Are most brands of the plain P5 chipboard flooring the same quality or are some better than others also are the flooring sheets with the protective coatings worth the extra money as they  cost considerably more per sheet
Protective coatings or sheeting are with the extra
Caba deck 22 mil is pretty standard within the industry
Is Caber or Egger ever used on a "flat" roof?
Guessing not as fibreglass or EPDM might not stick to it?
Usually OSB3 these days for that?
I still don't reckon it's as good as marine ply on a flat roof. Screws hold better, edges hold up better etc. (I'll probably get some stick for that).
If your paying for it,
Slightly off topic but I refoofed a Wendy house with 18mm OSB3 then painted it with No Nonsense wood treatment. I never got around to felting the roof, just slung a tarp on weighted down with some roof tiles. It's been like that for about 3 years now. The edges of the OSB3 have "grown" as in they've thickened from 18mm.
Would the wood treatment maybe break down the glues used to hold the OSB3 together?
I see OSB3 used all the time on here I know. I don't think I've ever seen anyone paint it with anything.
Edited by Onoff
do you mean WBP Ply or Marine ply ..?? There is no benefit in using marine ply as the only guarantee is the voids within the plies and there is zero stress on a flat roof unlike a boat hull.
Marine ply. Like the super expensive stuff I bought when I did the bathroom / bath deck and surrounds. No voids and just excellent imo.
Is ply not better in bending than OSB3 of the same thickness?
Edited by Onoff
14 hours ago, Russell griffiths said:
You only need the one with the protection layer if you are leaving it with no roof above it for some time.
Wont be leaving it exposed
