jpinthehouse
    1
Everything posted by jpinthehouse
  1. Hi Ceiling height 2.3 and not to bothered about the cooling side of it John
  2. Hi Utility rm,open plan kitchen dinner and normal ceiling height John
  3. Hi Just about to start looking at mvhr supplier, any recommendations and which system. House is 310sq m . Integral garage, two ensuites,one bathroom,one cloakroom. Thanks John
  4. Hi Anyone used Cedar cladding, untreated so that it greys. Some pics would be nice If so we're did you purchase it John
  5. Thanks for the replies,I'm not sure whether the felt goes under the counter battens onto the pir insulation or under the battens that holds the slate Thanks John
  6. Hi The details I can find for a warm roof are quite different with regards the roofing felt, what have others used John
  7. Pro dave What do you think of them and would you have them again John
  8. Hi Has anybody had rational fitted Thanks John
  9. hi We have the same problem because of the bad weather, we are going to run the planer over the high spots, mainly the joints
  10. Hi Have had quotes from rational and Aluk, not sure what to choose composite or aluminum,whats your thoughts, need to get this right as its a costly investment Thanks
  11. Hi Juj Who are you having provide your windows and did you go for Ali Thanks John
  12. Hi Had a very competitive quote from a company using Aluk, Ali window system, has anyone had there windows using this system Thanks
  13. Hi Decided on guttering, now need to choose fascia anyone else used it,if so what Thanks
  14. This is my first self build ,it's in our garden,we started on the 1st December,as we all know we have had really bad weather. I treat it like a job as do others. Work 8.30 till 4.30 when not at work stop for crib and lunch and DON'T work weekends ( I work shifts) Due to the trades we are using sometimes ,there is no one here so I tidy up,order materials and put things in place so the paid trades have work to get on with. The biggest question I get asked is when will it be finished ,i say hopefully December this year but it's not a target it's finished when it's finished if not before Time off is the key, work live balance even on a self build And reading this forum
  15. Hi I'm looking at lindab or evolve gutters and evoke Ali fascia,any one used them, what's your opinion John
  16. It's supporting the gable end, timber frame and 4inch block, it's giving us an open plan kitchen dinner with no middle supporting post. The beam is 9.5 metre long by 612x304 sitting on two 120x120 each end.
  17. it's the dearest ladder I've ever bought
  18. Hi Steel has arrived, for back of house with crane coming tomorrow to lift it in
  19. Hi Day 15 of building and erecting timber frame, 1st floor joists and nearly all flooring laid, steel arriving next week to build rear wall, then roof craned on
  20. I use paslode as its used a lot, the other manufacturers have caught up now so bang for buck its Hitachi or dewalt especially if not used for your main job
  21. Trying to find a drawing of dpc window detail, just to check what I'm doing is right, also I have a 50mm cavity so has going to use 38x38 treated timber or should I be using insulated cavity closer then strapping windows inside John
  22. We moved our b and b beams which are 4.8 metres long, two seat belts as strops, put a loop in them, piece of 2x2 through loops, four people, and we moved them about 25 metres to the back of the house, over the foundations
  23. I'm putting 150 mm celotex or similar on top of my b & b floor, then a screed floor
  24. Hi Looks interesting, have recently been involved with a barn conversion, they tanked the internal walls, then a insulated timber frame, inside the barn which was built on a concrete slab
