Post and beam
Everything posted by Post and beam
  1. If and when we get to that stage yes of course. But i like to learn.
  2. As i dont have the knowledge to answer this yet. Is there a table or a calculation i can use that would for example provide the necessary info for a 4, 6, 8 & 10kw array. or whatever is practical/allowed/sensible. The house will be 200 square metres, UFH, Vaillant 7kw ashp, compulsory EV point out front.
  3. Thanks and yes i thought that was the way to go. As stated above, is 500mm deep appropriate? Thanks for this as well, good idea. As to JohnMo's point about being vague, yes totally accept that. That'll be my ignorance of this subject. As it stands today i have no idea if the local rule makers will allow me to put an array in or of what size. It a conservation area. I understand local micro inverters are the current idea. The available fence line space would allow me a 30 metre run of panels on their ' long side' horizontal, if i do a single run. Neighbours on the other side of the fence would then not even see the array so no nuisance value to them.
  4. I have enough space on our plot for a south facing ground array along the northern fence line of our garden. Probably cannot afford to actually install this day one but if there is any money left ( yeah i know)once we move in i would like to put an array in place. So the question is what cables and at what depth should i lay down, just in case. The consumer unit at the front of the house on the west side is 21 metres from the closest point that the array would be sited. Thanks as always keith
  5. Ok it appears to mean the volume of the entire outdoor unit so we are good.
  6. We have just had a planning department concern about our planned install of a 7kW Vaillant. They have siad we dont have permitted development rights because it was not included in our submission. It was clearly shown on the drawings as located on the south side of the house. Regardless, the only question i cannot yet answer from the Class G requirements is the size of the compressor. I have seen this written down somewhere and am currently scanning all the Vaillant literature i can find. But does anyone have a link to where i might find this parameter please? Thanks as always keith
  7. You were not there and you are incorrect. I did not express to him the views that i have here. He offered his own opinion that we should not need to alter our home to suit the boiler. Whether this is a good or bad strategy is another question.
  8. I believe it is clear what the observed issue is. I believe that to all practical standards it is not likely to be possible to detect if the CH water experiences the same pause to heating. And in any case the engineer has confirmed what he does observe and why. He said himself that opening TRV's ( at least one) does stop the issue at the hot water taps. He also agreed that changing our house heat behaviour, while effective, is not the answer to the problem and that the boiler should be able to cope with how we want/need to live. But that Worcester Bosch would not be offering to replace the device for this scenario.
  9. The 'error' is me having cold shower water. Whether or not the central heating is being presented with no hot water supply on some occasions is, as previously stated, invisible to me and probably to anyone. This is true. Engineer demonstrated this when he was at our house. By opening the bathroom towel radiator TRV fully the issue did not occur during tests.
  10. I maintain that it is indeed unsophisicated. Becuase... The control algorithm cannot cope with this. Remember, nothing i am doing is outside of the published operating parameters of the boiler. Forget whether or not my house is poorly insulated ( it is). or i have too many TRV's, or i dont want to run at a higher temperature in the house to mitigate the over production of hot water.
  11. Agree But that means us having to modify our chosen living conditions to suit an unsophisticated combi boiler. Mind you, i doubt Worcester Bosch are going to do anything about it so perhaps that is what i will have to do. One thing is for certain, there wont be a combi in the new build.
  12. Of course. In the winter if it goes below zero then it needs to be 82 degrees. Funnily enough thats why i had it set at 82 Degrees. Today 76 degrees is probably too much and i will be returning it to 70 until probably November. John: i appreciate your efforts but i dont understand why the long sentence above. We have already discussed at length that Worcester Bosch cannot explain or fix the fact that in the winter months at least they cannot reliably deliver both CH and DHW without sometimes leaving us with cold water for washing. We know what is happening. They cannot fix it.
  13. No. To be honest i think the boiler that it replaced 3 years ago, at 34 years old, heated the house better than this one. But until we build our new house this is what we have and it has the issues described.
  14. Currently 76, was 82 through the winter because its a 1986 house.
  15. Not sure if 'after' is the condition we experience. Most obvious and annoying is when we turn on the shower. It also happens when we open any hot tap in the house. The water remains cold. So ' after using DHW constantly' does not fit our experience. Remember this is only every few weeks it might happen, it is not an everyday or every occasion condition. I do not know what the actual flow temperature out of the tap is. i will measure it. It is set for 55 degrees.
  16. I have very definitely stated that it is blocking code 2965. And it does clear after about 4-5 minutes. There has never been an actual 'error' code on this boiler that would require a manual reset.
  17. I doubt i would ever be aware of it, dont even know how i could be aware of it. If the radiators were not receiving hot water for 4 minutes the effect would most likely be undetectable.
  18. As an untrained punter( and, the customer ) this is my view. I repeat what i said previously. The boiler documentation says it can heat to 82 degrees if required. It should be able to give hot water for bathing in parallel.
  19. No its 15mm. But the PID algorithm controls the physics. My contention is that if the boiler cannot do what i need it to then it is deficient. I am not after all asking it to do anything odd. Specifically, heat a 1986 vintage 3 bed semi and deliver hot water when asked. The boiler manual does say that in older houses it might be necessary to set the temp to as much as 82 degrees C. There by recognising the need. It does not say ' but we wont always be able to give you hot bathing water if you do'
  20. Not to me. The engineers can see them. The previous engineer in january denied that they are time stamped, which i find unbelievable. Mondays engineer said that error codes and blocking codes are time stamped but that it is ' days since last reset' in some format. so not easy to decipher. Probably why the january engineer said what he did. By the way the boiler is a Greenstar 4000 rated at 25kw. Mondays engineer did say that when it fires up it will be at a % of max that makes the modulation very difficult when engaged water is low. Low as far as the boiler wants to see anyway.
  21. With respect i disagree. The boiler should be able to deliver the needs of my house and its occupants. In fact the engineer agreed and said that we should not have to bend to the will of the boiler. If the house is warm enough by the criteria we set that that is how the house operates. Stone cold showers every now and again are not part of my expectations.
  22. Yes, basically. It appears the boiler overshoots its upper limits and goes into a blocking mode for perhaps 5 minutes. My thoughts are that this is a failure of the P.I.D algorithm not being very sophisictaed, well not sophisictaed enough. The code is very specific '2965' to be precise.
  23. This is a traditional 1986 house with a gas boiler and radiators.
  24. I agree which is why i made the comment about software engineers. Little point in me demanding a replacement boiler under the warranty. But i will use this to try to get some kind of software update. However, i think we are on their latest and if they dont have a better algorithm then i am screwed until/unless they do.
