Sounds like the self cleaning coffee machine I bought. Makes great coffee but I still have to dismantle it every week for a thorough clean...
Oregon PowerSharp bar ... has a reverse bevel chain so the top of the tooth is sharpened not the curved cut as per a normal chain.
Stick the stone on it and rev the nuts off it whilst pressing onto a sturdy log and a shower of sparks later you have a sharp chain ...
They fit well onto Stihl saws but Husqvarna is a challenge. See them on the low end stuff in the sheds now as it means Joe Public can use a sharp chain to hack his own leg off rather than spend money on PPE and a sharpening system ...
Hmmm. It's May not April.  And, of course it'll work for rip saw chains as well as cross cut.
Anyway, I like sharpening my saw chains. Helps me avoid kitchen cleaning up duty...:$
One feels slightly heckled :D.
Last time I asked this question I skirted around the need to buy a chainsaw, however I now have a couple of reasonably sized but not large trees that need a trim.
B&Q have discontinued this option, but I see that the Oregan Powersharp system is available on a 2000W Qualqast (!) corded chainsaw from Argos (link) at £79.95. That looks like a good deal if an Electric Saw is suitable, given that the Powersharp system to retrofit costs approx £60. Looks badge engineered in exactly the same way as the B&Q.
Chain speed 13.5 m/s.
F
Edited by Ferdinand
I got this chainsaw as it was the cheapest and its one of the best buys I've ever got. http://www.ie.screwfix.com/titan-ttb355chn-40-5cm-2000w-electric-chainsaw-230v.html
I'm amazed it's still going with all I've thrown at it. It's a bad photo but it's cut trees which were 18 inch in diameter into logs I then split and have drying in the shed. I bought a cheap set of files to try and sharpen the chain a few weeks ago and now when I look at the cost of a new chain I just can't be bothered to spend the time sharpening each link and will just get a new chain. It's more than paid for itself.
I bought the same and even the file as well. Have had  to sharpen it twice and to be honest it's no where near as sharp as it was new so I just bought the chain to match from screwfix, life's to short to be sharpening chains each time when a new one is so cheap.
you lazy b*stards xD
theres 90 odd teeth on my chains and it still only takes a few minutes to sharpen them, even quicker with a dremel attachment.
Yep guilty as charged. I only use mine very rarely now as I have all my trees logged up. Maybe 5 times a year it would get used. If it's for some one else then I tell them the chain is blunt but buy me this one, points to image on phone from sfix, and you can use away.
58 minutes ago, Vijay said:
Look out in Lidl, those type of sharpeners were around  £20
.... I like my chains ... xD
I buy decent chains, and I make them last ..! Oregon are good but I've swapped recently and I'm quite impressed.
I also use TC rough service chains too for "unknown" trees and you can't sharpen those with a file ..!
All told I've probably got £1500 worth of kit inc PPE so it's horses for courses ...
