SWMBO has more plans for me !
Outdoor sink ( hot and cold feed )
I was thinking maybe a Belfast type sink ? . Need to wall mount it I.e it’s free standing . Any suggestions???
I had a Belfast sink under the outside tap (no hot!) in my last house, very useful I found. Got it for £10 off eBay or Facebook. Put mine on brick pillars but you can get cast iron wall brackets.
Was planning to hep20 to the sink . But Hep2o can’t be exposed outside can it ?
Also the taps will have to be wall mounted - that means my pipework will be visible !!!! . That’s probably something I don’t want unless it looks unnaturally neat ( which it won’t )
1 minute ago, Russell griffiths said:
Build it like an outdoor bar, granite top with top mount sink, then that gives you an area for taps and a cupboard underneath to hide the waste.
Was thinking that . But it’s for SWMBO so therefore minimal cost ! 😁🍺🍺🍺
  • Sad 1
Got to make a Gordon Ramsey outdoor BBQ / kitchenette for my current clients so am about to bridge this myself. The Belfast sink is an option but can look a bit ‘clunky’, but I may dress one in with brisk piers as suggested, and tile ( mosaic ) to make it look tres bien.
Will likely make a deck to one side for a tap like this….
https://www.victorianplumbing.co.uk/arezzo-matt-black-industrial-style-basin-mixer-tap?campaign=googlebase&gclid=EAIaIQobChMI36_3xPD9-AIVh6ztCh05Kg5REAQYASABEgJRa_D_BwE&gclsrc=aw.ds
Can be swung away to the side to fill a bucket etc or wash your feet.
1 hour ago, pocster said:
Any suggestions???
Yeah, don't use solvent weld, we know how that ends.
Perhaps free standing taps ? . I can’t plumb through the 1 metre thick concrete wall I made !
I think maybe a better option - also no pipework visible .
As Hep2o isn’t uv resistant just lag hot and cold ??
Can you find a piece of granite that will allow a standard tap to be fitted behind the sink, with a hole like a standard worktop mount.
I could do that for sure . Just got to find the granite ! 🙄😁
5 minutes ago, TonyT said:
Too small
even a cheap stainless steel sink would be ok if the rest was blinged up
Yeah but it might be ok for just hand washing . Not sure how the taps plumb ( based on the photo ) . Where’s the feeds ? ; all jammed up under the basin ??
Look out for second hand lengths of granite / quartz worktop with a sink cutout on gumtree / Freecycle. That's what we did, got it all for free Inc the sink. Just need a tap. Plan to mount on a couple brick piers. Have the water supply sorted and just going to use a rainwater gully for the waste. Don't forget to insulate all your pipework, either that or draindown over winter.
46 minutes ago, Russell griffiths said:
Is there an echo in here. 🤦🏻‍♂️
To do with the resonant frequency of the quartz maybe?
