Dan1983 Posted February 23, 2023 Posted February 23, 2023 Evening all, Please could I ask for some advice on plasterboarding. I have started to board out my oak frame/ wood clad garage. It has a breather membrane then 50mm celotex, then 12.5mm plasterboard on top. The uprights I’m fixing to are 600 centers but not really wide enough to fix two boards to. This means I’m ending up with approx 450mm overhang on some boards due to the spacing. There is no movement in the boards as they are hard up against the celotex. Will this cause issues later? Only thing I can think of doing is bonding the unscrewed section of board to the celotex.  Thanks for any pointers!  Â
Nickfromwales Posted February 23, 2023 Posted February 23, 2023 Ah, schoolboy error. You have 600mm centres so should have one stud in the centre and one each end of each board ( hence 1200mm boards ). You can get some Knauf board adhesive in tube form, loosen the board off, and bond them onto the PIR and to each other. Use a scraper and a sponge to clean up excess, and don't go mad with the adhesive. 1
Nickfromwales Posted February 23, 2023 Posted February 23, 2023 Something like this will do tbh; Â https://www.google.com/search?q=gypsum+adhesive&sa=X&rlz=1C1GCEA_enGB860GB860&biw=1536&bih=754&tbm=shop&ei=r933Y46xFI7VgQa0tYmoBQ&ved=0ahUKEwjOxJKTzqz9AhWOasAKHbRaAlUQ4dUDCAg&uact=5&oq=gypsum+adhesive&gs_lcp=Cgtwcm9kdWN0cy1jYxADMgcIABCABBAYMgkIABAeEPEEEBgyCAgAEAUQHhAYMgsIABAIEB4Q8QQQGDILCAAQCBAeEPEEEBgyCwgAEAgQHhDxBBAYMgsIABAIEB4Q8QQQGDILCAAQCBAeEPEEEBgyCwgAEAgQHhDxBBAYMggIABAIEB4QGDoKCAAQgAQQsAMQGDoJCAAQCBAeELADOgkIABAeELADEBg6DggAEAgQHhDxBBCwAxAYOgsIABAIEB4QsAMQGDoJCAAQDRCABBAYOgYIABAHEB46DQgAEAgQHhANEPEEEBg6CggAEAgQHhANEBg6CggAELEDEIMBEEM6CwgAEIAEELEDEIMBOgUIABCABDoLCAAQHhANEPEEEBg6CggAEAUQHhANEBhKBAhBGAFQiRtY7DVgtUFoAXAAeACAAY8BiAHTCZIBBDAuMTGYAQCgAQHIAQrAAQE&sclient=products-cc#spd=9699038899737614391 1
Radian Posted February 23, 2023 Posted February 23, 2023 Or... Small area like that, just bond another staggered layer of PB on top. Increase the fire rating, decrease the sound etc. 1
Dan1983 Posted February 24, 2023 Author Posted February 24, 2023 Thank you guys, Yes error on my part! Glad I’ve learnt this lesson on the walls and not the ceiling! Ive ordered some adhesive and will bond the edges. Think I should stick to my day job!
markc Posted February 24, 2023 Posted February 24, 2023 4 minutes ago, Dan1983 said: Thank you guys, Yes error on my part! Glad I’ve learnt this lesson on the walls and not the ceiling! Ive ordered some adhesive and will bond the edges. Think I should stick to my day job! Don’t stress or worry about it, learn and move on. We all f@#k up at times. 1 1
ProDave Posted February 24, 2023 Posted February 24, 2023 2 hours ago, Dan1983 said: Glad I’ve learnt this lesson on the walls and not the ceiling! I always board a ceiling first, then the walls, so the edge of the ceiling boards is covered by the wall boards. 1
Nickfromwales Posted February 24, 2023 Posted February 24, 2023 4 hours ago, Dan1983 said: Think I should stick to my day job! LOL Â 1
Dan1983 Posted February 24, 2023 Author Posted February 24, 2023 oak frame Dave so I’m leaving the beams exposed so boards will remain separate if that makes sense.  Still toying with the idea of painting the ceiling joists and recessing the plaster board to give a beam effect but seems like a load of timber and effort and less room for insulationÂ
Nickfromwales Posted February 24, 2023 Posted February 24, 2023 1 minute ago, Dan1983 said: oak frame Dave so I’m leaving the beams exposed so boards will remain separate if that makes sense.  Still toying with the idea of painting the ceiling joists and recessing the plaster board to give a beam effect but seems like a load of timber and effort and less room for insulation Get the amount of insulation in that you want, and cover the ceiling joists ( as they're just cheap tanalised timber anyways ). Plasterboard right through, and then get some reclaimed oak sections made up and screw on these lengths to make it look like the joist ( rafter ) ends were exposed. You need markers so you can screw through these and into the covered timber, for fixing them. Recess the screw heads slightly, and make plugs to fill the screw holes.  Plaster up to the faux oak timbers so you have a rustic edge ( as you'll have on the walls ) and then get yourself painted, and off to the pub.  Faux beams can be made to look authentic quite easily, and would look shit-loads better than a plain ceiling in there ( IMO )  1
Dan1983 Posted February 24, 2023 Author Posted February 24, 2023 Cheers for info Nick. That was reason for potentially painting the joists as treated so would look naff plain as you say. Kind of wish we had done  fake beams in the main house to give some more character but sure that was looking quite pricey at the time!
Nickfromwales Posted February 24, 2023 Posted February 24, 2023 You'd have a great looking garage though  Just have dinner in there?
Dan1983 Posted March 3, 2023 Author Posted March 3, 2023 OCD got the better of me and re did the 3 naff walls! Â Â
markc Posted March 3, 2023 Posted March 3, 2023 Well done, not enough bullet holes for @pocster tho 😉 1 1 1
Mr Punter Posted March 3, 2023 Posted March 3, 2023 26 minutes ago, Dan1983 said:  Nice job. Did that package in the foreground come from @pocster? 1 1
Dan1983 Posted March 3, 2023 Author Posted March 3, 2023 😂 Do I need to fill the bullet holes or just let them be skimmed over? i think the parcel is a lamp post but is a dodgy shape!
markc Posted March 3, 2023 Posted March 3, 2023 1 hour ago, Dan1983 said: 😂 Do I need to fill the bullet holes or just let them be skimmed over? i think the parcel is a lamp post but is a dodgy shape! The skim will sort the screw craters 1
SteamyTea Posted March 4, 2023 Posted March 4, 2023 20 hours ago, markc said: Well done, not enough bullet holes 2
Pocster Posted March 4, 2023 Posted March 4, 2023 3 hours ago, pocster said: Suck on this humans Before you all bitch …  300 centres because plasterboard is only 9.5mm . Short boards as I can’t get full boards down my temporary staircase . So noggins at joins . Timbers deliberately left visible above ceiling line so I can a) fix any ha / electrics to them b) no need to “ hunt the timber “ when I need a wall fixing .  So there ! 3
