Post and beam
Everything posted by Post and beam
  1. I should have twigged that one shouldn't i. Seeing as my handle is Post and Beam and thats the type of house i am hoping to build.
  2. Whats P&B please
  3. Its a Potton SIP's house. So timber frame essentially. If it turns out i am being indulgent and impractical i will have to re think.
  4. I am learning that Brickies are used to using 10mm mortar thickness and even have tape measures calibrated to this. So, where i want to add to the olde worlde look of my potential build i would like to have a wider mortar line. Perhaps 15mm. This of course screws up the brickie's auto mode. For any brickies out there, is this a stupid idea? is it unusual and or impractical. I am also learning that window heights and distances from corners to , say, a window frame are often multiples of whole bricks using the 10mm spacing. Potentially making my idea even more eccentric that i hoped. Comments.
  5. Yes, and the db numbers are not linear they are logarithmic. 3 db difference is twice the volume. For example 42db reduction is 4 times less noise getting through than 36db. The thing is our hearing is also not linear so that difference is not as obvious as you might imagine.
  6. Thanks Dave. I am still learning about calculating the heat loss. I expect the house to be well insulated, U=.15 walls and .12 slab. Also found this in their spec' sheet ....Sloping ceiling (222mm rafter) 0.13 to 0.12 (dependent on rafter spacing) 2 layers 80mm Kingspan Kooltherm K107 and one layer 25mm Kingspan K107 Kooltherm. Cold roof (cold space above e.g plane roofs and eaves) 0.11 2 layers 200mm loft roll 40 Putting the elements together for an accurate assessment is beyond me at the moment.
  7. Thats how this forum helps with rapid knowledge aquisition. Brilliant. Supplemental question then.... With regard to the pipe centres question. In my ignorance i imagined using close pipe centres ( 150-200mm) such that the water temp could remain low and thus not stress the heat pump. Keeping my living room at a southern softie 22 degree C for example
  8. As per the title really guys and girls. As a novice to the whole subject but trying to learn at a rapid rate, what matters when you need to make a purchase descision? # Should you go for the smallest possible distance between centres of the UFH pipework. # What bore size of pipe # Pure water or glycol mix # The smallest Heat pump that will do the job or the largest you can afford # longest run of pipe before you hit issues # is a particular manifold pair better than any other. If so, why? That will do for todays homework Thanks in advance keith
  9. As the OP, i say crack on guys. All discussion of this nature is good as every day is a school day. I am just about to create another post with a question that spins out of this anyway.
  10. Hi Hugh No i did not. I was hoping there would be other manufcaturers, there. Perhaps at the NEC
  11. My interest is trying to discover if this brand is reliable and viable for domestic use and also value for money. I have no interest in how to install one, thats what a competent installer is for and thats not me. I would engage somebody that i believe is trustworthy
  12. Hi guys Research is ongoing. I have been directed towards one of these heat pumps. I have not heard of them before. Grant aerona 3
  13. I spoke to these guys this morning. Rough estimate was not very close to your price. When did they install your kit please?
  14. That does not speak well of my potential supplier for you to say one of their design elements is the least efficient way of doing that task
  15. Had a look on their site, i will call them in the morning.
  16. Funny thing is, i watched a youtube video of theirs that is less than 2 months old. It said a typical install for a new buildhouse of about my size would be about £11500 all in. Installed and VAT added.
  17. Yes you can, its the Nibe 2040-12 kw @ £12800+Vat I aint payin that by the way ------------------------------------------------------------------------ Full supply list as below. Fitting not included. 1 NIBE F2040-12 (typically capable of heating a property with 10kW heat loss at design operating conditions, in compliance with MCS standards) air source heat pump kit, charge pump, and associated fittings. 1 Air source heat pump system to provide space heating and domestic hot water 1 100 litre (type C) buffer box assembly with four tappings and one immersion tapping, with immersion heater (Please note: DHW cylinders, up to maximum of 300l (due to weight), are stackable on the buffer box) 1 EnergyPro® 400 litre unvented stainless steel HP cylinder for use with NIBE ASHP, including fittings and G3 kit. (Please note that the cylinder warranty does not cover private water supplies, e.g. boreholes. Please speak to your Account Manager if this required.) 1 Electric metering kit for one single phase heat pump and two additional immersion heaters 1 Includes delivery of heat pump and tank by carrier to UK mainland only 1 Heat pump design and support package. This includes the system design, comprehensive handover pack, an on-site commissioning visit from a Nu-Heat Engineer where they will talk you/your customer through the system, and MCS certification. We will also register the heat pump for a parts and labour warranty. Please note the electrician and plumber installing the system will need to sign a sub-contract agreement before any installation work commences and adhere to MCS and RECC standards.
  18. On top of my quoted prices for the supply of an ASHP, see above. The install figure was estimated at 50% of that. So, £6500 to install the heat pump and cylinder. I estimate that to be just over 3 weeks work.
  19. Well yes, exactly. The same as reviews of just about any product, when advertising spend comes into play. Think virtually any car or bike magazine.
  20. Not saying i am going to use one at all. Just interested that something can top a poll and be invisible on a large forum like this.
  21. Afternoon guys While researching Heat pumps this afternoon and trying to justify the quote i have been given for a Nibe I came across a review online. The 10 best heat pumps 2023. The bosch CS7001iW came out on top. Now, i have nothing to say about this other than i have not heard them mentioned on this forum at all either good or bad. To be honest did not even know they made heat pumps. Has anyone fitted one? What are they like Regards keith
  22. A question for the experienced people here. Is it reasonable to expect that an ASHP installation for a new build would include some kind of hot water tank/cylinder. The reason for me asking is that if i have been quoted for a system i expect it to be for the 'system'. And all that that would typically include.
  23. No i am not capable of doing a competent job of this. My knowledge extends only as far as knowing that i dont know enough to even attempt it.
