saveasteading
    93
  1. Are you sure it is an sds bit? They rattle about, deliberately, as a cross between drill and breaker and I'm not sure they drill precisely enough for this purpose. The screw has to cut itself into the concrete. Might be wrong.
  2. These are specifically for concrere I hope. If so, then I'm sorry but there is something dodgy about structural fixings without instructions. These are hitech products and will have precise requirements. Too big a hole and they won't grip...expensive collapse? Too small and they won't fit and may damage the thread. Perhaps buy some new ones.
  3. It will say on the package and needs to be exactly right. It's worth getting a new, big brand, bit.
  4. Thanks but the plumbing is working fine, it's the lever that came loose. I may need a new screw if the thread is damaged, and /or or have to glue it back on.
  5. That would be tidier but not a statement. You don't know where my smaller molegrips are do you? The fixing screw was loose but won't tighten again. It's all soaking in vinegar to lose the lime crud...not a problem you get in N Highland. I'm told the very nice sink came with the tap for a very cheap cost..much the same as a branded tap would cost on its own.
  6. The kitchen tap broke last night. Q. Must be fixed today. How long will it take? A. Between 10 minutes and 3 days depending on where the mechanism has broken and what shops are open and have stocks. 20 minutes later it is solved with a new lever. I think this qualifies as Art as well as plumbing.
  7. Yes, spell it out. Bullet points make it easier to read and absorb.
  8. Their official email address will be public knowledge. An easy cut and paste from the above. The parish council are an advisory role only. The district Councillor has clout.
  9. I understand that multiple electric car chargers can also sort themselves out in some way.
  10. Planning officers aren't always great at technical stuff, even such as whether something fits. And they tend to leave traffic stuff to the highways dept.....who only care about main road safety. If in any doubt, send them accurate and annototed sketches showing why it doesn't work. Some planners arrogantly ignore the parish council. If you can get your borough/ district councillor to back you then the planners have to respond (officers report to elected representatives.)
  11. You need someone with more experience then. Do you have a schedule of the power needs? Ask for it. You don't just add it all up. I think the term is divergence, for not all toasters, hairdyers etc being on at the same time.
  12. OK thanks team. I'm having a few days off the subject, with family visiting I have other priorities and don't want any unforeseen consequences of a job half done. I'll still be dealing with other people's problems on BH which is much easier.
  13. I think we know the answer. A gutter and dp to a recognised design and properly installed will not overflow. An old one might, because of recent changes in rainfall. This one is sortable but needs some technical skill. @Paene Finitur can we have your thoughts and response to whats above? The answer is probably in there. It's OK to acknowledge and say , let's have a few days off the subject.
  14. We wanted 3 phase because it was adjacent. £40k upgrade. Fortunately someone explained that the existing transformer provided plenty. That is for a big house, all electric. That probably applies in this case.
  15. OK that is normal. The project has gone for costing and been costed and sent to you. That person doesn't assess whether the installation would then, or may perhaps, be used to supply other customers. You must assess the likelihood of this and ask them to charge you only a proportion. A different party will decide. Is it likely? If not, then it will be all your cost. I've done this successfully for a 200k transformer, which very clearly was oversized and would be used again....and it was. But I think we engaged a specialist.
  16. My thoughts, additional to the good advice above. Usually rain is fairly vertical and not severe. The water will run nicely down the slope and not go in. In very severe storms and especially with wind, it might drive up between the tiles, but it is unlikely as the overlap is considerable. Then there is the membrane to catch it. We cannot know if the membrane is intact and lapped properly. The eaves and gutter is a mess. For now I would cut out an overflow from the stop end so that any extreme flow can escape...into a butt perhaps. An additional downpipe may solve it. More on that if requested. It is a plastic gutter. They often distort. Can you check if it is in a straight line or twisted....the lowest point will shed water, perhaps inwards. Is the gutter on a slope downwards to the pipe? Downpipes work very much better with flow from 2 sides. You have the additional pipe shedding onto this roof....lots of water at the wrong end from the downpipe. PLUS the flashings are random here....extend the lead fiwn to the gutter and complete the longitudinal flashing. LABC would say that this was built incomptetently and they don't cover that.....unless they had checked it....had they?
  17. Vents up the chimney via a slinky duct? Then you can pack around it.
  18. Ahhh...most chimneys have redundant fireplaces....I made a rather huge assumption.
  19. No. But a polythene bag stuffed with fibreglass will stop your heat disappearing up, and also mute the noise coming down.
  20. Yes, you need to weed it and remove dead things, and infill dead areas. The loading from wet moss isn't significant, unless with gravel , but it is from turf which will develop. The roof membrane is a different spec to resist roots, but I recall that it is not UV proof so there is a lap. I did a calculation once to prove to planners that a green roof was not the optimum for sustainability. The effect of the load on the steel building added tons of steel and concrete. Plus it kept water back from the rainwater harvester. And then there is safety and access.
  21. From my observation of stick build in the Highlands, it was very quick and good value. It's what they did, and was second nature. There was no factory element just a stack of 4 x 2, another of osb and some glulam for the ridge and hips. I wouldn't expect that in SE England though. And the reverse applies for brick and block.
  22. I'm going shopping apparently. I'll read all that clever stuff later....thanks all.
  23. Yes that's the plan. I was hoping for such an obvious bit of damage so it's good news. I need advice now on an acceptable way of patching in a repair, eg the boxes. They seem appropriate to me as I can fix them to the joist to avoid any trailing cable. I did, including after the visitors left, taking multiple chargers with them.
  24. I'm down this way, nearly France, but electricicles behave the same. Good reminder. It was Wagos that the electrician didn't like. I had done cabling on another daughters old house and asked him to do the final connections but he replaced them all. I will take advice from @ProDaveor other experts if they would please advise.
