DorsetEndHouse Posted January 14, 2023 Posted January 14, 2023 Morning all, We're scratching our heads and unsure which way to turn when it comes to extractor induction hobs. We would like a large hob with built in extractor, not the pop up type, and like the look of Bora/Novy/Miele/Elica - grateful for any real life experiences recommendations please? Thanks in advance
Bramco Posted January 14, 2023 Posted January 14, 2023 We've just installed an IKEA kitchen with one of their induction hobs - it's our first induction hob but can't fault it, on boost it boils water incredibly quickly. The only down side was that we had to pass on our Spring saucepans that we'd had for 40 years to our son as they wouldn't work - not enough steel in the base, they were a steel/copper sandwich construction. Finding new pans turned out to be a pain. I think IKEA do 2 widths of hobs, one standard sized and the other 200mm wider. When we bought ours, the only option was the wider one and I think we would have gone for this one if there had been the choice. Simon 1
Russdl Posted January 14, 2023 Posted January 14, 2023 We’ve got a Miele. No complaints. Fan is noisy on boost but does what it was designed to do effectively. On one occasion it identified two small pans as one large one and automatically turned both cooking zones on instead of just the one zone I wanted. I found out the painful way that the empty pan on the rear zone was getting very very hot. Very easy to clean, no protrusions. All the grease filter bits go in the dishwasher, charcoal filter gets recharged in the oven. Whatever you go for (if you want to keep it looking good) get a hob protector from Lakeland - ours still looks mint. 2
Blooda Posted February 15, 2023 Posted February 15, 2023 We have the Elica Switch recirculating, and its great. If you haven't decided yet and you are close enough to Birmingham, a day at KBB show is worth it. kbb Birmingham | Europe's Leading KBB Event Ensure you lock up your wallet, there is a lot of high end stuff there, as well as the middle and lower ranges. 1
Pocster Posted February 15, 2023 Posted February 15, 2023 2 hours ago, Blooda said: We have the Elica Switch recirculating, and its great. If you haven't decided yet and you are close enough to Birmingham, a day at KBB show is worth it. kbb Birmingham | Europe's Leading KBB Event Ensure you lock up your wallet, there is a lot of high end stuff there, as well as the middle and lower ranges. I have the same hob . It is amazingly good .
MikeGrahamT21 Posted February 15, 2023 Posted February 15, 2023 Induction hobs in general are great, had mine for years and you can really tell the difference even in the air over cooking on gas. The built in extractors look good in practice, the ones i've seen in showrooms look slightly ugly (but then i guess beauty is in the eye of the beholder right?), but i think my main concern would be my classic trick of spilling something, pan boiling over, or dropping food down the holes. No idea if thats even an issue or not?
Conor Posted February 15, 2023 Posted February 15, 2023 Another Elica owner here. Fantastic piece of kit. Have it in white and looks class I've yet to figure out the temperature hold function (e.g 42c so you can souvette or 90c for slow cooking) and it's not in the manual. Other than that, 10/10.
RobLe Posted February 15, 2023 Posted February 15, 2023 We have induction, it's great! Used to have gas, wouldn't go back. The only thing gas does better, I have been told, is heating the whole of the underside of a curved bottom wok, rather than just the base. Allegedly makes a difference with aggressive wok frying. As an aside. we got a particulate detector a while back - the who says the yearly mean should be less than 5ug/m^3 of 2.5um particulates. Burnt toast, frying aggressively, can both send it crazy, giving >1000ug/m^3. Gently frying with oil, normal toast, boiling etc, it's safely below 5.
Pocster Posted February 15, 2023 Posted February 15, 2023 46 minutes ago, MikeGrahamT21 said: Induction hobs in general are great, had mine for years and you can really tell the difference even in the air over cooking on gas. The built in extractors look good in practice, the ones i've seen in showrooms look slightly ugly (but then i guess beauty is in the eye of the beholder right?), but i think my main concern would be my classic trick of spilling something, pan boiling over, or dropping food down the holes. No idea if thats even an issue or not? The elicia has a collection bin for liquids in the extractor exactly for this . There’s a drain tap underneath or you can remove the bin . It’s all easy to do . 1 1
Bramco Posted February 15, 2023 Posted February 15, 2023 36 minutes ago, pocster said: The elicia has a collection bin for liquids in the extractor exactly for this . There’s a drain tap underneath or you can remove the bin . It’s all easy to do . Same with the IKEA one - you could have 4 IKEA ones in your kitchen for the price of the Elica! Bramco 1
Pocster Posted February 15, 2023 Posted February 15, 2023 5 minutes ago, Bramco said: Same with the IKEA one - you could have 4 IKEA ones in your kitchen for the price of the Elica! Bramco Elicia =status 1
Blooda Posted February 15, 2023 Posted February 15, 2023 5 minutes ago, Conor said: Another Elica owner here. Fantastic piece of kit. Have it in white and looks class I've yet to figure out the temperature hold function (e.g 42c so you can souvette or 90c for slow cooking) and it's not in the manual. Other than that, 10/10. If you find out please let me know. But we maybe going to KBB and Elica are there so if we do I will find out from the rep. 1 hour ago, MikeGrahamT21 said: but i think my main concern would be my classic trick of spilling something, pan boiling over, or dropping food down the holes. No idea if thats even an issue or not? With minor spillages the Elica seems evaporate them in the filter, for major spillages there is a sump and a sump plug you can access from the draw below [assuming you haven't blocked up access fully]. 1
MikeGrahamT21 Posted February 15, 2023 Posted February 15, 2023 That answers that concern, thank you!
Bramco Posted February 15, 2023 Posted February 15, 2023 3 hours ago, pocster said: Elicia =status Everyone to their own - it's a weird world where 4x the price means status. I'll bet you're a B&O status person as well.... 1
Pocster Posted February 15, 2023 Posted February 15, 2023 2 minutes ago, Bramco said: Everyone to their own - it's a weird world where 4x the price means status. I'll bet you're a B&O status person as well.... I know . Couldn’t see that ikea do an extraction induction hob …
Pocster Posted February 15, 2023 Posted February 15, 2023 Just now, SteamyTea said: I open a window. Tricky to do in an underground house you moron 😘
SteamyTea Posted February 15, 2023 Posted February 15, 2023 2 minutes ago, pocster said: Tricky to do in an underground house you moron 😘 You let your prisoners cook? Whoops, meant Austrian guests.
Onoff Posted February 15, 2023 Posted February 15, 2023 29 minutes ago, pocster said: Tricky to do in an underground house you moron 😘 Well said, he should know the cooking smells escape via the leaky walk on glazing!
Pocster Posted February 15, 2023 Posted February 15, 2023 12 minutes ago, Onoff said: Well said, he should know the cooking smells escape via the leaky walk on glazing! 🤐
Adam2 Posted February 15, 2023 Posted February 15, 2023 We've a Bora - yes not "cheap" but it is great, extract works well. Fitted very nicely so is flush with the worktop. Overall very happy with that
Bramco Posted February 16, 2023 Posted February 16, 2023 14 hours ago, pocster said: Couldn’t see that ikea do an extraction induction hob … Two! 60cm -> https://www.ikea.com/gb/en/p/foerdelaktig-induction-hob-integrated-extractor-ikea-500-black-50534854/ 80cm -> https://www.ikea.com/gb/en/p/foerdelaktig-induction-hob-integrated-extractor-ikea-700-black-90534852/ But prices have gone up since we bought ours last year - now a 1/3 of the Elica.... 1
Pocster Posted February 16, 2023 Posted February 16, 2023 32 minutes ago, Bramco said: Two! 60cm -> https://www.ikea.com/gb/en/p/foerdelaktig-induction-hob-integrated-extractor-ikea-500-black-50534854/ 80cm -> https://www.ikea.com/gb/en/p/foerdelaktig-induction-hob-integrated-extractor-ikea-700-black-90534852/ But prices have gone up since we bought ours last year - now a 1/3 of the Elica.... Fair play . Though when I got my elicia the only other extracting hob at the time was the bora .
Kelvin Posted February 16, 2023 Posted February 16, 2023 Ours in the one ‘bargain’ I’ve managed to secure as it was an over order by the kitchen supplier. A Neff N70. Otherwise we’d probably have gone with the Ikea.
Thorfun Posted February 16, 2023 Posted February 16, 2023 26 minutes ago, Kelvin said: Ours in the one ‘bargain’ I’ve managed to secure as it was an over order by the kitchen supplier. A Neff N70. Otherwise we’d probably have gone with the Ikea. and how is the Neff? obviously you can't compare it to the Ikea/Bora/a.n.other but is the Neff good? 1
