ProDave Posted March 9, 2022 Posted March 9, 2022 20 minutes ago, Marvin said: As long as they take the metal bits out before using the microwave. (Assuming metal racking etc is still used) Ours you can leave the metal side runners in while using it as a microwave but you must remove the metal shelves.
Roundtuit Posted March 9, 2022 Posted March 9, 2022 2 hours ago, ProDave said: Ours you can leave the metal side runners in while using it as a microwave but you must remove the metal shelves. Ours is a Neff combi (that sits alongside a fan oven), and metal shelves can stay in on the microwave setting. It does 95% of its work as a microwave for reheating and defrosting etc, plus occasional duties as a 'hot air' oven for roasting when I need a lower temp for a joint of meat than the main oven for the roast potatoes. I might have to rethink that practice under the current energy situation however...
Ralph Posted March 10, 2022 Posted March 10, 2022 17 hours ago, ProDave said: Or your kitchen designer just supplies a unit with the correct size gaps and correct size cupboards above and below. If you want them stacked that works well and looks good. We are having a side by side layout. 1
Simplysimon Posted March 10, 2022 Posted March 10, 2022 21 hours ago, Roundtuit said: rethink that practice under the current energy situation however... that's one thing i really like about the air fryer, it's quick, cooks a small chicken in 40 mins
ProDave Posted March 10, 2022 Posted March 10, 2022 21 hours ago, Roundtuit said: plus occasional duties as a 'hot air' oven for roasting when I need a lower temp for a joint of meat than the main oven for the roast potatoes. I might have to rethink that practice under the current energy situation however... A low temperature joint usually cooks for longer, we just put the roast tatties in for longer in the same oven.
MJNewton Posted March 11, 2022 Posted March 11, 2022 On 09/03/2022 at 12:00, ProDave said: But the turntable compensates for the fact the microwave energy is not even inside the oven, so without it you have to keep stopping and stirring what you are heating to avoid cold spots or local boiling. You only have to do that with a turntable microwave if you've removed the turntable. So-called 'flatbed' microwaves that dispense with the turntable altogether have a rotating antenna instead.
Adsibob Posted January 2, 2025 Posted January 2, 2025 On 09/03/2022 at 11:46, CotswoldDoItUpper said: We have a Samsung chef collection combi thing. Would you mind posting the model name please?
Onoff Posted January 2, 2025 Posted January 2, 2025 We've had a 32L Sanyo combi for years, 20 in fact and it's still going. Just needed a new capacitor and waveguide cover recently. The thing with the combis, is because of the mesh grills for the grill and oven, steam can condensate and rot them out. I've to do some internal "bodywork" on ours. The old Sanyos were built like tanks with seperate grill and oven elements. Panasonic I think bought Sanyo and some might say dumbed their offerings down. They have I think one element for oven and grill and it gets directed by fans to wherever. If we do get a replacement I'll be looking at the Sharp R959SLM 900W 40L. Still has seperate elements I believe.
Adsibob Posted January 2, 2025 Posted January 2, 2025 6 minutes ago, Onoff said: If we do get a replacement I'll be looking at the Sharp R959SLM 900W 40L. Still has seperate elements I believe. Thanks @Onoff. I had a look at your recommendation and alas I need an integrated one (and an integrated one that is black) so this won't work for us.
