tonyshouse Posted October 2, 2021 Share Posted October 2, 2021 Triggered an idea for an extension of that detail to protect the non-joisted part of the first floor void. In addition to polythene or similar to replace joist caps, drape another length of membrane across the top of the wall from one joist to its neighbour. Overhanging the inner leaf on both faces. Then after ceiling board and floor board installed, pull the overhangs in and tape to the respective boards, as well as to the airtight membrane or tape at the respective wall junctions. Treating the entire floor void as a quasi-joist. For those who are constrained to have no more than plasterboard on dabs. The tonytray does all round 1 Link to comment Share on other sites More sharing options...
Faz Posted October 2, 2021 Share Posted October 2, 2021 On 30/09/2021 at 23:27, WWilts said: Inner leaf of external cavity wall. Mortar mix 5:1, blocks are 7N aircrete. Doesn't look too good but that's a layperson view. Specified: LABC warranty standards. If not passable, what is the way to remedy work already done? Just pointing enough? And how DO brickies get mortar in perpends? Not nice mate - hopefully this crew aren't proposing to do any facing brick for you? This is my internal block if you want to compare. 2 Link to comment Share on other sites More sharing options...
PeterW Posted October 2, 2021 Share Posted October 2, 2021 On 30/09/2021 at 23:27, WWilts said: Inner leaf of external cavity wall. Mortar mix 5:1, blocks are 7N aircrete. Doesn't look too good but that's a layperson view. Specified: LABC warranty standards. If not passable, what is the way to remedy work already done? Just pointing enough? And how DO brickies get mortar in perpends? Are they Ytong 650’s as they are longer than a normal block. If that’s inside face then it’s crap - ask for it to be pointed and full perps as that’s about as sealed as a seive… 1 Link to comment Share on other sites More sharing options...
Lorenz Posted October 2, 2021 Share Posted October 2, 2021 But it should be thin joint.... this looks like an apprentice has had a go? 1 Link to comment Share on other sites More sharing options...
WWilts Posted October 2, 2021 Author Share Posted October 2, 2021 2 hours ago, PeterW said: If that’s inside face External face. Still worth asking for pointing (perpends)? PS Celcon plus 630mm long Link to comment Share on other sites More sharing options...
PeterW Posted October 3, 2021 Share Posted October 3, 2021 So that’s the face into the cavity ..?? Link to comment Share on other sites More sharing options...
Brickie Posted October 3, 2021 Share Posted October 3, 2021 (edited) Just pull them on it & ask for the joints to be kept full in future. Let’s bear in mind that everyone can have a bad day people,before we erect the Gallows,eh? @Faz your lads want to bring the insulation right up to the reveals-bit short in places there. Edited October 3, 2021 by Brickie Typoo 1 Link to comment Share on other sites More sharing options...
Faz Posted October 3, 2021 Share Posted October 3, 2021 ? They did fill it when they topped out just before the closers went on. Link to comment Share on other sites More sharing options...
Dave Jones Posted October 3, 2021 Share Posted October 3, 2021 17 hours ago, Faz said: Not nice mate - hopefully this crew aren't proposing to do any facing brick for you? This is my internal block if you want to compare. subframes for all the structural openings speed up brickes and help with accuracy. Very cheap and you have to fit cav closers at some point anyway. Link to comment Share on other sites More sharing options...
Pocster Posted October 3, 2021 Share Posted October 3, 2021 17 hours ago, Faz said: Not nice mate - hopefully this crew aren't proposing to do any facing brick for you? This is my internal block if you want to compare. Nearly as good as mine ? 1 Link to comment Share on other sites More sharing options...
Onoff Posted October 3, 2021 Share Posted October 3, 2021 I think this was my second ever attempt at blockwork. I used a Bricky tool and all joints were full filled. I then pointed with a mortar gun and brushed level. I knew nothing about air tightness then but imagine it helped. 2 Link to comment Share on other sites More sharing options...
saveasteading Posted October 3, 2021 Share Posted October 3, 2021 20 hours ago, Faz said: This is my internal block if you want to compare. Very smart, but for a perfect job should not the cut blocks be away from the opening jamb, , and only full or half blocks used there? ie small cuts are within the main area, as you do have on the alternate courses. Link to comment Share on other sites More sharing options...
Dave Jones Posted October 3, 2021 Share Posted October 3, 2021 12 minutes ago, saveasteading said: Very smart, but for a perfect job should not the cut blocks be away from the opening jamb, , and only full or half blocks used there? ie small cuts are within the main area, as you do have on the alternate courses. they will be fine to fix a frame to. Link to comment Share on other sites More sharing options...
Faz Posted October 3, 2021 Share Posted October 3, 2021 14 minutes ago, saveasteading said: Very smart, but for a perfect job should not the cut blocks be away from the opening jamb, , and only full or half blocks used there? ie small cuts are within the main area, as you do have on the alternate courses. They are not cuts - they return into the garden room. 1 Link to comment Share on other sites More sharing options...
saveasteading Posted October 3, 2021 Share Posted October 3, 2021 2 minutes ago, Faz said: They are not cuts - they return into the garden room Thanks, didn't think of that! Perfect then. Link to comment Share on other sites More sharing options...
Dave Jones Posted October 3, 2021 Share Posted October 3, 2021 is that snow on the ground ? Link to comment Share on other sites More sharing options...
Faz Posted October 3, 2021 Share Posted October 3, 2021 Afraid so - that would be February time. This is what that room looks like now - you can see the return detail here too. Link to comment Share on other sites More sharing options...
WWilts Posted October 3, 2021 Author Share Posted October 3, 2021 14 hours ago, PeterW said: So that’s the face into the cavity ..?? Yes Link to comment Share on other sites More sharing options...
WWilts Posted October 3, 2021 Author Share Posted October 3, 2021 12 hours ago, Brickie said: Just pull them on it & ask for the joints to be kept full in future. Let’s bear in mind that everyone can have a bad day Makes sense. Overall good co-operation, good service. Don't want to be over-fussy unless it makes a real difference. Link to comment Share on other sites More sharing options...
WWilts Posted October 3, 2021 Author Share Posted October 3, 2021 Part of me has the idea that the cavity face of the inner leaf is better off with a bit of air as additional insulation in place of mortar. As long as the internal face of the inner leaf is air tight. Concave joints best for that? Perhaps that idea is nonsense. Link to comment Share on other sites More sharing options...
Brickie Posted October 4, 2021 Share Posted October 4, 2021 Are they approachable,would you say? Link to comment Share on other sites More sharing options...
Dave Jones Posted October 4, 2021 Share Posted October 4, 2021 kitchen in before plaster, brave! Link to comment Share on other sites More sharing options...
tonyshouse Posted October 4, 2021 Share Posted October 4, 2021 Insane, very draughty 3 Link to comment Share on other sites More sharing options...
WWilts Posted October 4, 2021 Author Share Posted October 4, 2021 2 hours ago, Brickie said: Are they approachable,would you say? Yes, very Link to comment Share on other sites More sharing options...
markc Posted October 4, 2021 Share Posted October 4, 2021 10 minutes ago, WWilts said: Yes, very In that case, count your blessings and speak to them, make it a joke … you may seem a bit fussy but it’s your home and you would like …xyz! we are all human, we all have good and bad days and we all want our days to go smoothly. to quote the Advert … It’s Good to Talk. 2 Link to comment Share on other sites More sharing options...
