A fence post has broken off at the base leaving just the concrete foundation.
Does anyone have any tips of how to remove the concrete in the ground so that I can put in a new post with associated concrete?
Having a JCB is a great help for this!!!! I have had to resort to manual digging in the past which is hard work and depends a lot an how much concrete was used. If the hole was dug with a digger there may be loads of concrete around it. Hope someone can come up with a better solution fir you.
Alas no JCB ?
All when I put the new post in should I wrap in dpm to stop it rotting?
Put a slimmer post in. If it was a 4*4 post put in a 3*3.
Or get the kango/crow bar out and break it up.
Or dig around the concrete and remove it as one lump if it's not a massive amount.
Best bet is to drill the old wood out with a long drill bit and shave the new post to fit the existing concrete
yep, done this a number of times at our current place.
I removed half a dozen at our old house before we moved
If the stump that is left is still relatively sound
drill a 25 mil hole about 200 up
Nock a long chisel through
Then simply jack it up a bit at a time on either side
It left the concrete in But I just moved the posts up
when putting in new posts it was good to make up a shoe in lead to the depth of the concrete, silicone around the top edge to prevent water ingress and when required lift old post and replace, this would depend upon the number of posts. as suggested above wrapping and sealing in dpc/dpm would do a similar job.
Farm jack is good too.
We had a similar problem when we replaced one of the fences. The installers had kindly put the posts in 600mm deep and put around 150mm of concrete at the bottom of the hole. When the posts broke at a later date they didn't replace them, instead they concreted a chunk of angle iron to the post and strapped the two together. As a result we had to dig out two lumps of concrete for every post. The only way we could do it was with a spade which was a real pain for 25m of fencing.
Hire a breaker it is then
Cheers for the advise, I ended up drilling the post out, down as far as I could go, approx. 1 foot.
What a pig of a job, 3 hours to put up a single chuffing fence post! I have put an extra layer of post Crete on top of existing concrete.
There was damage
Edited by Moonshine
There was damage
Was it a concrete post you drilled out ?
