Post and beam
Everything posted by Post and beam
  1. These EV chargers have a display panel. If your BCO was awake ( and cared) they might notice if its not working.
  2. 'To comply with the rules' is an answer but its not THE answer. Why is it a rule? I think it is reasonable to require installation of the cabling to a point on an outside wall. In contrast it is nonsense to mandate that i spend a grand of my hard earned for the potential benefit of someone else.
  3. A future owner of my house might want a pool, should i install one now just in case. FFS! Solar panels are very popular, green and likely to become mandatory soon. Should i also install some
  4. East herts are my local authority. I had to spend a grand on a full EV charger install. I dont have an EV car.
  5. This is from just now. I can forgive the infrequent couple of seconds buffering we get in the evenings sometimes. Fair trade off as far as i am concerned.
  6. As an ex Submariner i can say that quite a few visitors do ask where the portholes are. We did have a fish tank built into the junior rates dining space wall which made people do a double take.
  7. Disagree. If the supply/demand equation were better balanced the upward price pressure would evaporate. Homes( not just new homes) are in short supply thus the price.
  8. One obvious reason is the huge imbalance between supply & demand i think. As long as the amount of people wanting a house outstrip the supply of them then the price/quality thing will suffer.
  9. I watched Kevin yesterday exploring the off site construction of a 'modular' single story house. Am i missing something? all that appeared to happen is the house was built in sections in a warehouse, it took just as long as it would have done on site as far as i could tell. Other than, of course, not at the potential mercy of the weather. Is this enough to warrant the process. The customer was impressed that once the house was delivered it went together quickly. But it still took quite a while, just not within the customers visibility. Only one house was able to be built at a time in the warehouse. Surely this is not a sustainable model from a financial point of view. I imagine true off site modular houses would be a 'call off' from a parts warehouse of pre made for example... 3 x 4 metre wall panels with window 2 x 2 metre panels with door. n X 4 metre wall panels no window. etc. You get the idea. Much like a SIPS design might be now but scaled for volume. Any design of house you want but from the standard parts list. Appreciate not everyone likes SIPS but i hope the description still holds. I believe the actual assembly should still be on site.
  10. I just read elsewhere on the forum about the building regs requirement for gigabit capable infrastructure mandatory. Have i screwed up by ditching openreaches incompetence and going with Starlink as my only connection to the outside world. I have read the requirement before, forgotten it i guess and then gone my own way. Clearly starlink is not hardwired. Depends on an acceptable definition of 'infrastructure' i suppose.
  11. I would not rely on any AI generated content. But i will view all designs and pictures it creates to see what i can take from it. If it sparks either my wifes or my imagination with any good ideas for layout then it will be worthwhile.
  12. Not yet but chat GPT says it can do this. It even claims it can prepare building control spec drawings. I am also planning to spend sometime out in the sunshine today as well, staking out options for paths, drive way etc. I need to try to stake out the relative heights. also need to accommodate the Wife's flower beds. I am not very imaginative in this regard which is why i wondered what AI can do.
  13. On the graphic that displays my 'obstructions' there is a quite large area behind the antenna that shows as a problem. This is because it is mounted on my chimney at about 12' up and the house is the obstruction it sees. This is with the antenna pointing north west which is apparently where the satellites come up over the horizon from. I would imagine my signal is handed off to the next one in line before the slightly behind obstruction becomes an issue. I do have a hazel tree partially in the way to the low left of my line of sight but it does not show up as an issue on the graphic. In practice none of the above is a problem 99% of the time. I think other factors are what cause the very occasional buffering in the evenings.
  14. Like a great deal of what the state provides in this country these days. Lots of encouraging words and 'plans' But very little apparent provision. Yes i know that Openreach are a private commercial company but the vision is the governments and they are not great at delivery.
  15. To date my experience of Starlink has been excellent. The product and everything in the box is top quality and well presented. It works very well and is dead easy to set up.
  16. https://starlink.com/public-files/accessories_guide_standard.pdf I bought this, its the standard wall mount. Solid as a rock
  17. Plenty of engineering text books with tables of figures for every type size and material of fixings. Google is your friend.
  18. Discussed this before elsewhere on the forum. I paid £2100 for a 200 sq metre house last autumn. Result went from 3.8 to 1.4 over a few hours. The guys did have a couple of leaky nozzles on their kit which left an invisible gloop on my walls. It is a bitch to remove, as i found out once i discovered what had happened.
  19. Dont give up on the the Zehnder Q350 because of its weight. I bought a brink flair 400 and that is about the same weight. I bought a cheap pulley set for about £20 and very easily lifted the unit into our loft.
  20. I was shown today how AI can generate ideas for lanscaping when given a photo as a base reference. Question, has anyone done the same successfully from plans and elevation drawings.
  21. The installation company i chose and subsequently turned out to regret Left me with a few questions once they left site for the final time. On this basis i was very reluctant to pay them the final invoice which basically covered the grant. They very quickly started to hassle me to pay. Stuck to my guns and argued that once they had all their money where was the incentive to #1 sort the issues & #2 actually get the grant money to me. As it turned out i spoke to the MCS people myself. They were very helpful and told me that the company had not responded to them within some time limit which killed the grant claim. The installers own incompetence had cause their issues. If you knew the full sorry story of this shower this would not come as any surprise to you. Anyway, MCS said that it was perfectly possible for the installers to resubmit the claim which they duly did once i informed them that their failings were at the root of the delay. MCS paid out within a week to their credit. Still waiting since 9th December for a resolution to our losing pressure issue from this bunch of chancers.
  22. I wonder what hardware and service level this is. My antenna cost £275 in November and i pay £75 month. sometimes get up to 300Meg download.
  23. The Starlink cable is proprietry and a standard ethernet cable will not work. The ends of the Starlink are slightly different. They also claim that because their antenna is quite high power that ethernet cable cannot cope.
  24. Before i ask the Planning department the probably painful question of what their requirement is with regard to our Bin location, does anyone have any insight please? Our 'pre first occupation' condition #13 requires us to submit full details of how and where we will locate our bins & recycling containers. We have already moved in by the way. My response would be, ' over there mate out of the way'. I doubt this is what they want. For those that have been here, what level of detail are they likely to be expecting?
  25. New build well insulated, UFH and air tight ( ish). Mains gas is not available on our plot and the delivery was going to be £6500. Not usually factored in when people discuss how expensive heat pumps are. Finding a heat pump installer was difficult and to be honest the company i chose have ended up being a total incompetent nightmare. Hey ho! lesson learned.
