We've had it fitted as part of the deal. Very fast when nearby. Very slow to nil at 30m away in the site caravan. As the project is all metal clad, we will have to provide boosters. The fitter asked why starlink when there was an O2 mast within sight. Well, because O2 don't say that reception is any good in the area and because they are right... it's very poor.
Re downpipes. Once the water is in the pipe it is well within capacity. But the constraint is in the inlet where a weir effect forms. So a single pipe with a big outlet can carry lots of water where a standard one cannot. The upmarket makes cater for this. Do you know what brand is being used? They should have info in their brochure or online. It sounds a bit as if this hasn't been designed and is just a sequence of events. Bigger gutters, big outlets, more than one pipe (and/or an overflow) and a fall, if possible, all help. Also, a downpipe near an end works less well than if centrally positioned. Bottom line is what happens if it overflows? Does it come clear of the house or run back to the wall?
What battery drill should I buy? The choice is bewildering.
saveasteading replied to jimseng's topic in Tools & Equipment
Just had an email ad: Dewalt discounts at Toolstation. -
Join the club. It happens with interesting subjects. We've all been engaged and you have had good advice. Now, re buckets: get a couple of the better ones from a BM, as they usually have a choice of cheap or good: then hide them. Plus an orange one. -
I want a bucket. There is a bucket. I have a bucket. (The orange ones are not strong, hence the price.) -
To some extent. But my hedge cutter and leaf blower won't stack on the drill or jigsaw. If I was a working trade then there's a big advantage in stacks on wheels. But at home it goes on shelves, and excessive size isn't any help. Btw tippex on the box is an easy marker of the contents. -
Not at all. That bucket one looks really handy for moving around or hung on the wall. Decent price too and finding it brought up other makes that the Google search had decided to ignore. Re sundry tools and fixings for a project where I'm moving around, I use a b and q orange bucket or a wickes yellow trug because it is findable and not picked up by someone else as a handy bucket. -
I'm coming to realise that tools need to come in a customised box. I've got several that came in cardboard boxes but 1. They don't go back in without disassembly, 2. The accessories are at risk of loss. 3. They fall apart eventually. What value the customised plastic box? £5? Yes I'd pay that, although some of my own brand ones aren't good either. Does anyone know a source of good storage boxes? -
Likewise I have an ancient drill, like a machine gun. It is mains powered. It makes the most beautiful whirring sound and drills almost effortlessly. It comes out of the box for precision work in hard material. Herr Bosch was on Radio 4 once, explaining very openly that their cheapest drills are for occasional diy with a limited life, and both performance and lifespan increase with price. -
The tool I use most, by far, is a drill with settings for speed and torque. Light weight is a boon. The hammer option is not ideal except for very easy material like lightweight blocks. Having seen inside a broken drill, the hammer option is quite primitive. Hence sds for any serious masonry drilling and the cost may save days of struggling. What is your time worth? If you are doing lots of timber cutting then I think a bench saw may be justified and perhaps mains power isn't a handicap. For boards you must have a circular saw, or jig saw.... and on it goes. -
Agreed. Batteries are expensive. It's not an easy answer as you could spend thousands easily. I've been borrowing deWalt recently. And it is generally the high spec, so hundreds each. When I can't borrow I use my own Einhell stable.* The difference is apparent but both have their place. That drill you mention isn't top end so more diy than professional. But maybe that's what suits. You also have to consider weight. If you have a big drill with heavy battery it becomes a burden in a long day. Some tools need big batteries or always 2 more on charge. So yes try that. I'd also consider one with SDS. It depends what you want to do. The own brands are not such a great bet. I have 3 I really should throw out because they are broken down, out of alignment or just a pain to use. But I bought a Titan circular saw and a heavy breaker. The latter cost the same a 2 weeks hire: but is nowhere near as good as a hired one. There you are: not an answer. Tell us what jobs and how intensely used and it would become clearer. Btw joiner has switched from deWalt battery nail gun back to Paslode. But he's nailing hundreds a day. * currently with free battery from Wickes, so very good value for my work intensity. I've got 7 or 8 things and never a problem. -
Why we need "Net zero"
saveasteading replied to Beelbeebub's topic in Environmental Building Politics
Rhetorical, or do we expect our man in the field to check this by drone or trained eagle? Perhaps the more advanced met maps tell us? A good point anyway. -
Steel Single Spine Staircase worries
saveasteading replied to crispy_wafer's topic in General Structural Issues
For a little comfort. We put this stair in as temporary access. The post is really too small to bear directly on the screed. A permanent solution will be to have a much bigger bearing area by plate, or by forming a footing in place of insulation. But do notice that after a couple of weeks of burly builders and carrying materials, there is no damage and the screed is only 40 to 50 thick. So it's not a panic but does need a considered solution, as already discussed. -
South Cambridgeshire Local Authority, yay/nay?
saveasteading replied to Gema's topic in Building Regulations
Sadly I'm not surprised. Eg. I was once seconded to one of the big UK consultants who were engaged by one of the world's biggest (US). I was handed stuff to design that I had only studied af student level. I thought "why me" then gradually realised that the place was full of agency sourced designers and I knew as much, maybe more, than most of them. It was basically " design this middle eastern new city". I did ask at higher level and was told not to worry as it will all be redone later. I've looked on Google Earth and it seems to be in place. On the positive side though, this became part of a spontaneous and rigorous questioning at my Professional Interview. It was clear that this was also a concern to my interviews, both high in Engineering circles, so perhaps it is unusual. Plus I've engaged perhaps 5 Stuctural Engineering practices over the years. No doubts, good teamwork. The thing is, @Gus Potter, if they are found wanting what will happen to them? They aren't in professional bodies that could sanction them, so prob a strict talking to and small fine, and then a change of business name. -
@Gus Potter i was only considering building inspectors -
Along with a photo looking like my mouth these days.. @Beau I'm impressed how cleanly that came out. Was it slow and painstaking? My concern would be that this is fine for a concrete slab. But in beam and block you could hit a block, which might fracture with a bolt into it, or hit a beam, which is very hard and has tendons in it, which on wouldn't want to cut. But for a stair with only downward leading, you could simply rest on the base with no fixing. -
Me please, I said it too. I'm afraid most of us write something casually sometimes: I know I have annoyed without any such intention. Its the nature of the Hub.. we are not writing word perfect theses. -
It will be fiddly. I think you need to cut out a square of the screed, without touching the pipes. Then cut down through the pir to expose the structure. Then you will see whether you are on a block or beam. Fro there it is simple to form a concrete plinth up to floor level. The size of the plinth will depend on the stair load and floor capacity, which your SE must advise. OR a large plate that can bear directly on the screed. Again requiring a calculation. That may be ugly or "honest" depending on point of view. -
He is supplying and including the adhesive and grout. I'm pleased about that because the best tilers in the past have also insisted on this. I once helped one by mixing up the packs, fetching and rotating for him when the pattern was complex. He used very quick setting compound which would have scared me... holding and adjusting a tile with one hand while preparing the next. No spacers or packing. The tile suppliers all seem to want to sell adhesive... but how many tilers are happy with that?
I never came across the slightest hint of corruption. But maybe I don't spot any hints, not thinking that way myself. (I'm forever seeing social media comments blaming everything on 'brown envelopes", presumably from people who would if they could.) However, I have come across ignorance and misplaced self- importance esp in LA inspectors.* It surprises me when I occasionally see on here that a BCO has given a self- builder advice, as they do spot checks, not thorough inspections. My guess re the now required registration is that some authorities or businesses were delegating to juniors or other unqualified staff, so that had to stop. If there was any criticism in Grenfell et al, then I've missed it. * one such young LA chap told me he wasn't accepting block paving in an industrial yard. I asked him why and he blustered some nonsense. So I told him I'd get an Engineer's letter to him. He responded that I needn't bother as they'll write anything they are asked for. I did a how dare you rant, but wished I could have got him sacked. Readers , I was that Engineer but was probably dressed other than he expected. So yes, there need to be standards for a BCO, and I hope they have risen. -
Update. I have found no evidence that a decoupling mat provides benefit on a well constructed concrete or screeded floor. Our screed has one tiny visible crack and of course it will stop moving. That on an area of over 300m2. All rooms were already formed in stud, and had foam perimeters so the screed is not stuck ro walls. Had a tiler in to look. He has agreed to quote without a decoupling mat, and will include a flexible adhesive. He has never seen a case of a cracked tiled floor due to absence of mat. Moral I think is: Decoupling mats are for poor quality newbuilds, or a rushed programme or 'peace of mind'. It makes money for the seller and tiler. Btw the tiler also says the dips and ridges that look rough to me are just normal, and part of his job to lose by double buttering. Ie no latex levelling. A good day so far.... now let's see his quote.
Could you explain please, or perhaps its your circumstances? I'm no expert in PH, but surely a big window facing south is going to blow the principles re solar gain?
Seems to be a "Who to complain to" list. Only Architects from the construction industry. How odd. If you work with fluorine gas there seem to be multiple regulating bodies.
