February 22, 20179 yr It's right in the corner (vertical stack)and under the floor with very little crawl space so no chance of using a grinder or recip saw. Can hire a chain cutter for 33 quid and watched a couple of YouTube videos, I know, I know... Plan is to add a plastic swept tee for the new WC and use two couplers to make the PVC/cast joint good. @Nickfromwales am I crazy to attempt this? I know the stack has to be well supported above and the big risk is cracking the cast pipe...that's if there's room to get the chain around it while lying on my back! From what I've read it's not a job any plumber will be rushing to do...
February 22, 20179 yr Why not just remove the floor boards next to it so you have proper access for the grinder?
February 22, 20179 yr As it's old cast iron there is no guarantee that a chain cutter will give you a clean cut. As your going to retain the outlet side, you could use a disc cutter and cut a wedge out of the section you're going to scrap. This wedge, once removed should allow access to disc cut the back of the pipe.
February 22, 20179 yr I was bottling cutting this, crazed and holed pipe surrounded by concrete: Surprised myself! Could only get to one side but came out pucker:
February 22, 20179 yr Author 21 minutes ago, ProDave said: Why not just remove the floor boards next to it so you have proper access for the grinder? Poor pic, but you can just make out the black pipe right in the corner.
February 23, 20179 yr 1 minute ago, Tennentslager said: Bump for @Nickfromwales Been avoiding this Ill have a crack later ?( backshift just arrived to bail me out )
February 23, 20179 yr What about a reciprocating saw with a metal cutting blade in it. You can get blades over 250mm which means you can cut it all from the front.
February 23, 20179 yr 2 hours ago, Declan52 said: What about a reciprocating saw with a metal cutting blade in it. You can get blades over 250mm which means you can cut it all from the front. Ever tried it? . It's a nightmare to cut, even with a grinder. Let me finish this, grab some Piri Piri for the thick cut pork loins, and we'll have a go. ?
February 23, 20179 yr Author 2 hours ago, Declan52 said: What about a reciprocating saw with a metal cutting blade in it. You can get blades over 250mm which means you can cut it all from the front. Yep but concerned that is a bloody tight space and having the ability to hold the saw rigid as the travel of the blade will have to be held back to stop it hitting the brick...and/or using a whole pack of blades...and running out half way through the second cut...or any slight movement in the stack jamming the blade?
February 23, 20179 yr Hand job? https://www.amazon.co.uk/d/5nr/Stanley-Hand-Tools-12in-Carbide-Hacksaw-15-412/B000KKWRVU
February 23, 20179 yr 10 minutes ago, Nickfromwales said: I thought you'd never ask I'm not going to lower myself and bite on this tonight.....
February 23, 20179 yr I keep thinking of a wire saw like this: http://www.ebay.co.uk/itm/Metal-Wire-Hand-Saw-for-Pipe-Cutter-330mm-Plumbing-Cutting-Flexible-Spare-Blade/111538359069?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3D0b9f9170a9184870838954bc1be7c09f%26pid%3D100338%26rk%3D9%26rkt%3D30%26mehot%3Dag%26sd%3D112114817083
February 23, 20179 yr 9 minutes ago, Onoff said: I'm not going to lower myself and bite on this tonight.....
February 23, 20179 yr @Tennentslager, bear with this old boy: Clever old sod! Can't see tbh whether your pipe in the corner stops short under the floor or not. Drill a hole through floor etc. Slitting disc on a bit of studding. EDIT: I think I've just found my father! Edited February 23, 20179 yr by Onoff
February 23, 20179 yr 6 minutes ago, Onoff said: I keep thinking of a wire saw like this: http://www.ebay.co.uk/itm/Metal-Wire-Hand-Saw-for-Pipe-Cutter-330mm-Plumbing-Cutting-Flexible-Spare-Blade/111538359069?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3D0b9f9170a9184870838954bc1be7c09f%26pid%3D100338%26rk%3D9%26rkt%3D30%26mehot%3Dag%26sd%3D112114817083 Only prob is at 330mm you'll have no real length to get a decent saw stroke going. Cast is a b'stard, has anyone here ever had to cut one / has cut one? I have, and it's a pig of a job.
February 23, 20179 yr Author 18 minutes ago, Onoff said: I keep thinking of a wire saw like this: http://www.ebay.co.uk/itm/Metal-Wire-Hand-Saw-for-Pipe-Cutter-330mm-Plumbing-Cutting-Flexible-Spare-Blade/111538359069?_trksid=p2141725.c100338.m3726&_trkparms=aid%3D222007%26algo%3DSIC.MBE%26ao%3D1%26asc%3D20150313114020%26meid%3D0b9f9170a9184870838954bc1be7c09f%26pid%3D100338%26rk%3D9%26rkt%3D30%26mehot%3Dag%26sd%3D112114817083 Papillon or Shawshank Redemption...
February 23, 20179 yr Author 36 minutes ago, Nickfromwales said: Ok. What's the 'headroom' under there, aka operator space? Not a lot...under two ft and I've never been described as slight...well, to my face?
February 23, 20179 yr Author I'm losing the plot here...Question Time is coming on, so *chilling* soon. Don't rip the piss too much.
February 23, 20179 yr Is the existing cast iron soil pipe in use? Assuming you're replacing above the new swept tee.... you must be otherwise you'd never get it (the tee) in. Lop it off above the floor then use that mad old bastad's method in the video I posted to cut the pipe from the inside out. Will need to find a suitable washer to go on a slitting/cutting disc and over a length of studding. Edited February 23, 20179 yr by Onoff Grammar
February 24, 20179 yr 2foot is plenty of crawl space, I've rewired underfloor with less,,,,,. Wouldn't want to be cutting a soil pipe with contents unknown stuck to the sides in that confined space,,,,. So ye, I'd go with @Onoff and cut above, then that crazy method of cutting from inside out.
