Plumbersmateuk
Personal Information
  • Location
    Kent, Plot Middlesbrough
2108 profile views
Plumbersmateuk's Achievements
Regular Member
Regular Member (4/5)
40
  1. There is a thread on here where somebody did the same and got their refund
  2. I would be interested to know how you get on if you don't mind.
  3. Just be careful what brushes you use (if you use any at all) where the door goes into the wall. Mine are a tad to noisy and will use something softer next time
  4. Ah yes I did register with beta one.
  5. I use Chief Architect..........Are you sure their planner is not working I used it last week.
  6. Same here Again same for me apart from I didn't think it was PITA, I immediately thought of the VAT reclaim
  7. I did..........I put pull out wire baskets in one of the base units and a pull out corner unit https://www.bullerltd.co.uk/blind-corner-optimiser.html The carcases are a standard size so I can't see a problem?
  8. I only used the wall units above the desk in the same materials.
  9. When I got mine the delivery charges were different. I had 2 man delivery which was during a really bad winter and they (the 2 man team) were really good. They kept me informed of their progress and when they eventually arrived at 8.00 in the evening, (they had to reverse up the road beacause of the snow and ice) they were most apologetic and nothing was to much trouble whilst I was making them hot drinks. they were ambassadors for the company and I have not had any problems with the units and they still look like the day they were put in. I bought enough units for the kitchen, utility and an office.
  10. Just out of interst what paint did you use this time?
  11. Oh I could do with some of that right now Many thanks for the advice it sounds a bit technical so I will have to do a bit more investigation and reading
  12. Many thanks..........can you leave the set up overnight (I see on utube that the nozzle is kept in water for short periods of time), the gun nozzle in water and the paint coverd? or have you got to clean it all each evening?
  13. Thanks for the info, it is my prefered method, airless spray that is. What ratio would you suggest for new plaster?
  14. Really pleased for you ....now get down to Lidl they have some "Arestel" cheap this weekend and celebrate
  15. Yep me to, fingers crossed for ya
