Hi all,
Came back to the house today to see the builders had chased some of the pipework into the wall. I'm a bit concerned affect this has on the structural integrity of the wall.  Am I being too cautious?
2 hours ago, Water said:
Hi all,
It was quite common once over
Not now Even the gas pipes are left on the surface and enclosed with drywall adhesive
We retrospectively cut doorways into load besting walls, so a bit of chasing will be of zero detriment. Electricians will do that 4 times or more in the same wall before breakfast.
Zero BCO or structural issues / concerns have ever been raised in the last 25+ years of doing this exact work.
Time to put more tonic in with the gin ;) :)
48 minutes ago, Water said:
try again
I personally wouldn't have gone that route, I would have just surface mounted the pipes and boxed them in. Vertical chases are one thing, I wouldn't be too happy about a horizontal chase like that. How deep is it? Looks like a 32mm pipe can easily fit in it? I wonder how much brick is left!
Well I guess the block work will have to be replaced. ffs.   Unless I have misunderstood the building regulations.
Edited by Water
Yatzee!
I automatically assumed vertical chases. That's a chunk missing from that wall. :S Sorry, I now agree with your concerns.
Yup. 100% or popped the floors up. At the very most I would have removed just the render and set the waste pipe as far back as possible to reduce the footprint of the boxing in.
Not even sure if backfilling with a stiff cement compo would satisfy here.
Edited by Nickfromwales
Holy Crap! Ive seen some deep horizontal chases pass BCO but never at the bottom and only being short run. that needs sorting
Is it a 4" wall or 9" party wall? (if that would make any difference to what can be chased out) I just can't imagine a builder would do that to a 4" wall and be ok with it
It's a standard cavity wall.
I'm not a structural engineer but if there was only a small piece of the wall removed I wouldn't be so worried. Why oh why is it so hard to find good people.
Anyone know if they can be safely refilled? If a concrete block was refilled with concrete would that be ok? I'm guess it is not that simple.
Think I'd be happier to loose 2”  off the room and create a service void for that lot, or just box it in.
I'd want the blocks/bricks chopping out and replacing, not just bodging in something over the face as a cosmic patch up
Edited by JFDIY
20 hours ago, Water said:
Yeah that was my concern, they blocks are 100 thick but I'll have to get back down there and measure the depth.
Did you get a chance to measure what's been removed/left?
It’s 40mm minimum if a 32mm waste plus the thickness of the fitting has been lost. :/ So ~60mm of brick plus ~15-20mm of cement render & plaster remains. Not going to fall down any time soon, but probably best to confirm this isn’t taking the hop of the roof or chimney etc before ‘accepting’ this compromise.
