I can't help thinking...buy a commercial, metal door and repaint it! Meant to take photos at work of the edge/corner details but this might help. Ours are all interlock seamed:
15 hours ago, joe90 said:
@Tony K find a picture of what you would like, then we will come up with suggestions how it can be made.
In either timber or some sort of metal this kind of thing appeals, though it need not be a swivel door:
Modern Front doors ideas - design trends 2020 — Aluminr- Bespoke Luxury Metal  Door Manufacturers
Edited by Tony K
If timber you could route the slots as seen in a solid door blank and paint, is that copper or bronze?, need to source metal sheet but don’t know how you would treat the edges but could be bonded on with an appropriate adhesive. Handle you would have to source somewhere.
4 hours ago, Tom said:
possibly investigate worktop fabricators?: https://www.stainlesssteelworktopsuk.co.uk/made-to-measure-copper-worktops-sinks-and-drainers/
stick it on it's end, add a few hinges, job done!
That's interesting. I could see what that costs vs the other options.
Another idea I've had is to buy something like this:
https://www.screenwithenvy.co.uk/products/larbre-corten-garden-screen?variant=31461792284715&currency=GBP&utm_medium=product_sync&utm_source=google&utm_content=sag_organic&utm_campaign=sag_organic&cmp_id=11450961827&adg_id=112868478460&kwd=&device=c&gclid=Cj0KCQjws-OEBhCkARIsAPhOkIblkVsPP-kzA9Ij7Yx0-C8vWjBpqH48jWDsFNcavPyhIxqWYGJTzB4aAuUuEALw_wcB
...and pin it to a blank door. If I set it about 10mm from the face of the blank door I could even backlight it in some subtle way.
On 10/05/2021 at 14:06, Tony K said:
I wonder if anyone has any advice on the following:
1. Are they always as expensive as I have found so far (thousands rather than hundreds for a door)?
2. Is there any merit in taking a standard old timber door and seeking to attach sheet material to it, thereby achieving a similar effect?
Thanks
I've recently received an expensive front door which is 2.1m high by 1.2m wide. I'd seriously thought about making it myself but my wife talked me out of it. I'm glad she did. Ours is made with Accoya and is well insulated. I has a steel reinforcement frame, necessary due to its size, plus multi-point locking etc. The door weighs 107kg. It's also manufactured as a door set with inset heavy duty hinges, three at the top, one at the bottom.
Overall, I wouldn't have managed anything even remotely close to this and I do think it takes a lot of skill (and tooling) to produce something like this diy that will last.
I have to admit, entrance doors can be eye watering in price, especially once you factory in things such as LED lighting, electrical locking, finger print scanners, keypad access, numbering, etchings etc. However, I have not come across a proper main entrance door from any of our suppliers that doesn't make that "clunk" sound that makes you smile and feel safe.
Worth the money imho if you have it in your budget.
Well I had my front door and frame made by the same company that made my windows and conservatory. It’s oak, insulated, multi point locking and much cheaper than on line “posh” door suppliers. If not DIY try to find a local wood shop and see what they can do!
We have Gaulfhoffer windows and minor doors but the front door is RK as it met the aesthetic.
It is a feat of engineering and arrived in a fully installed door set - there must be about 4 grub screws to balance every hinge and get the 900mm wide door perfectly level and flush. I think this would be the challenge from a DIY perspective.
I suppose the difference in my case compared to some is that I don't want an oversized front door, or one that turns on a pivot. I can imagine that the engineering requirements for either are significant and almost certainly beyond my DIY skills, but I could have a crack at modifying a standard front door, probably by cladding it, to give it a non standard appearance.
Thanks for all the discussion and ideas all.
7 hours ago, JOE187 said:
 This company advertise also on ebay as well and do 3 thickness of doors. I would be interested to have a lok at the quality as looks pretty solid!
https://globarro.co.uk/doors/specification/
Seems like the kind of thing where you'd want to see one in person. At those prices they are obviously not pretending to be top of the range, but that doesn't mean that they aren't up to scratch.
  • 4 years later...
  • 3 weeks later...
My wife silly money for doing this.
(the adding patina creatively and then varnishing it part)
You supply the door with the metal attached at your own cost. That's the easy part. 😉
Or you buy the sheet then glue it to your own door. (and no she can't/won't post massive sheets or warrant the lacquer and it remaining as-patinated for outdoor use)
https://www.etsy.com/shop/BalticMonkey
- Buy timber door
- Go to a place that does copper/brass in 0.5 to 1.0 mm thickness (0.6 and 0.7 mm pretty common) for about £60-80/m2 - the local metal roofing shop is a good bet
- Glue it to a slightly oversize timber door
- Trim it to finish size using a tracksaw with nice sharp blade
- Add patina with "secret sauce" (various acids, alkalis, etc - if doing daft things with heat/oxygen* then  you need to patina it before you glue it to the door)
- Laquer it to all heck OR leave it as is and accept that it will change
Probably buy yourself a few sheets before you start for practicing on. Getting your patina right is the bit that needs practice. Nothing that's out of the reach of DIY but you'll be corroding then washing / sanding and trying again with brass for a while before you get it right.
  • 1 month later...
On 07/08/2025 at 23:02, daunker said:
@Tony K how did you get on with this in the end? Did you have a shot at it?
Sorry for the late reply!
No, I didn't try it. I just bottled it and spent silly money on a new door.
No worries my man, I have a door sized opening still with nothing in it myself. What did you go for?
I have a pal whose helping me and can make me an oak one, might just see if he'd be up for trying a metal one..
- Buy timber door
Only just seen this! Sounds awesome, did you/your wife complete it, any photos?  If that's all the metal costs, I'm definitely up for taking on the challenge. I've actually got a zinc roof on and I think he does copper roofs... So I'll find out.
Sorry just seen her Etsy those look awesome..!! Very happy with a DIY effort if I can make it, if getting it on the door is the easy bit then I'm going for it. Doesn't matter if it's rustic or chaotic I don't really mind too much how it looks. Fingers crossed!
Edited by daunker
I went for a brand new composite door. It's quite nice looking, but I'm not convinced that I got value for money overall. I say that partly because there is already a 'knack' to opening it (though that's perhaps down to the fitting), but mostly I'm not convinced that a good second hand one wouldn't have done a perfectly good job for a tenth of the price.
Ultimately we were driven by wanting exactly the right look for the house, and paid for it.
Edited by Tony K
