HI all, Wondering if your collective brains have any knowledge on condensation in a cold roof in a passive timber frame house. We have tons of insulation in the loft floor, slate roof, when we opened the loft hatches to do the second fix electrics up there this week there was a deal of condensation. Is this normal in a new build timber frame and should i be doing something to prevent it? We have only just got the electric on and plastering has only just finished but with it being airtight i am assuming moisture should not have escaped from the house into there from that. The loft space is boarded out and we were intending using it for storage (the proverbial xmas tree and assorted other junk that its difficult to part with).  Appreciate any help or advice any of you have on this.
How have you sealed between the warm house and the cold roof?  how have you sealed the loft hatch?
I am a huge fan, you could say a convert, to the concept of a warm roof where this problem goes away completely.
No, airtight does not necessarily mean vapour tight. It depends on the exact nature of the airtight layer (and possibly other layers). The loft hatch would also definitely be a suspect.
its all totally airtight, taped to within an inch of its life by the timber frame company, (the airtest was very good 0.5). It has warm cell insulation (installed by MBC) The loft hatches are airtight and insulated, albeit not the prohibitively expensive ones - dolle clickfix with a u value of 0.49.
ah ok, this is a learning curve for me. I will ask the timber frame company on monday what they suggest on this.
You have introduced a lot of water while building/plastering  , it may just need a dehumidifier running for a while to remove this extra  moisture, then the normal ventilation will cope....
Mostly, pitched roofs are either cold roof + cold loft with insulation at ceiling level or cold roof warm loft, where the insulation is between and under rafters.  To be a proper warm roof, all insulation would be above the rafters.
@kaye has cold roof + cold loft and needs ventilation at eaves, plus a bit at the ridge.
thanks tony, we kept the loft hatches closed to help keep it snug to dry the plaster, this is a good idea
Edited by kaye
45 minutes ago, kaye said:
natural slate. and yes it was this membrane.
You should be good then (without any air vents) as that membrane is vapour permeable and natural slates alllow ventilation of batton zone, even if you dont have a dry ridge systen with ventilation.   As long as you haven't put anything vapor impermeable on top of expoperm (?).  Agree with @TonyT, its likely temporary.
Slates are quite well sealed and I believe even with a breather type membrane the roof void should be ventilated unless the membrane is certified (BBA or similar) to allow use unvented.
construction moisture drying could be part of the problem.
Edited by ADLIan
Mirroring what others have said, this is most likely entirely normal. It could just be down to a recent rapid drop in ambient temperature together will moist air within a new building. Keep an eye on it but you'll no doubt see it disappear soon.
Thanks Dan - i do hope so. There is nothing above the membrane except the warmcell insulation (about 350mm minimum as i remember). The loft is partially boarded though, not sure if that would make any difference.  lets hope it  magically disappears!
Thanks Simon, will keep a close eye.
I meant between exoperm and battens/slates. I can't see how partial boarding woule have an impact.
  • 1 month later...
