Oz07
Everything posted by Oz07
People will actually be sad when it blows up too. They like to see the cooling towers. Its all just insane.
Reliable, secure, plentiful
I still can't believe we are going to blow up ratcliffe on soar power station. I wonder if we will ever start using coal for electric again in the uk
I did a Dunster house for someone that was excavate, membrane, compacted type 1, gravel grids with 10mm pea gravel.
What about the undiscovered quantities i keep seeing being talked about. There could be a lot more than what is known?
Registering a site with Openreach
Oz07 replied to Bancroft's topic in General Self Build & DIY Discussion
I just emailed some local office, god knows where I got their email and they dropped me loads of bits off. It was all very informal as I remember it around 2018. Last place in 2020 I didn't even bother with a fixed line connection. It wasn't in the regs then. Is there any way to opt out if it nowadays? I still use 5 and 4g for Internet now -
Whats the craic up there then? What do you have to have and what is extra?
I think this is a regular thing. Even I've had that vibe lately.
? Ive not had any drawings done yet as not decided who im using yet. Hence the thread
@Gus Potter i dont need any project management. I will sort all applications with utilities and highways. All I need is planning and building regs. Plot will be BNG exempt.
How long is a piece of string but generally what are people paying for architects? Ive always used a riba architect previously and also had a PCC off them too. I think excluding the PCC I've usually paid around 2% of build cost. Not that the deal is a set % of build cost its just that's where the quote has come in. For planning and building regs no project management or anything like that.
Volumetric guys do this regularly ive found. I've called them out on it before now. I reckon they get told to because the mixes aren't upto spec. Your footings will be fine.
This is why I said to use connected firms for pump and crete. Better still if same company supplying both. Incentiveised to get it done then
Not ideal but I'd stop worrying on this. Its not going anywhere. 30mm a metre I bet a lot worse has been done.
No it will be fine. One place I built had stepped footings from 2.4 to 1.5 due to trees. Top of conc all level.
Landscaping - Bank Edging Replacement
Oz07 replied to BOSullivan's topic in Landscaping, Decking & Patios
What about reclaimed sleepers. The proper old ones. They look better and last longer. Still get a gentle curve with them -
I dont think its a problem. You step bottom of footings all the time when trees are nearby. Any pics?
External camera to record the progress of the build
Oz07 replied to Indy's topic in Networks, AV, Security & Automation
Sorry to drag up old thread. How do you know if the model reolink camera you're looking at does timelapse? Also with these if I have an sd card how much storage does timelapse take up per day/week/month. What's a standard photo rate one every few minutes during daylight hours? Can the reolink camera be hotspotted to your phone so you can download the data without having to fetch the sd card out of it. Even if no WiFi locally. -
How big is this house 🤯
How do people get on with solar panels if not shown on planning? Anyone ever had a pull on these?
I meant buying melamine, mirrored doors and hanging rails etc. If you have supply and fit it would say fitted robes.
Invert levels for rest bend that exits straight out the house?
Oz07 replied to flanagaj's topic in Waste & Sewerage
Lower the better in some respects, like you say just dealing with a 4" hole thru membrane then not trying to make good round half a bend. You could bring it out the wall above your membrane if thats below your insulation layer and lose the pipe in the insulation. Tbf how tall is a rest bend 450mm ish? That doesn't put the invert too deep once you add insulation plus slab. -
What about if built into the building like the aussies do. Plasterboard and skim the alcove, set of doors on the front with shelves and hanging rails. Suppose its easier to get more elaborate wardrobes thru if buying materials separately as it won't be a specific invoice for "fitted wardrobes"
