Not sure of the best way to deal with this.
The suspended system relies on tracks around the perimeter and then structs crossing it to form a grid.
I've got skylights and a stairwell to contend with. I need to construct somehow a 'structure' around these so the suspended ceiling trim can fix.
Any suggestions welcome
If you are going to plasterboard it you will need to allow for the supporting bar 50 mil
We normally allow min of 60 mil void
Set your perimeter track at 80 mil to be safe
28 minutes ago, Thorfun said:
CT1? seems to fix most issues for you.
I don't know. I think a timber structure then perhaps with plasterboard for the recess will be quite heavy.
I don't like doing neat timber work.......
I'd treat skylight like a regular wall/window reveal. Eg plasterboard fixed to battens (or dot and dab?). Mesh reinforcement on the corners.
Edit: I suppose some batten off cuts could be used around the edge of the opening to provide blocks to screw plasterboard to.
Edited by Temp
Just now, Onoff said:
Oh praise be there is a God!
I intend to keep them; even with suspend ceiling going in. Took me many years to grow those babies.
Serious hat on now...
How about builders band straps fixed to the inside of the skylight upstand. You could then timber frame around/below the skylight at whatever level.
What about metal stud wall channel shot fired up into the slab?
What's a builders band? is it like LittleMix? ( I love them, though not the fat one )
What would look good is a viewing panel set in the suspended ceiling, maybe some back lighting and you watch them grow over time.
And some glazing yes?. Perhaps I can watch your pair grow also?
1 minute ago, pocster said:
not the fat one
Is that Belle, aka Little Mixer?
(Round and orange etc)
Edited by Onoff
Too big for me. Would hurt my back. The other 3 all at once - be ok though.
43 minutes ago, Onoff said:
I'd deffo be using Gypframe metal stud for this. Much more stable I reckon than timber.
+1 to this - shot fired into the concrete and it’s going nowhere.
@pocster how are you insulating the insides of the skylights ..? Stop cold bridging.
This just the metal stud I use for walling ?
Was going to use aerogel for insulating
Actually . Wouldn't it be better/easier to fix some straight 'L' angled steel from the top of the recess straight down vertically? i.e. say a length per corner?
Have to be careful with thickness though as got to aerogel/board/skim.
If this is a sensible idea - then what steel for this??? ( too much thinking today as it's Friday )
Edited by pocster
On 10/02/2022 at 15:08, pocster said:
Can't you just fix four lengths of aluminium angle in the corners hanging down whatever length you want and attach your ceiling struts to them.
