SBMS
Everything posted by SBMS
  1. Useful to know @joth I’ve got two existing Sonos amps and architectural speakers so I’m thinking of keeping those. It’s a shame the loxone can’t interrupt the Sonos for announcements or alarms or doorbells. Other rooms I might put the stereo extensions in and line in to a floor sub. I might put a couple in hall and one in kitchen for the announcements / alarm?
  2. Have been looking at loxone audio server options. I like the idea of using stereo extensions and pairing my own speakers to that - but how would one go about adding a subwoofer to the mix? Did you do this @Kelvin? alternatively @Thorfun did you consider the new master/slave speakers that also have support for a ceiling sub? has anyone used them/would recommend them over the stereo extensions?
  3. Have done 👍
  4. Hi Zelem Yes we have gone this route. I asked the very same question to both the fabricator and Senior themselves regarding the claimed Uw value. They use a standard calculation method using EN ISO 10077, for the reference CEN window. The window size they simulate with is 1.23 m wide × 1.48 m high. This reflects a standard window size as the Uw value is related to the proportion of glazing to frame. Remember - the larger the window, the closer the Uw value tends to the Ug value. We have larger windows than the CEN standard so will tend to a better U value - although we have some spacer bars on some windows that will wash this out. The problem with any claimed Uw value is it relates to a number of related components that won't reflect your window; and therefore all they can do is provide a reference size so you can compare between manufacturers. The calculation of the Uw value (I looked it up because I wondered) is actually remarkably straightforward. You need to know the u value of the frame, the glazing and the dimensions of the thermal transmittance strip. One of the reasons Pure's Uw is low is they use PUR -polyurethane resin (~0.022 W/m K) whereas many other manufacturers use Polyamide (~0.30 W/m·K) thermal break. Thats an order of magnitude improvement in thermal conductivity. PUR is already commercially proven in large systems. So with this assumption, is their Uw claim reasonable? On average the frame area is around 15-25% of the U value heat loss, so the thermal break is going to improve the Uf value by around 30-40%, so I'd be looking at a reduction of around 0.2–0.5 W/m²K for a Uw value. That pretty much checks out with the difference between their standard Polyamide broken windows, and the Pure windows. Without independent verification then (which few glazing providers bother with because of the challenge of different window makeups - and the fact that the reference CEN window calc is pretty simple), you're left with looking at the reliability of the fenestration provider itself. Senior are prevalent in higher specified commercial glazing - not massively prevalent in domestic glazing. I see this as a benefit - they're a 34 year old company, which imparts a good degree of confidence. Check out the NBS Source Case Studies (https://source.thenbs.com/manufacturer/senior-architectural-systems-ltd/dVSDoRHE7zaprhEbgnigyf/case-studies). They've installed Pure in Grantley Hall Spa & Hotel, the main welcome building in RHS and the Castle Park View scheme in Bristol - tallest residential building in the city and it achieved level four standard in the Code for Sustainable Homes certification. These are the typical installations Senior does - high specification, high end commercial glazing. I think they are one of, if not the, largest privately owned fenestration provider. We're not talking safestyle UK here. Do I trust that they are putting PUR not Polyamide thermal breaks in? Yes. So from this, do I trust the claimed U value of the window? Yes. Did I look into Senior (£50m annual revenue last year, profitable, well reviewed?) Yes. Are the windows fabricated to a high quality? Well that's down to the fabricator selected which I can't comment on, but I visited the factory where our fabricator is based, spoke to their MD, spoke to a seasoned installer who has had no issues. So all in all, I'm pretty comfortable with the claims and my decision.
  5. I think they’d have a hard time justifying commencement just with presence of machinery. If you weren’t actually using it in the context of commencement of development (which is defined in the t&c act) it’d be a hollow challenge. CIL commencement is defined by the acts definition of material commencement. So demolition works, digging trenches for foundations, pipe laying, road layout etc. ‘digging holes’ would trigger commencement if those holes were clearly in relation to the development the CIL relates to.. I would always submit a start notice anyway there is literally no reason not to!!
  6. Ah didn’t realise that was who was offering the 30%… Why sell though?
  7. Our joiner did it. Stapled a bit to hold but then the battens are the actual thing that mechanically fixes the membrane to the sarking. The staples are almost temporary and I think could be skipped if it’s a still day and you’re battening as you go??
  8. Why did you sell @nod? Why not take the 30% uplift guaranteed?
  9. Fan coils instead of ac connected to your ASHP? They can be a bit more immediate then the slab?
  10. Thanks all. Im a bit worried wiring two 12v mr16s to 24v and was already concerned about putting non standard lighting circuits in.. I think it sounds like I am probably best off with mains downlights and trailing edge dimmers. The loxone 4 channel mains dimmer is ridiculously expensive so I’ll probably go for the whitewing dmx. I think I’m better off going for gu10 fittings and then getting something like a Philips master DimTone?
  11. Is MR16 not 24v? I assume the 24v dimmers wouldn’t work?
  12. Looking at loxone home automation. Seems that life would be much easier and cheaper with regard to downlighter dimming if I went for 24v lighting circuits for downlights. Has anyone else done this? It seems very difficult to find 24v fittings but I assume I can use 230v fittings that don’t have lamps, add my own gu10 24v lamps and then can dim from the 24v loxone dimming relay (4 channels for £70 odd). Any downsides to the above?
  13. What’s your approval say? Is it conditioned stating you must build to a drawing that has an internal layout? If yes, by the letter of the law you should apply for a NMA. But who would check? If you change the layout internally in such a way it affects anything external then definitely apply. weigh up the chances of enforcement (low probably) from shifting a few walls (after all, you’re allowed to post build).
  14. Interesting that the 10 modulates lower than the 12 in heat mode (and outputs higher) but in cooling mode the maximum output is identical. (Page 5) makes me think it’s the same hardware but software is range setting in heating mode but allowing the compressor to run full speed in cooling mode. Which actually is a useful thing for me as there is no additional cooling output with the 12kW but the 10kW is possibly better suited for my heat loss requirements 🤷‍♂️
  15. Does the 10kW modulate down to same level as the 12kW? What’s the point in going for the 10kW then??
  16. It’s 9kW at -4 in total. Sorry - the installer originally sized 12kW but they werent accounting for heat recovery so had a higher heat loss. I thought you were saying the heat loss calculation was wrong. They don’t have the calcs yet for updated heat loss. Interestingly heatpunk which produced the same output picked the 12kW as well, not the 10… I guess I have to account for DHW as well
  17. What is your current approach to cooling?
  18. I think I’ve been pretty scientific in the heat loss calculations. I agree the cooling ones are not realistic. How are the heat loss calcs wrong though and producing oversizing?
  19. I think the undercurrent point of mine here - despite some strong opinions on the rubbish job i am doing trying to navigate it - is that as we self builders spend more and more time on insulating our houses from the cold, there is disproportionate consideration given to overheating. I haven’t seen any DIY approachable method of coming up with a sensible cooling load model or calculation - but plenty of opinions that what I am producing is rubbish. I think as we hit hotter summers and temperatures increase this will become as important as the (much larger) emphasis on heat insulation and heat loss. I have noticed many other self builders that have overheating issues on here, and I do think it’s a problem that the part o overheating doesn’t fully address. I could just throw air con at it, but as anyone who has had an AC contractor round they (under their industry guidance) size for PEAK load. We’ve had two separate contractors who sized that we need a vrf system at 24kW output!! That is definitely madness. The answer as I see it now is a. size ASHP for heating and it’ll ‘probably be alright for cooling’ b. Get an oversized sub contracted ac system at double cost c. Pay for an independent cooling load assessment (if one exists) - that is more realistic than a peak load calculation! 🤷‍♂️
  20. Checked with our SAP assessor and the house does pass under dynamic thermal modelling. Frustratingly they don’t have cooling load/heat gain calculations in their modelling software 🙄
  21. Oversized for cooling or heating?
  22. 30mm is too much. You could put trim on and foam behind it.
  23. You’re right rick and 1/3 of that glazing is actually underneath a covered canopy. I need to update the model to reflect that. We could also look at an extendable shade if needed - it is north facing though.. it does have quite large roof lights which don’t help - but again we could shade those as well to reduce the cooling demand on very hot days. I’ve asked the SAP assessor for their full report as well, never thought of that!!
  24. Yes. We have passed under the dynamic thermal modelling process.
  25. By doors we have a large set of sliders and bifolds, master bedroom bifolds and two sets of glazed French doors and a utility glazed door. So the ‘doors’ are actually mainly glass. Correct I haven’t attributed for shading and that’s a good point. Agreed on internal gains I used an estimated watts per m2 probably over estimated. I don’t know what you mean by How have we passed building regs? Our glazing is all high performance triple glazing average is 0.7 u value and 0.5 g value. What is ‘bad’ about the figures?
