I've a spare 203x203mm X 46 UB (incorrect order) that I can potentially utilise in my balcony.
Is it feasible to cleanly cut such a beam in half using a 10" grinder?! Guessing the steel is a good 6-7mm thick.
To get a neat cut I would be looking to rig something up to make a "table saw" out of the grinder with a fence, so you can slowly feed the beam through to get a neat cut.
Or if you have a table saw, see if you can get a grinding disc to fit it?
I do have a diamon blade for the table saw, but the beam is 4.5m long so not easy to move around. And I think the bore is too big for big for an oxide blade.
I'll go with the grinder, cut needs to be reasonably flat but not perfect, I'll be welding a plate to the ends. Might get an extra pack of blades tho!
It's actually a UC 😂
Flanges are 11mm thick and the web 7.3mm.
9" grinder with 2mm discs all day long.
  • 2 weeks later...
On 26/12/2022 at 08:51, SteamyTea said:
An angle grinder is the second best tool you can have.
Every household should have one.
I had a wired one for a long time. Then partnered it with a ryobi battery one - have been pleasantly surprised how good it is. Chews through batteries but that's to be expected.
  • 1 month later...
What's the first?
Combi drill?
Hammer?
Maybe we could do a desert islands discs of tools 🙂
I haven't got an angle grinder in my tool box yet... Sort of used it as a yardstick for 'out of my competency area' and always been too scared. How would it change my life? Now I want one!
  • Haha 1
