Kelvin
Everything posted by Kelvin
Doesn’t this ultimately come down to where you put the air tightness layer, then the careful detailing of that. We also designed our service void so that there’s an uninterrupted horizontal run around the rooms. This also has the advantage of being easy to add other sockets in future. My electrician commented that ours is one of the first houses he’s worked in where there’s no cold draughts behind the back boxes. I would have been incredibly disappointed had there been to be honest.
It you’re worried about the legals down the line but happy in principle with the access then speak with your neighbour about getting something drawn up. However it’s your neighbour that ought to be concerned about future access to their plot.
It’s because nearly everyone on here is your neighbour.
What’s your specific issue? What do you want the outcome to be? Do you intend to try and stop their access to their property? Have you spoken to your neighbour about it? Can you see a reasonable alternative solution?
Our planning consent included putting PV panels on the roof. We decided to ground mount them instead for a variety of reasons. I spoke to planning last week to confirm that I needed to submit a new planning application. I’ve had a look at other planning applications for ground mounted PV and it’s straightforward enough. Data sheets for the mounting system and panels, dimensions, current location drawing and block drawing and proposed block drawing. Should I include my reasons for wanting to ground mount them instead or simply provide the minimum planning requires?
Boiling Water Tap Under Kitchen Units Condensation
Kelvin replied to revelation's topic in Kitchen & Household Appliances
We had cupboards above our previous utility room sink and have done so again in the new house with no issues. You can get away with it if the sink isn’t in constant use. -
Built-in fridge with ice dispenser
Kelvin replied to puntloos's topic in Kitchen & Household Appliances
Our original plan was to have a full height fridge and freezer side by side with built in water dispenser and ice maker. However, we ditched that idea early on for a few reasons, namely: 1. They take up a lot of space and we would have lost a complete unit of cupboards/drawers which we valued more than ice on tap. 2. It’s open plan so another device to make a noise. 3. More bits in the fridge and freezer to go wrong and they do seem a bit unreliable. 4. We don’t actually have a need for a big amount of freezer space. We also tend to buy fresh daily so not even a need for a full height fridge as there’s just two of us but we have fitted one. 5. We wanted the appliances to be integrated anyway. 6. We have a dedicated drinking water tap and our water comes from a borehole anyway. Our final plan was to just fit an integrated full height fridge in the kitchen and have an under counter freezer in the utility room. If we find we need more freezer space I’ll put one in the garage or in the utility room. -
Yes listen to the examples given here. There’s another example near me where the guy got planning to renovate a derelict cottage on a large plot. He got into it and the building turned out to be much worse than he thought. The walls “fell down” so he started erecting a new house on the footprint. Building control stopped by to check progress and stopped all work. In the end he reapplied for planning to build a completely new house on a different part of the plot. It’s not worth the risk to mess about with this.
Having trouble comparing quotes and understanding whats reasonable
Kelvin replied to vab89's topic in Surveyors & Architects
It seems a big expense for a relatively small space. -
I would think the difference in cost between single storey + mezzanine and two storey marginal. Clearly your budget sets your ultimate build but don’t compromise on such a big element so early. If you really want two storey stick to that for now. References are great but they only go so far. For example, we went to see three Hebridean Homes builds before deciding to go with them. The feedback was mostly positive with the negatives being consistent but nothing to worry about. All three loved their finished houses and they did look good. Our experience of them has been pretty awful by comparison. -
Having done a fair bit of paint balling with my son the bigger the space the worse and less interesting the game. They tend to drag on for ages which is no fun if you get shot early. The best games are the ones where they’ve created playing area with buildings and obstacles in a relatively small area. These games tend to have a faster turnover.
Existing water supply to temp
Kelvin replied to SarahG's topic in General Self Build & DIY Discussion
Yes exactly. It’s much easier to bring the main to the plant room (or specific cupboard) and distribute it from there. -
We really aren’t missing the point. It was fine until something changed. That change was adding a lot of extra weight onto the timbers. If the timbers had some space between them (that weren’t filled with packers say) then they can move. Even very small movements will crack plaster. I went around all my first floor timbers and packed out any narrow gaps with thin bits of wood and glue for example.
88 new houses near Cambridge to be demolished.
Kelvin replied to Temp's topic in General Self Build & DIY Discussion
Either quality is designed in and everyone involved buys in to a quality first approach or you have someone responsible for quality, checking every element and signing it off. Just transferring the responsibility for quality to the people doing the task is never going to work. Oddly one of the older guys on my site described me like his old clerk of works guy which I took as a compliment rather than an insult. -
I’m sure I read that it was the logging industry that developed paint ball guns to make it easier to mark trees to fell. I might well have made that up though. I would have that running about an ancient woodland would do a certain amount of damage plus the potential for a load of rubbish being left laying about.
The casing is gelatine like they use in the pharmaceutical industry. It’s not really paint but a water soluble dye.
Trading off rooflight size vs supporting steel
Kelvin replied to RatFloofing's topic in Skylights & Roof Windows
That is a substantial room and done well it could be a terrific room. It looks as if it’s pretty bloody cold on there too! Your starting point really needs to be what do you envisage using this room for. If money was no barrier and you turned into a wonderful entertaining space would you use it? Done well it would add real value to the house. Alternatively you say you don’t need the space so the other extreme is remove it completely and regain the garden space in what is potentially a sun trap. No matter what you do it won’t be cheap to do it well. -
You need to decide what your main objection is. Is it the noise, the potential to devalue a property you’ve yet to even start a planning application for or the safety aspect? If they can satisfy your concerns about making it safe will you be ok about it then? Assuming they go ahead and make the rumour real of course. I struggle to see how a woodland could be turned into recreational use if there’s regular vehicle access through the middle of it. That said, you don’t need a significant amount of space for paint balling depending on how they set it up. I did it a lot with my son and the best ones were where the layout was in a small area. If the area is too big it’s less fun and the games are much longer.
It’s another reason I am ground mounting mine too.
What’s your suggestion? It’s more a scale thing. For all the thousands of extensions etc that make up the biggest proportion of applications it likely works mostly ok. For large complex builds it doesn’t as there is an expectation that the developer is doing it correctly and checking the work which they clearly aren’t in some cases. The consequence of failure in this case is going to cost David Wilson homes many millions to fix. Maybe there also needs to be very harsh penalties for failures too to act as a deterrent. -
There wasn’t a house on the site at that point it was just a field with planning permission. Therefore it was making a new connection. If there was a problem in the future now the house is up, I expect the existing wayleave is worded such that they could get access. I never got a copy of it so don’t know the wording but I can’t imagine they word them for a one off new installation.
They can’t get access to it. The electricity to our house is fed from a pole on our neighbour’s land. I needed a wayleave from her to let SSEN access her land to run the cable down the pole and into the 2m trench I dug to my boundary. Had she not granted this we would have been stuffed or it would have cost thousands of pounds compared to the £450 it actually cost. A less scrupulous neighbour may have tried to make money out of it. The situation might be different if the supply is to an existing house and there’s a problem with it. I also can’t see them do something that would cut someone off. You won’t be able to force them to move it very easily. You can ask of course. I suspect if there was an issue that they deemed dangerous they could gain access. What’s your specific issue?
Yes it’s odd how quiet it is. It’s less quiet upstairs though as you can hear the rain hit the rooflights.
