Weebles Posted June 17, 2018 Posted June 17, 2018 Well done - you must have been flat out over the last 2 weeks. Enjoy a day off now!
dogman Posted June 18, 2018 Author Posted June 18, 2018 Thank you for all the replies. Some highlights of the first few days. 1. Hot water is via a Sunamp +expansion.. So happy with this. I know its summer and we have 4.2KW of solar but the last few days have not been the best for sun and i was worried we would need to heat using full priced electricity. Its been full by lunch time and that is after a full bath and two showers a day plus the incidental sink use. Flow is excellent although not really checked the what if situations (turning other taps on etc.) 2. Ventaxia MVHR. Keep checking to see if it is on as so quiet. House is kept at 21deg although we need to see how it works this week as its hotter outside. Summer bypass is only set to cut in on temp differential not on a timed purge The only issue we have is the low 25mm simpson shower tray. The flow is so good on the showers that when its on full you get a slight overflow out the door. The drain is the standard one connected to 50mm
vivienz Posted June 18, 2018 Posted June 18, 2018 Belated congratulations from me, too. We're going down a similar build/energy system route, so it's great to hear a positive real-life report after a year of living it.
dogman Posted September 9, 2018 Author Posted September 9, 2018 We have now been in the house for three months and last week received the completion certificate Vat claim will be submitted this week as the "wife" has been compiling the receipts as we progressed. Still need to finish some rooms and have not got any carpets / curtains etc but it is not spoiling the pleasure of living in the house. There is only one thing so far i wish i had done. Fit a proper externally vented cooker extractor. I know it goes against all the air tightness etc but during the recent hot weather cooking indoors was not a pleasure as it really heated the house up. We have found that if you keep it cool it stays cool but once it warmed up cooling it down took a lot of effort. Solved it by using the BBQ outside most days Things I am thinking about are some sort of energy monitoring. We have 4.2kw of panels and produce far more electricity than we use at this time of year. If I can work out when and how much we produce it will help decide if I need some sort of storage solution, or in winter move to economy 7/10.
Dreadnaught Posted September 9, 2018 Posted September 9, 2018 (edited) On 09/09/2018 at 13:28, dogman said: There is only one thing so far i wish i had done. Fit a proper externally vented cooker extractor. I know it goes against all the air tightness etc but during the recent hot weather cooking indoors was not a pleasure as it really heated the house up. We have found that if you keep it cool it stays cool but once it warmed up cooling it down took a lot of effort. Solved it by using the BBQ outside most days Expand As posted here, a recent scientific paper also suggests that MVHR alone is insufficient to clear the pollution that cooking generates. A further reason for a externally-vented cooker extractor perhaps. Edited September 9, 2018 by Dreadnaught
Nic Posted November 18, 2024 Posted November 18, 2024 On 11/10/2017 at 18:37, dogman said: The render is finished Took a lot longer than they quoted but it has come out better than expected. The fake arch heads ready for render Base coat Finished just need to tidy up The colour will lighten to a fawn and it was getting dark so it is not that pink Expand hi I’d be interested to know how this render is holding up all these years later … of if you are still on the forum to reply 1
