  On 14/12/2020 at 16:07, daiking said:
just (expletive deleted)ing paint it. You really won't notice it up there.
Expand
It will stick out like a sore thumb if I just paint it - as it will show texture if I’m not careful
Just spoke to paint manufacturer . They reckon if I sand it back super gently and use a fine roller with a watery coat first ( and leave to dry ) - then go over it again I should be ok......
So ordered just a tester pot as that should be enough....
Edited by pocster
Couldn’t sand this no matter how gentle - it just ‘pulls’ it loose .
So a very weak pva mix to stick the edges down . Sample pot of exact matching paint ordered .
Lightly sand the surface of the paint above the damage.
Use some filler to create a new 'paint thickness' below the damage.
Lightly sand and then paint.
If you really don't want to see the difference, there are some wrist exercises that make you go blind, similar to sanding.
Edited by SteamyTea
  On 15/12/2020 at 11:27, PeterW said:
Sounds like the paint hasn’t bonded correctly to the underlying plaster. What was the first coat..??
Expand
It hasn’t Peter
Though I did a first watery coat using the same paint . Speaking to the company they suggest next time to use a watered down emulsion first . He said this as it is would not be an issue assuming I don’t stick a piece of sellotape on it and pull it off .
  On 15/12/2020 at 11:59, PeterW said:
If you want it to look the same as the sprayed area then buy an airbrush kit - not expensive.
Expand
I did quickly look at cheap ones - but they all get mixed or terrible reviews .
Any you suggest ???
Expand
Surely worth a try before spending even more money, can’t do any harm!
Expand
Too fecking late mate!. I'm not convinced any roller won't leave a texture. Anyway - new toy on the way!
  • Sad 1
  On 17/12/2020 at 15:45, pocster said:
Xmas pressie has arrived
Expand
Let me know how you get on with it.  I have some small, "St. Ives", picture frames I want to spay up.
Not sure when I will be passing, was going to see my Mother, but think she is now in Tier 3, so may have to rethink plans for my 2 weeks off.
Expand
Sure - I’ll let you know how it is .
btw you aren’t really getting it ! ??
