ToughButterCup Posted November 7, 2019 Share Posted November 7, 2019 Reading this section of the site, I'm sold on the idea of dimmable LEDs. We're thinking of dimming some LED strips, and a good few LED GU10s. Maybe my brain's too full of dripping roofs, stolen favourite tools and First Fixation circuitry: but where does the dimming actually occur? In an LED GU10 circuit, the bulbs need to be dimmable. But what about the driver / transformer? Does that need dimmability too? Do the same rules apply to LED Strip dimmers? And has anyone seen a Scolmore Click Mode Module dimmer switch - you know, the type that'll fit in a grid together with other switches? Link to comment Share on other sites More sharing options...
ProDave Posted November 7, 2019 Share Posted November 7, 2019 First the lamps must be dimable. Then the switch must be compatible with LED's, sometimes described as a "leading edge" dimmer. There is no transformer with GU10's Link to comment Share on other sites More sharing options...
Conor Posted November 7, 2019 Share Posted November 7, 2019 I have an LED dimmer switch and bulb in our living room. It's terrible. I suggest you try a couple setups before committing to anything expensive and permeant. Link to comment Share on other sites More sharing options...
ToughButterCup Posted November 7, 2019 Author Share Posted November 7, 2019 Bleedin' edge dimmer eh? @Conor, I'm working on it... Do GU10s need to be Fire Rated if they are going to be put in the ceiling downstairs? Link to comment Share on other sites More sharing options...
Onoff Posted November 7, 2019 Share Posted November 7, 2019 https://www.lightbulbs-direct.com/article/dimming-guide/ Link to comment Share on other sites More sharing options...
Construction Channel Posted November 7, 2019 Share Posted November 7, 2019 40 minutes ago, AnonymousBosch said: Bleedin' edge dimmer eh? @Conor, I'm working on it... Do GU10s need to be Fire Rated if they are going to be put in the ceiling downstairs? I remember hearing somewhere they need to be fire rated if below bedrooms. But I'm sure someone will know the actual rules Link to comment Share on other sites More sharing options...
Dee J Posted November 7, 2019 Share Posted November 7, 2019 (edited) 6 minutes ago, Construction Channel said: I remember hearing somewhere they need to be fire rated if below bedrooms. But I'm sure someone will know the actual rules Typically a single two-storey domestic residence is one 'fire zone' and thus does not require fire rated lights downstairs. If your house can have open stairs and doors without automatic closers then its one fire zone. Taller buildings, flats etc may well require fire rated fittings. Hth. Edited November 7, 2019 by Dee J 1 Link to comment Share on other sites More sharing options...
Pocster Posted November 7, 2019 Share Posted November 7, 2019 Automate while you can ! Qubino or fibaro dimmers . Go on make the leap !!!! Link to comment Share on other sites More sharing options...
Mr Punter Posted November 7, 2019 Share Posted November 7, 2019 19 minutes ago, Dee J said: Typically a single two-storey domestic residence is one 'fire zone' and thus does not require fire rated lights downstairs. If your house can have open stairs and doors without automatic closers then its one fire zone. Taller buildings, flats etc may well require fire rated fittings. Hth. I have been told in the past by NHBC to limit the number of downlights or use fire rated ones as it may otherwise compromise the structure of the floor above. filedownload,84608,en.pdf Link to comment Share on other sites More sharing options...
ToughButterCup Posted November 7, 2019 Author Share Posted November 7, 2019 ?? everyone. Ian Link to comment Share on other sites More sharing options...
ToughButterCup Posted November 7, 2019 Author Share Posted November 7, 2019 2 hours ago, Onoff said: https://www.lightbulbs-direct.com/article/dimming-guide/ Sheeeeet . I didn't know I was sticking my [... ] in a hornets nest . Link to comment Share on other sites More sharing options...
Onoff Posted November 7, 2019 Share Posted November 7, 2019 10 minutes ago, AnonymousBosch said: Sheeeeet . I didn't know I was sticking my [... ] in a hornets nest . Mismatching the minimum load rating of the dimmer switch vs the total LED wattage is a common mistake. Link to comment Share on other sites More sharing options...
Temp Posted November 7, 2019 Share Posted November 7, 2019 6 hours ago, ProDave said: First the lamps must be dimable. Then the switch must be compatible with LED's, sometimes described as a "leading edge" dimmer. There is no transformer with GU10's I thought trailing edge dimmers were better for LEDs? Link to comment Share on other sites More sharing options...
ProDave Posted November 7, 2019 Share Posted November 7, 2019 1 hour ago, Temp said: I thought trailing edge dimmers were better for LEDs? You might be right. Forget leading or trailing, does it say suitable for LED? 1 Link to comment Share on other sites More sharing options...
ToughButterCup Posted November 8, 2019 Author Share Posted November 8, 2019 13 hours ago, Onoff said: https://www.lightbulbs-direct.com/article/dimming-guide/ Clive, yer a star. You've just saved me a good few quid. Thanks Ian Link to comment Share on other sites More sharing options...
Onoff Posted November 8, 2019 Share Posted November 8, 2019 10 hours ago, Temp said: I thought trailing edge dimmers were better for LEDs? Trailing edge for capacitive loads as in LV trannies full of "electronics" and drivers for LEDs. The dimmers themselves have more gubbins in them. (Because of the higher component count one could argue more to go wrong). Leading edge for inductive & resistive loads. They rely on chunky TRIACS, DIACS etc. A resistive load for example a good old fashioned incandescent or halogen "bulb". Leading edge dimmers really only for higher wattage stuff so they don't like the lower power requirements of LED stuff. An inductive load being say a motor. As for Click Mode bits do you mean these? https://www.click4electrics.co.uk/click-mini-grid-modules-dimmers-c-328_518_713/ Link to comment Share on other sites More sharing options...
