flanagaj
Everything posted by flanagaj
Just looking at the planning application that was approved for the plot we are in the process of purchasing. The PP used Nitrate mitigation calculations based on a Graf One2Clean system, but when I look on the drawings, I do not see any provision for a drainage field. Is that because a sewage treatment plant can feed it's water into the same soakaway as that used for rainwater? Maybe drainage fields only apply for the traditional septic tank based systems?
Thanks for this. Makes much more sense doing the slab this way. Did the contractors who did the slab also power float it?
Wrong levels, sides collapsing, wrong location, uneven base. Aside from the second point, the rest are avoidable.
That's a good point.
This is a confidence builder. The depth display is a very cool feature. I suppose using triangulation with satellites for GPS is actually very accurate.
It's not so much about saving money, but mainly due to wanting the job correctly. I have used multiples trades in the past when we renovated our house, and 50% of them were ****. Maybe I get a good digger driver in to pull the footings and I can then do the drainage myself. As @ProDave stated. Drainage is planned on paper and all relative to the height of the excavated oversite. If you hammer a stake into the ground and get it set to finished floor level, and use this as you reference point for all laser level measurements, how can you possibly get things wrong?
Maybe I am not doing it justice and am massively over simplifying things, but if you consider that every aspect of groundwork is carried out relative to finished floor level,then it seems very straightforward to do all groundworks yourself. One you have used simple trigonometry to mark out your footings you dig to the required depth (according to soil survey) and relative to finished floor level. Put pegs into the side of the trench according to required concrete depth. Calculate required concrete volume and poor footings, levelling to pegs. If you buy a decent rotary level and you understand about drainage then you can then install the foul water system to septic tank and the required drainage field. The only part that I'm unsure about is being able to operate the excavator to create a flat bottomed and levelled trench. I could potentially get the digger and maybe practice on some smaller areas first so as to get familiar with it. Was thinking about site entrance. Have any forum members done this, and if so, would you advise against or say that it's very viable. I've got plenty of time that I can devote to getting the groundworks done.
That is very nice! Love the galvanised guttering too. I'll keep this image to hand.
Possibility for a bedroom?
flanagaj replied to flanagaj's topic in Lofts, Dormers & Loft Conversions
Fair point. Once we have exchanged then I am going to engage with an architect to see whether our ideas are viable. Just not sure how receptive the LPA will be to large scale changes. -
I need to understand groundworks
flanagaj replied to flanagaj's topic in General Self Build & DIY Discussion
One other point I forgot to mention surrounds the finished floor level. The PP obviously has proposed elevations, but when it comes to the finished floor level, is this something that is open to you to decide, or will the architect provide that information once a topographic survey has been carried out? -
Thanks @JohnMo / @Russell griffiths some really useful information there. I am not too far from Swindon, so will definitely head up there. -
So having had our offer accepted on a building plot with full PP, I have been researching like mad the whole groundworks stage and my head is spinning with questions. 1) Installation of septic tank and drainage field 2) Trench or Strip footings. How do you run the soil pipes through the concrete if you go trench fill. I understand that for strip you just use concrete lintels. 3) Installation of soak away 4) Beam and block OR just install the concrete slab with UHF straight away and be done with the the concrete / insulation / uhf / concrete layer approach 5) How will the soil pipes run to the septic tank and does the approach differ depending upon whether you go beam and block or solid slab floor. I have seen that with beam and block, the pipes simply run in the void under the beam and block floor. 5) What order are these things done. Does anyone know of a good resource for this stuff. I have the Housebuilder's Bible, but this does not really cover this stuff in much detail.
This is a new dwelling, and I currently only have the drawings used for the planning application. Stairwell is no problem as the ground floor has been designed so that the stairs enter into the upper floor space in the middle of the floor. -
I am trying to work out from the drawing below. Where the floor level would be upstairs and how much head height is available. I think there is enough room to get a bedroom in the loft space, but not sure what size and headroom. Not sure if anyone with any knowledge might be able to provide an idea.
Looking at securing finance for our build, but want to understand what actually needs to be done to get a completion certificate and to then move onto a standard residential mortgage. We are quite tight on funds, but we are also fine if we move in and still need to tile floors, fit the additional bathrooms, utility room, exterior cladding. These are areas that I am completely comfortable doing myself and not only will it save us money, but also mean we can move in and tackle these jobs when time permits. Thanks
Does brick plinth really add expense?
flanagaj replied to flanagaj's topic in New House & Self Build Design
The granted PP on the plot we are purchasing has oak cladding with a lower brick section with no plinth. I personally, much prefer the plinth as shown in the image below, but conscious of a finite budget I have a feeling that this option adds a lot of expense? The brick plinths seem quite expensive.
Offer accepted, but funds wiped out from land purchase.
flanagaj replied to flanagaj's topic in Self Build Mortgages
When you say 80% of the plot purchase, you mean that I put down 70k (20% of 350k) and they will pay the additional 280k and then I can keep the 280k cash liquid so it can be used as and when, or am I missing something? -
Build is 157m2 internal with a detached double garage. Budgeting around 2k / m2, but hoping my Brother in Law who has just completed his 280m2 build for just over £1200/m2 can help me. I am quite fortunate that plumbing / electrics / roofing / carpentry trades are available in the family. -
So we have just had our offer accepted on a building plot with full PP. Super excited, as my wife and I have been looking for a plot for over 2 decades. Unfortunately, the plot purchase (350k) is going to completely clear us out (profit from the sale of our previous house) and we will not have any funds for the actual build. I am conscious that lenders do either 'in advance' or 'in arrears', but I wanted to ask whether there are any caveats to be aware of. We are looking to borrow 250-300k in total and we have been told that after completion a house in that area will be valued ~ 700k - 750k. Thanks
Haha. That's the first thing my wife said.
Thanks. So my worry of 10 - 20k has been somewhat alleviated
I did wonder whether that might be an option. Much better if it could be recycled and reused by somebody, rather than it just being destroyed.
