But then the plasterboard must touch and be sealed at the interface. It's a compromise. I think you are OK unless it is a recording studio, or a bedroom under a gymn.
At my wits end with brick layers. Advice please.
saveasteading replied to flanagaj's topic in Bricklaying, Blockwork & Mortar
Ahem. I spent 3 horrible days under a Boots factory. Damp smelly and 3ft headroom. Using a water level, as lasers hadn't been invented. The water settled in seconds on each of the several hundred occasions. Perhaps it is proportional to the diameter and length of pipe. As mine was mostly lying flat on the solum I assume this dampened the movement. -
Otherwise a lake would be higher on the sunny side than the shady. -
If you consult them early, they can assess off plan, and that is the time to change the design or argue the niceties. We've done that and established that we don't have technical disagreements, and had some good advice. The assessor is highly engaged in interested, including alternative opinions.
I'm always researching for you all..... I went in to a Spanish diy store yesterday. Think b and q with more emphasis to trade. Eg lots of plumbing and electrics that would be from survivalists in UK. They are revamping so there was less solar to see than is on their website. But I could have bought from a big stack, a 440W balcony panel, for €449. That simple. Trolley, checkout, take home and plug in.
3 years later Does this take the record for a prolonged topic? @Gus Potter having a catch-up. I've recently done some drypack and some poured and learned even more. But I will relay that if the subject comes up again.
We have this issue. A patio door opens on to an area that has to be low fof drainage. As levelvaccess is desirable anyway we are intending to make the area from slabs or large tiles supported by mapei pedestals. They leave a gap fit drainage. Maximum grade is 5%. I can't say this works for you but it may he an option. There is another manufacturer too.
Is that picture showing what we are discussing? With the polythene my wetness point is silly. Maybe it could do with more clips, or just screws, where there are no pipes, as anchors. Maybe this is a job for the fibre variation of screed.
I'm thinking of the rb to joist connection. It is timber so needs a timber screw and I hadn't considered they might use a drywall screw.
Resilient bar has always worked well in practice. If any noise gets through it will be flanking sound, coming between the wall and ceiling interfaces, so follow details.
Type 1 or recycled crushed for ground bearing slab?
saveasteading replied to flanagaj's topic in Concrete
I'd be ok with that. Because there could be voids I agree with 75mm capping but not all sand. Thick sand ruts and gets footprints, and so concrete can dip into it and the slip property is lost. I'd prefer 50 or 60mm of type 1 or 2, then the rest in sand. -
As nick says. But if the spec says 1 screw then that is what you should do but only with very good screws with enough thread. Why? The rb works by minimising direct contact. What there is, is offset by that loose-hanging Z of the bar. So when it vibrates it is a wibbly wobbly reaction rather than direct and in phase.
I will be perfectly happy to miss the egg box at about £6/m2 and labour. Thinks. My instinct is that the screed won't adhere to the woodchip floor properly, whereas the egg boxes are screwed or nailed down. Will the wet screed interact messily with the woodchip? Will ufh clips fix neatly and securely to the floor? Chipboard may flex. Opp argument Screed sticks to anything. It will be set in 3 hours and there is very little free water. Clips.. we can test that. Flex. But it won't unless we drop the piano. Cheaper, quicker.
You could Poss use skinny ply to the whole landing. Filler under the worst of it. Then smooth off at the perimeter.
Not at all. We are allowed logic, hunch and gut feeling. And wondering. It stops us walking over things that look flimsy, without calculations or test certificates.
I had exactly this issue on a previous and very old house. I skimmed it level locally using latex screed. It lasted for years and may yet be there. BUT I haven't seen this product again. It came as 2 parts if I recall. There was certainly a bag of dust and there may have been some liquid additive. The finished product was very flexible, almost like a soft shoe sole, (ie latex) and that will be why it stayed in place. I'm hoping someone else might know what it was. 'Latex' screeds now all seem to set hard and brittle. It was almost like a layer of bostik. Thought. What about wood glue? The kind you buy in a tin.... evostik?
Imagine how much character some of us must have.
Absolutely. This is little understood. In fact there used to be false, or musleadingly vague, assertions about the effect of shiny faces on plasterboard, pir, and that loft wrap multilayer stuff I won't name. These have now been dropped but the rumour lives on.* It is is still implied that the aluminium layer within an underfloor heating pipe is doing this, but it isn't. I've burned the plastic off an offcut and found the inner pipe is surprisingly robust, ie not like kitchen wrap. I don't know what it is for.. it helps it hold a shape but also makes it vulnerable to kinking. Back to the question... some of these crates do have pockets of air but I doubt there is much/any benefit in foil. It's not as if the heat is being lost outdoors or to a neighbour..... it would only heat the ceiling void at worst, and only once. * @Mulberry View do you mind sharing where you heard of this supposed benefit? ** I once went to a presentation by superfoil, arranged by the local bco. (It was a short walk and free buffet). I was itching for the pitch on reflective aluminium but he didn't mention it, just another new product which I haven't seen since. Btw they measured insulation in their own way. I'm not saying it didn't work, but bubblewrap is cheaper.
Indeed. There are lots of versions with more of less plastic/voids. We have decuded not to put acoustic underlay because our ceilings will do that work, but it's a nice idea. The screed provides density for heat absorption and spread, and also against footfall noise. And the screed is ready for the finish, most of which will be tiles. We are not insulating under it as heat rises, and any going downwards will meet what is coming up through a dense ceiling/floor. The downside is that any area without heating (passageways, wardrobes) still needs the same thickness.
I'm going to have to think about that! The hot half expands so much that it is higher? -
Excuse me grinning at this. Crush and run sounds like the worst of recycled aggregate. From a quick Google I see,though, that it is a fairly commonly used term, presumably from mishearing and repetition. I just had never heard it said this way. The tech term is crusher run. I have always understood it to mean "as it comes" . Thus it is great for haul roads and heavy duty parking, but not for precision as there isn't a graded mix. 75mm crusher run will be everything that went through a 75mm grille. That would feasibly include long lumps, and will vary according to the original material. So @mjc55 you were lucky or the guy had seen it. -
That's my point. New panels may be different shades.
Why we need "Net zero"
saveasteading replied to Beelbeebub's topic in Environmental Building Politics
It's not. If nothing else I'm learning that lots of intelligent people listen to and are swayed by the implistic publicity that we can drill and solve everything. -
As discussed elsewhere, I have little respect for decoupling mats, . We are going for upstairs being normal chipboard, then egg box overlay with snap-in ufh pipes, then screed. Tiles on top. If it was only for a small area of bathrooms I'd be thinking of electric mats with timers.
If the missing panels are coloured ones, beware of a colour match risk. Tell them the coloured panels must all be from the same production run, or get a written guarantee.
