I have run out of our engineered oak tongue and groove flooring boards, but have managed to get away with it by leaving a gap in the floor which will be covered by IKEA carcasses. The gap is 3.5m long, 39cm wide and 15mm deep.
i need to fill that gap with something to level the floor, such that when the carcasses go on top they have a level surface to sit on. Only sheet material I can find locally in stock for immediate pickup that is 15mm thick is OSB.
Will OSB take the weight of wardrobes (the big ones, 236cm tall), each weighing about 38kg without clothes or inserted pax shelves and other accessories (and there will be 5 of them). Plus the weight of clothes, shelves, rails, drawers etc, and everything could be quite heavy. Or will it eventually get compressed?
You need to work out the area that the feet it sits on and then the total mass.
Convert to MPa (Mega Pascals) then see what the compression strength of OSB is (I am sure a bit of googling will reveal it).
Then wish you had a bit more oak.
Higher quality ply wood may work i.e. marine or birch faced.
https://www.researchgate.net/figure/Performance-of-OSB-in-Compression_tbl1_319095057
Stress-strainconstitutiverelationofOSBunderaxialloadingAnexperimentalinvestigation.pdf
Edited by SteamyTea
3 minutes ago, joe90 said:
Have you got any off cuts to put under the parts of the wardrobes that rest on the floor.?
No. Annoyingly, I somehow managed to mis-measure the quantity of wood required. I think I must have only added 5% instead of 10%. There must have been some off cuts, but the fitter didn’t keep them.
Other option is buying sheets of MDF in 9mm and 6mm and laying one on top of the other.
Probably your easiest and safety option.
Well not at your house.
I have some oak faced ply left over from my build, not sure what thickness tho!, it only needs to go where the wardrobe “feet” go 🤷‍♂️
I wanted to fill the whole void, to try and mitigate a sound transfer issue we have.   But I’m probably just being neurotic. I’m very good at that.
No I understand that. As OSB is full of resin I can’t imagine it will “crush” much at all.
It is a bit late at night to go out into the shed, but if I remember in the morning, and can find a bit of OSB, I shall pop it in the vice and see what happens.
Edited by SteamyTea
  • Like 2
Been hunting around the shed and I cannot find any OSB, except what is lining the shed, and I am not going to cut that up.
So someone else will have to see if OSB crushed more than plywood.
Buy some 18mm ply and cut some squares / rounds to sit under the cabinet feet. Drill 3mm recesses in each with a spade bit. Give a good coat of pu varnish.
Immovable 15mm packs.
7 minutes ago, Marvin said:
check the weight of a sheet of both and compare
How does that tell you the compression strength?
There may be a casual correlation between compression strength and density, but timber is a strange beast as the Young's Modulus, which is what is important here, is orientation dependant.
In that case I would expect the OSB to have a better compression strength due to the mixed grain and the impurities, like bits of metal, found in it.
Edited by Marvin
spelling error
Yes.
I have some 22mm OSB that has been outside for 4+(?) years supporting a pile of concrete blocks (set up on 2 by 4 bearers) : the surface is delaminating a bit, thats all.
PS no additional water-repellent covering - just bare OSB.
Edited by ToughButterCup
Does the flooring have underlay, if so the compression of the flooring element will probably greater than the OSB.
You mention PAX wardrobes ? They have two adjustable feet at the front, there may be some play in those to take up slack.
We had oak flooring, with underlay,  on top of Egger flooring board, our wardrobe fitter removed oak flooring for the support so it would not "sag" later.
These were not PAX, but on legs like kitchen cabinets and then a plinth section that could be scribed in to final size.
How about finding a similar flooring product, perhaps a bargain remnant, and running it the other direction, ie as if you had always meant it?
Or use ceramic tiles. That may look eccentric, but at least deliberate.
We had some off cuts of 18mm MDF, so are going to use those. It's too thick for the depth of the hole, which is about 15mm, but with the adjustable legs on the pax wardrobes, we should be okay. I expect the MDF will compress a bit (these are 75cm wide by 236cm high wardrobes, with an additional 40cm high unit placed on top, and filled with lots of clothes).
