47 minutes ago, Russdl said:
A sheet of PIR or similar fits the first 4 criteria but falls down on the last.
But does it fail if you add local reinforcements (metal or wood) in local stress areas. You can make strong corners by using dowels, and even screw in to dowels etc.
An idea here
Why not just buy some armaflex sheets and glue this to the exterior of the existing box? This is what I did with the galvanised steel filter box from Zehnder.
Funnily enough just stepped out of my place, to be passed by farm vehicle moving manure. On Sunday, next door had a bonfire.
So glad I’ve got a pre-filter for all these country smells.
Edited by Nick Laslett
@JohnMo thats interesting, thanks for the link.
@Nick Laslett that would prove difficult to get an airtight seal on the current boxes.
I was thinking I could do with something like a ply backed PIR - which of course I've now discovered does exist!
As I have a sheet of insulation left over from the garage build I think I'll experiment with the local reinforcement idea, or maybe make my own PIR backed plywood sections, or perhaps a combination of the two.
What would be the best way of adhering foil backed insulation to plywood?
Spray foam, allow to flash off and not stick fingers when touching and squish together (dampen surface first). Bit like foaming plasterboard to the wall.
Or you can use double sided tape, the decent scrim stuff used for sticking vapour membrane together.
3 hours ago, Russdl said:
To that end I'm going to be remaking them but what material should I use?
If you're willing to forego the DIY & the 90° bend, you may be able to buy them.
The Zehnder IsoBox, for example, is made from EPP, has a DN160 connection & can take a pre-filter, a carbon filter, or both. Or a DIY filter, I guess. Paul used to sell them in the UK.
I guess that other manufactures may make similar for larger ducts.
Edited by Mike
Thanks @Mike, everything was originally built around replacing a 90° bend so that if I screwed it up I could remove my Heath Robinson filter and refit the 90° bend - so the 90° change of flow direction is one of the few certainties.
However, I could refit the original 90 and cut out a bit of the straight duct flow for one of those boxes you linked to. I've never seen those before but I suspect they don't give them away - or the filters? I'll take a look.
On 07/08/2023 at 07:27, Russdl said:
Also the power draw 67W before 34W after.
When I did my toolmaking apprenticeship, we combined machine amperage and an assigned tool life so we knew when to change the work bits.
Mayne you can do something similar, say 4 months and 50W.
A good idea :)
The best price I found was €85, carbon filter included, from https://www.econology.fr/zehnder-comfosystems-caisson-filtrant-isobox-dn-160-filtre-a-pollen.html, but there's not going to be as much competition in the UK market.
As expected, they don’t give them away!
As I’ve got some bits and bobs lying around I’ll go with rebuild and if that fails reconsider the pro version.
  • 2 months later...
Hi all,
New member here. I read this thread with interest, as my new MVHR F7 filter became black with muck and flies in just a few weeks (ugh).
After failing to find an insulated box for sale anywhere (I'd have thought they'd be popular!), I ended up buying a metal filter box from an online retailer (actually ended up with two, silly story) and, as expected, it became misty with condensation as soon as the outside temperature dropped. So thanks to @Nick Laslett's advice I bought a square metre of 19mm-thick Armaflex AF self-adhesive insulation and covered the box in that. It's not pretty but it does work really well, the outside of the insulation doesn't feel cold at all, even though the metal box inside is.
One question I had for @Russdl while looking at the photo of the grime-covered filter was, have you considered putting it in the box at 45 degrees? From the photo it looks like nearly all the air flow across the mesh is through a circle which is against the duct that's behind it. But with the mesh at 45 degrees you'd have a much larger air flow surface area (the diagonal of the side of the box, by the width of the box) which should mean less pressure drop, and a longer time before it becomes clogged. (Just my 2p's worth - I wish I had space for such a big pre-filter!)
As it happens, that is exactly what I did during the mid life refurb!
It is so much better, shame I couldn’t work it/you weren’t available when I made the Mk1!
I’ve also increased the insulation and air tightness with some left over bits and pieces. My pre filter material is now some fine mesh muslin material that costs pence and works like a charm.
Great minds think alike, eh! I can't claim credit for the idea though, I saw it on a YouTube video where a guy in the US was replacing his MVHR unit and he happened to have a pre-filter box with a diagonal filter, which he also explained.
The cloth you've used as a filter is interesting... I might try something like that instead of buying more G3 material. Though the stuff that my filter box came with is so thin, I doubt it causes too much pressure drop, the F7 in the main unit probably causes far more.
Your box now has some serious insulation on it!!
And I think very necessary.
Previously it was just some thin foam on the inside (and not very well attached, definitely not airtight).
I’m hoping the new set up will improve performance thermally, waiting for some proper cold days so I can check the temperature of the boxes, the Mk1 was definitely getting cool last winter.
  • 3 weeks later...
3 months after commissioning the new and improved Mk2 Pre Filter box it was time to change the filter material.
The muslin seems to be doing a grand job and the increase in useable filter surface area is being fully exploited by dust and flies.
  • Like 6
5 hours ago, Jolo said:
That colour change really is astounding.
I was quite taken aback by how dirty it got in what was a relatively short period of time.
I suspect the farming going on close by may have contributed significant dust. It’ll be interesting to see what the new filter is like in three months time with very little farm activity.
I'm surprised that ventilation systems don't come with a pre-filter like this, really -- or at least, that the're not more common.
Sure, the unit has a filter inside it, but on mine this comes after the temperature sensor and the pre-heater, meaning that these components get covered in dust, and probably flies too.
Also it's nice to protect the fancy expensive fine filter with a cheaper one!
Maybe pressure drop and increased fan speed for a given flow and more noise. The companies all sell pre filters of one kind or another so it's just an added extra, if you feel you need it.
We are among trees, the fields around are grass with horses, so our filters stay pretty clean. All depends on your houses needs and environment you are in.
I’m with @Jolo on this. I think a coarse filter of some description should be part of the package, if only to keep spiders and fly’s out.
Either way, it’s been fun messing around making something that does the job and does it well it seems.
Sounds pretty idyllic! (Though I'm surprised you don't get a lot of flies in the filter)
19 hours ago, Kelvin said:
Very nice job. I don’t have the room but our filters don’t get too dirty that quickly.
I only just had enough space -- I hadn't planned to add a pre-filter, so luckily there was a gap big enough between two other ducts to fit the box in. If the gap was a few centimetres narrower I couldn't have done it!
