Can I please ask is Hammerite no 1 anti rust beater OK to use on an old steel beam which has signs of rust?
It's still sound and structural engineer said just sand and treat with galvanoid. I can't find galvanoid so just thought I'd get what I could from Screwfix
 Thank you
My wife runs a powder coating business so gets shed loads of stuff galvanised. Havnt used the spray stuff but typically the steel has to be super clean for it to take properly otherwise it peels. They use acid baths to clean new steel and remove any impurities so old steel will be tough to clean for it to work properly.
I use hammerite a lot, I find it seals rusty stuff well if applied thick enough (as long as flakey stuff removed), however the new water based stuff is rubbish in my opinion .
Good old fashioned bitumen paint, so long as you don't mind the finish look. Like 'proper' creosote, water based stuff ain't as good unless you really really prep the surface
We had four beams to reuse on the front of the garage
We used a silver paint purchased from a local boat yard For painting the underside of boats
Cheap as chips No rust five years on
Any idea what paint this was ?
I can’t remember the brand
But it did say bilge and hull paint on the tin
Bought from preston marina shop
My wife picked it up
The chap said normally lasts five years submerged
Basics are.
Remove rust, or remove all loose and convert to something else, with rust converter.
Hamerite isn't that good any more as mentioned.
A galvanizing spray with give the metal a sacrificial costing which will deplete prior to rust coming back.  But sprays go on very thin.  A brush zinc paint like the architect mentioned with give a longer lasting protection.
If you are ok with a dull silver, something like a Rustoleom galvanizing spray, several good coats.  If you want a different colour follow the painting instructions on the tin.  You need a coating that is around 99% zinc.
Or a zinc phosphate based epoxy primer as it bonds well, expensive but good.
 Thank you
Galvafroid , not galvonoid, brilliant stuff, haven’t bought or needed any in years so not sure if you can still get it.
Edited by markc
+1 for the galvafroid, use it on my land rover. Next best thing to hot-dipping
2 minutes ago, SteamyTea said:
That is for curing piles with an electrode.
Haha, can’t knock a bit of galvanic action
I am afraid a disagree . Yes the new water based stuff is pants but the old stuff is still as good as was and I use it a lot on outdoor tractor stuff. I will give this galvafroid a go as well ?
That's a confusing response.  You disagree that hamerite in isn't as good as it was, then go on to say the new stuff is pants.
The old stuff will be good - its not the new stuff.  You can't buy it any more unless it's old stock.
No, I said the new water based stuff was crap (IMO) but the old stuff is very good (and freely available).
What ever.  I really wouldn't bother, there are better products mentioned above.  Never really had much success with hamerite, new or old.
