Got a pic taken further back?
Bespoke stainless bog roll holder? Just a flat plate with a capped tube welded on & sticking out. Stick it on the tiles.
A Quinetic switch and use as a disabled call button?
Ash tray?
A bit of walk on glass to forever remind you of you & @pocster's mistake...
  • Haha 2
4 minutes ago, PeterW said:
Chrome USB blanking plate so you can charge your phone whilst on the bog...
Would that be a bog standard one?
59 minutes ago, ToughButterCup said:
I blame myself. Even though I had told the tiler not to cut this hole .......
How on earth do I fill it up / camouflage it elegantly?
What was it intended for ?
BTW my glazing will certainly cover it
... intended for ... ?
A small Euromodule light. But I was persuaded to change the layout of the shower: and now the lighting point is directly in line with the shower flow .... ?
I did ask the tiler no to cut a hole there.
If the light is IP65 then i would put it in regardless
Ask the tiler to replace the tile as you told him not to cut it!. However, as you have cable there are you not liable to have access to it (new build electrics not allowed to have hidden joins so I am told).
The WAGO blocks are considered maintenance free. The bigger issue is if someone decides to drill into that wall later and there's nothing to say there's a bunch of wires there. In that case back to a blanking plate or obvious electrical accessory (light).
Edited by Onoff
10 minutes ago, Onoff said:
... In that case back to a blanking plate or obvious electrical accessory (light).
a blanking plate is ...
I have TLCs catalogue open in front of me and  cant find one - even in the Bits and Bobs section
Online though , is this what you mean?
Presumably if I decide to do that, then it'll need to be sealed with something like CT1 maybe?
Just a good quality clear silicone in case you ever need to get it off. Nothing that sticks like sh...
3 minutes ago, MikeSharp01 said:
How did the sticker get into my post?
I thought we'd posted the same thing at the same time.
1 minute ago, MikeSharp01 said:
Nope - that's a bug by the looks of it - I didn't put it there.
bizarre ..!!! unless you both posted at the exact same time, I can't see how that worked..!
Spooky!
Presumably you can edit your post and take it out?
