Author Posted January 7, 2024 On 01/01/2024 at 22:43, Onoff said: If filling a pallet wall with insulation, what's the best stuff to use? PIR would be a complete pain to do I'm thinking. Something fluffy I guess? Expand The insulation will go to my next building I build next year. I reckon it will be some Knauf. Regarding the breathable membrane, should I put it from the bottom over the DPM or start where DPM ends?
JohnBishop Posted January 20, 2024 Author Posted January 20, 2024 On 31/12/2023 at 11:40, Onoff said: That's what we did. It'll make it easier to put your cladding on, regular fixing points etc. We used a combination of tile battens and some fresh timber milled to the same size from the chap who gave us the cladding (literally offcuts from milling the trees). Staple your membrane on. I've a couple of this sort though Parkside ones from Lidl: https://www.ebay.co.uk/itm/374194279817? With a helper roll it out along a side, watch you keep the bottom level to whatever line you're finishing at. Staple top left. Then with the helper holding the roll staple bottom right. Stapling on the diagonal will keep it taught. Staple here and there. Cut the membrane and fold/staple into any window & door reveals. You'll want a horizontal batten top and bottom to try and prevent insect and vermin ingress. Then do vertical battens (between the top and bottom ones) and cladding. Got any pictures yet? Expand Hi again, you said about bottom and top battens but then what about the airflow?
Onoff Posted January 20, 2024 Posted January 20, 2024 On 20/01/2024 at 13:45, JohnBishop said: Hi again, you said about bottom and top battens but then what about the airflow? Expand The natural milled lumber we used as cladding warps and twists thus the cladding is pretty "open" to airflow. With tight fitting cladding I'd consider L shaped mesh perhaps instead of a batten top and bottom.
Onoff Posted January 20, 2024 Posted January 20, 2024 (edited) Make the top and bottom battens 3mm thinner and mount on some 3mm (blue) trouser shims. Edited January 20, 2024 by Onoff
JohnBishop Posted April 29, 2024 Author Posted April 29, 2024 Just another picture of the shed. Not finished yet but done the cladding, just need to finish of some bits and pieces. 4
Pocster Posted April 30, 2024 Posted April 30, 2024 On 29/04/2024 at 22:20, JohnBishop said: Just another picture of the shed. Not finished yet but done the cladding, just need to finish of some bits and pieces. Expand Yeah it does look like a shed …. But ! Inside ….. 1
Onoff Posted April 30, 2024 Posted April 30, 2024 On 30/04/2024 at 09:47, Pocster said: Yeah it does look like a shed …. But ! Inside ….. Expand It looks like YOUR shed!
Pocster Posted April 30, 2024 Posted April 30, 2024 On 30/04/2024 at 09:59, Onoff said: It looks like YOUR shed! Expand You can come in my shed anyday
JohnBishop Posted April 30, 2024 Author Posted April 30, 2024 yes, I am in the process of digging a dungeon 1
JohnBishop Posted May 6, 2024 Author Posted May 6, 2024 what do you think I should put in front of the shed? 1. block pavement 2. pavement slabs 3. fill with MOT aggregate, grid system on top then gravel/shingle 20mm like https://www.nidagraveluk.co.uk/
