newhome Posted December 8, 2020 Posted December 8, 2020 Hope this isn’t normal .... https://www.facebook.com/100014753527643/videos/1038971309937977/? Not sure if this link will work for everyone. This is the next door neighbour’s video complaining about someone’s ASHP. Permission given to share the video.
joe90 Posted December 8, 2020 Posted December 8, 2020 (edited) 50+ db is not acceptable IMO. I wonder how the “rules/law” can deal with this edit, just found this on the gov website....... Permitted noise levels The permitted noise level using A-weighted decibels (the unit environmental noise is usually measured in) is: 34 dBA (decibels adjusted) if the underlying level of noise is no more than 24 dBA 10 dBA above the underlying level of noise if this is more than 24 dBA from. https://www.gov.uk/guidance/noise-nuisances-how-councils-deal-with-complaints Edited December 8, 2020 by joe90
newhome Posted December 8, 2020 Author Posted December 8, 2020 Original message. I’ve uploaded a video of what we listen to most of the year. Been like this several years now - only slowly getting worse. I usually manage to get to February before I’m spitting blood, now I’ve had enough in early December. Rural village. Conservation area. No PP was applied for. I ‘think’ I know install company. I did some calling round last winter. Very off hand and defensive over the phone. Fence. Six foot ultra close boarded (double) window triple glazed on drive. Adjoining living room. Conservatory virtually unusable - unless you like the sound of living in an industrial estate. So, far my wallet if £1.5K lighter with fence and window. Other side of fence owner has lined the fence with sound insulation. We have had dialogue over the issue. Probably installers have suggested this. It has made a marginal difference. Before it was 52-54DBa one metre from window. One anonymous complaint has already been lodged by a neighbour (not me, it’s not my style), never has been. We live in a beautiful property overlooking fields behind us. Honest- we have come to the conclusion our lovely home would be unsalable in the present circumstances. NIMBY I’m not. I’m as easy going as an easy going person. But, surely this cannot be right? Any helpful suggestions would be very much appreciated. I’ve had several suggestions -quite a few non legal if you get my drift...
Temp Posted December 8, 2020 Posted December 8, 2020 I just looked at the data sheet for a gas boiler (Worcester Bosch Greenstar 25-30 Si Compact) and it quotes 52 dB(A) sound power level indoors. I guess its different when its your own noise.
Temp Posted December 8, 2020 Posted December 8, 2020 (edited) https://www.imsheatpumps.co.uk/blog/are-heat-pumps-noisy/#:~:text=Depending on the system%2C quality,metre away from the unit. Quote Depending on the system, quality of installation, and quality of maintenance – an air source heat pump will have 40 to 60 decibels of noise. Again, this is assuming you are one metre away from the unit. The upper limit is not a common phenomenon. There are official planning requirements with regards to air source heat pump noise. ASHPs must be below 42 decibels, measured from a distance equal to that separating the unit and the next door property. The noise might be between 40 to 60 decibels from just a metre distance (probably much quieter in reality), and the levels drop significantly as you move away. I thinking that installing one at the side of a house might make things worse because the noise will reflect off the walls of your house. Might be better to put them in a rear garden? Edited December 8, 2020 by Temp
joe90 Posted December 8, 2020 Posted December 8, 2020 8 minutes ago, Temp said: There are official planning requirements with regards to air source heat pump noise. ASHPs must be below 42 decibels, measured from a distance equal to that separating the unit and the next door property. that's not ambiguous. Someone should tell them.
nod Posted December 8, 2020 Posted December 8, 2020 Are they always so loud We did the plastering and rendering on 60 houses Most where in blocks of 4 or 6 All had a unit directly next to the patios Many where back to back
PeterW Posted December 8, 2020 Posted December 8, 2020 Looks like that is too close to the wall (min 300mm) and it is also out of balance - wonder when the fans were cleaned last .? Noise will be amplified by the wall and the fence - quickest fix is turn the ASHP 90 degrees to the wall(s) and it will reduce the noise substantially and probably improve the performance too. Out of the box it’s 52dB so it’s definitely louder than the agreed level but that install doesn’t look good.
Timedout Posted December 8, 2020 Posted December 8, 2020 Oil boilers make a terrible racket too. Particularly the external ones. And they stink of kerosene.
Onoff Posted December 8, 2020 Posted December 8, 2020 5 minutes ago, Timedout said: Oil boilers make a terrible racket too. Particularly the external ones. And they stink of kerosene. Mine is a boiler house type and fairly noisy but it doesn't smell unless I bleed it.
ProDave Posted December 8, 2020 Posted December 8, 2020 46 minutes ago, Onoff said: Mine is a boiler house type and fairly noisy but it doesn't smell unless I bleed it. I think he is referring to stinking outside. I have made the point several times that I believe my ASHP is about as noisy as the burner on an oil boiler. Exept that noise from the ASHP is outside so I don't hear it, whereas the last house had the oil boiler inside the utility room.
Onoff Posted December 9, 2020 Posted December 9, 2020 (edited) 8 hours ago, ProDave said: I think he is referring to stinking outside. I have made the point several times that I believe my ASHP is about as noisy as the burner on an oil boiler. Exept that noise from the ASHP is outside so I don't hear it, whereas the last house had the oil boiler inside the utility room. Gotcha. I wouldn't say mine's particularly stinky outside tbh. Must be pretty noxious though as it's rotted the flue grille. Also stained the adjacent uPVC frame a bit. I've added on this in my boxing in thread. Edited December 9, 2020 by Onoff
Gone West Posted December 9, 2020 Posted December 9, 2020 14 hours ago, newhome said: Hope this isn’t normal .... Our neighbour has a NIBE single fan ASHP at the side of his bungalow which is less than 2m from our fence and it can't be heard in our garden even when standing next to the fence. The only time I have ever heard it is when it stops and there is a whooshing sound for a couple of seconds.
