Alan Ambrose
Everything posted by Alan Ambrose
>>> can't select a sd=7.5m VCL BTW you can creste your own materials in ubakus.
Opinions please on this quote for substructure & drains.
Alan Ambrose replied to Tony L's topic in Foundations
Hi, @Tony L - is it possible to report back how this went, with any knowledge / tips that you gained? We may well have a similar situation. -
Building Dispute with contractor
Alan Ambrose replied to James Frome's topic in Costing & Estimating
>>> depends how mickey mouse the whole setup is from the start. Client - well meaning but properly naive and just hoping the gov will pick up any overrun. Gov funder - has a bunch of lawyers, contracts and procedures, is properly slow, and also fairly naive about the ability of the people they give the money to to actually execute the job well. Contractor: work a bit slapdash, spun the client a tale about not being able to know whether they were on budget/timescale until a few weeks before the original completion date. Contractor's QS now going for the jugular to the tune of £0.5-0.75m. It is government money after all and the bosses really want some new Range Rovers. -
Hmmm a bit of game that DNOs play, some more hardball than others. Yes, of course they'll remove their equipment / no, they cannot say how long before they get to it / yes, they'll be happy to give you a quote to move it in a shorter timescale. It is their business, and yes they're pretty good at this game. How long are the cables / what kind / how many poles? Before I bought it, my plot had some cables moved from overflying to underground and one new pole put in. Original overhead route was ~43m, new underground route was ~31m, one extra pole, cost £16.2K. This was UKPN.
Octopus Energy tariffs
Alan Ambrose replied to Adsibob's topic in General Self Build & DIY Discussion
>>> Apart from the reliability, and nuclear is very reliable, I cannot see a case for it in the energy mix anymore. I just read No Miracles Needed by Mark Jacobson, the Stanford guy, and he comes to the same conclusion. From memory: more expensive than renewables, to slow to build to make a difference to climate change and, of course, security and contamination risks. A weirdly written book though - it may have been pitched at the lowest common denominator of US Congressmen. In fact, on page 57, he says 'I agree with @SteamyTea on this'... -
How do these traps get emptied and how often typically? BYW re shape, you can almost certainly arrange these in any shape providing you stick to the right invert level for the inlet pipe.
>>> Any recommendations on which to get? Leica Disto maybe.
Yeah I have two bathrooms with electric heated floor and epoxy over. I quite like them. Would have been even better if I had worn my glasses so I could have seen the tiny bubbles on one side...
Yeah, I hope they find a way to build more houses, but pretty much every government for the last 50 years has made housing 'a priority'. Also, you have the entrenched planners, appeals system, nimbys etc in place and even if you invent new policy that doesn't mean you will change the system at all quickly.
Why does it read 10V when it's off?
Alan Ambrose replied to Gone West's topic in Consumer Units, RCDs, MCBOs
>>> ghost voltage I'm thinking it could also be a crossed neutral. You have RCDs in that consumer unit? Another simple test - turn CU on and all MCBs off. Your stray voltage should be zero. Turn the MCBs on one-by-one leaving your suspect circuit til last. See when the ghost voltage turns up. -
HELP, failed perc test and on clay soil
Alan Ambrose replied to nowtie's topic in Rainwater, Guttering & SuDS
I would dig as deep as possible with the JCB not for perc test but for DIY soil investigation. Maybe the extremities of the plot and one in the middle. As I said, you're looking for anything sandy or porous at any depth to begin with. -
I sometimes use a shipping service (myUS) to ship stuff from US to UK where the supplier can't be bothered to do the customs stuff etc. Works well, not cheap but you can consolidate several orders if you want to make it more cost-effective. There are similar services from other countries.
Goodness. Except where you're craning in huge windows (I'm not) I plan to do myself. Just read the number of dodgy installs detailed here on BH by 'professional' installers. >>> want the supplier to measure and take responsibility for any errors Buy yourself a laser measure and check a few times. Control your risks, have a backup plan etc - it's not rocket surgery.
A couple of other easy tests to do: + Switch off the MCB and leave for 10 mins or so. If the 10V goes away, then it was likely just charge being held in some LED power supplies or similar. + If possible, turn the whole consumer unit off and see whether the 10V goes away. If so, there might be some cross connection e.g. on the neutrals, between circuits. >>> the other circuit connecting to the junction box was removed some time ago I might also be inclined to double check whether this was fully disconnected. Know what that circuit was used for? -
Hi, reading back, did you ever have a soil investigation on your own site? I see the mention of sandstone on some of the records above and wonder whether there's any prospect of finding that? If you have a JCB, I think I might be inclined to dig the deepest hole I can in the extremities of the plot and look carefully at the spoil as it comes out. Anything remotely sandy may well signal success.
It's a bit odd - are you using an auto-ranging meter and is the number actually 10mV? These are lighting circuits? Does the 10V persist for a while e.g. a minute? -
I'm cautious about bonfires - I don't know whether the 'authorities' could claim that as 'contamination' at some point. Anyone know for sure? >>> Maybe 50% of that or less if most can be done with a small tractor and a flail mower Actually, I think that should be 1/2 day or less with that equipment >>> An option is to have a digger in to strip the topsoil and everything in and above it. Might that be construed as 'commencement'?
Sorry to divert the thread a little, but it is still on the subject of determining fair overrun amounts. >>> 2.5M without any bank borrowing ? Unlikely. It's a cladding project and mostly paid for by the government. No borrowing or bank QS. The contractor refused to give any progress on time or budget until a few weeks before expected completion. At that point the QS went in very aggressively with a 10 week overrun on a 27-week project plus scope to overrun further. The QS has supplied no calculations. Minimal extra work has been discovered to add to the project costs. The client has never run this kind of project before... -
It’s a bit weird isn’t it? Considered turning the heating on in my shed for no other reason than just to make a few quid. Decided that was ridiculous. -
Incorporating solar into modernist shallow pitch roof?
Alan Ambrose replied to flanagaj's topic in Photovoltaics (PV)
Actually it’s not such a big deal to put panels flat on a flat roof - a techy neighbour has that set-up. Again pvgis will tell you exactly. -
Crazy system penalising wind energy
Alan Ambrose replied to saveasteading's topic in Environmental Building Politics
>>> how can it be sense to pay the turbine company when they turn them off because of too much wind or over production and pay them for the electric they are not producing I’m hoping this policy will be extended and someone will pay me for not building a house. -
In 20 years time you may want to replace the panels (falling efficiency of older panels / lower cost / better technology available) and probably the trays (the plastic will be brittle and probably the wrong size for the new panels). That is, pretty much re-roof assuming you've crowded your roof with panels. At that time, might you may have wished you did the on-roof thing as that probably only involves replacing the panels and bolting them onto the old rails?
