Alan Ambrose
Everything posted by Alan Ambrose
A "lighting design strategy for biodiversity" :)
Alan Ambrose replied to Alan Ambrose's topic in Planning Permission
Thanks. I might try the DIY approach as we don't have much in the way of wildlife or much in the way of lights planned. I have a camera there (Reolink Go Ranger) which spots bigger wildlife fairly well - well walker's dogs anyway. I've seen one ordinary newt hiding in the cap over one of our SI bores, birds in the hedge and a couple of sightings of vole or rat-like things. We also have a couple of molehills. I'm told there are muntjacs around but never seen any evidence. At our current place we have a light either side of the front door and that's about it apart from the xmas lights . @DownSouth - did you have some fancy light cone images in your doc? -
@PNAmble - I just noticed your post. I want a set-up like yours. Can I ask: + the DNO and Openreach were ok with them in the same cabinet, or didn't they know? + you have your meter and main switch / fuse block somewhere else? + your little CU is the 'main distribution CU' to your garage, house etc with MCBs and no RCDs? Anything else you can tell us? Looks a good setup.
>>> or my behaviour is being discussed đ
OK by great algorithmic genius (hmmm) ... using 1 star for 'living in', 1 for 'building in', 2 if you've only specified one place, I have this at present. So, anyone suggest a good pub in, say, IP14? Kings Arms in Haughley? The Bull in Bacton?
Suggest you read the threads here using "CIL Legislation" as the search term. The CIL legislation uses phrases like principal residence and sole or main residence. (You can always read the legislation yourself.) These don't seem to have been tested in the courts much yet (for CIL). IMO LPAs seem to make it up a bit re CIL and CIL teams are often quite aggressive, so they may fancy punting it in the courts. I have had one otherwise competant commercial property lawyer say to me "we can't advise re CIL" as though it were not part of property law. So, you could easily find yourself being a test case. Fine if you're OK with that. Of course, you could ask your LPA's CIL team first if you want to be sure ... but then you've put them on notice.
OK, we have permission now. It will probably take me months to recover from the PTSD caused by 1 year of purchase shenanigans and 2 years of planning BS. Most conditions are standard, but I was surprised to get this one below. The plot is in a hamlet in the countryside and currently a bit of old pasture with grass, 3 trees at the back, one old apple tree in the middle, and little else. Anyone had something similar? 5. Prior to the installation of any external lighting a "lighting design strategy for biodiversity" for development, the new building, and features or areas to be lit shall be submitted to and approved in writing by the local planning authority. The strategy shall: a) identify those areas/features on site that are particularly sensitive for biodiversity likely to be impacted by lighting and that are likely to cause disturbance in or around their breeding sites and resting places or along important routes used to access key areas of their territory, for example, for foraging; and b) show how and where external lighting will be installed (through the provision of appropriate lighting contour plans and technical specifications) so that it can be clearly demonstrated that areas to be lit will not disturb or prevent the above species using their territory or having access to their breeding sites and resting places. All external lighting shall be installed in accordance with the specifications and locations set out in the strategy, and these shall be maintained thereafter in accordance with the strategy. Under no circumstances should any other external lighting be installed without prior consent from the local planning authority. Reason: To ensure that impacts on ecological receptors from external lighting are prevented
I believe that most LPAs ignore local objections unless there's a dozen or so. They assume a few people will always object and most of the 'objections' are not on planning grounds so they are ignored. I'm amazed that even 'nice, kind, worldly neighbours' often can't see beyond they're own petty interests - a lot 'want more houses to be built'. Yeah but not next to them.
Can you use CO2 footprint as argument at appeal?
Alan Ambrose replied to flanagaj's topic in Planning Permission
Of course, you should get an advantage with sustainable design, but it seems to play little part in the planners' thinking and also they don't have a 'points scoring system' for weighing up a balanced judgement. The planing system behaves as though the issues are black-and-white and everything is 'policy' when, of course, it can't be and isn't. By and large the rules are written for large developers (IMO) and they want to build min building regs designs. -
Attaching breather membrane?
Alan Ambrose replied to junglejim's topic in Structural Insulated Panels (SIPs)
Tacwise, of course, have all sorts of cheap electric staplers and small nailers. I think manual, electric, battery and air driven. They have stainless staples also if you need them. I have a couple of the small electric staplers. They need a bit of downwards pressure. No safety nose on the ones I have so Iâm careful with them. Useful for fixing into softwoods and can take small brads too. -
@Jeremyw @G and J @olley @LSB @zzPaulzz @DIYHacker @GaryChaplin @Nick Laslett @JohnnyB @marshian @FuerteStu Anyone interested in a Suffolk meet-up? I'm thinking maybe 1st Thursday of the month at a pub somewhere in the 'centre'. If you are, let me know your post code prefix so I can figure where the 'middle' is? We're living in IP6 and our plot is in IP17.
In fact, most sustainability credentials are irrelevant to the LPA unless they have a specific concern/remit e.g. biodiversity or external lighting vs. wildlife. Think you'll get brownie points for your Passivehouse spec? By and large, no. -
While looking ahead to 2030 and beyond, electricity demand is expected to rise as transport and heat are increasingly electrified via EVs and heat pumps (see below). According to NESOâs recent advice on reaching clean power by 2030, demand for electricity is expected to grow 11% by 2030 and to nearly double by 2050. https://www.carbonbrief.org/analysis-uks-electricity-was-cleanest-ever-in-2024/
And why on earth would you imagine that the British use British Thermal Units? đ I guess we did in the 1900s. They are useful though - see the following equivalents: One Btu is approximately: 1.0551 kJ (kilojoules) 0.2931 Wâ h (watt hours) 252.2 cal (calories) 0.2522 kcal (kilocalories) 25,031 to 25,160 ftâ pdl (foot-poundal) 778.2 ftâ lbf (foot-pounds-force) 5.40395 (lbf/in2)â ft3 A Btu can be approximated as the heat produced by burning a single wooden kitchen match or as the amount of energy it takes to lift a one-pound (0.45 kg) weight 778 feet (237 m).[16] p.s. BH members were mostly all brought up on a healthy diet of Monty Python.
Itâs a BH tradition that we donât answer the exact question thatâs been asked. Instead, we riff on the theme like a seasoned jazz band đ. Think of it as a more creative process than straight Q&A ⊠akin to âartâ.
MVHR & Wood Stove
Alan Ambrose replied to Marko's topic in Mechanical Ventilation with Heat Recovery (MVHR)
It probably depends on the exact geometry, prevailing winds direction etc (you donât say whether the chimney is on the ridge or further down) but I would think yes it may well be a problem. Not too tricky to move vents elsewhere? I guess you could rough test it using a smoke source and then see whether the MVHR draws in smoke in practice? Also, FYI thereâs an issue with internal MVHR vents in the room with the stove - the idea being that you donât want the MVHR to pull the smoke into the room. The latter issue is discussed in several threads here on BH. -
Conduits in concrete slab - making it all work
Alan Ambrose replied to Bancroft's topic in Foundations
>>> Is it worth considering just a single electrical supply out and then putting another meter box in the garage to split all the external requirements from there? As itâs usually much easier to do lines into a garage, yes reckon so, also for ethernet (with a separate POE hub there). In fact, I could see 2 or 3 consumer units - in another thread, someone suggested a separate CU for the kitchen rather than running everything back to the main CU. Seems helpful. -
>>> Do you have a design you're working to yet? Yes, several, but they're all generic and specify MOT1 and I want them to be free draining.
I'll spend some more time talking to the local aggregate suppliers next week when everyone is back. In the extreme, can I make up my own aggregate, say with a mix of stone, shingle and sand?
I read about MOT 3 (e.g. here https://www.cloburn.co.uk/what-are-the-3-types-of-mot-aggregate-and-which-would-be-best-for-my-project/ ) but yet to find a local supplier. Supposing you wanted a fairly free draining version instead of a standard MOT spec e.g. under a driveway sitting on sticky clay, what would you use?
WhiteWing 16 channel DMX relay
Alan Ambrose replied to Thorfun's topic in Networks, AV, Security & Automation
You've seen his youtube channel mikeselectricstuff ? Fascinating if you've always wondered how a PCR / bomber sight / baggage xray works? -
10m sounds a long old way (although I should say that I know nothing about piles ). Poss to post up a pic of the soil layers from the soil investigation?
Pros: + Fewer tiles, so less cost and weight. + Better looking (maybe). + Easier to protect against nesting birds. Cons: + More complex fitting (check out the instructions for choosing trays and for battening). + Harder waterproofing detail. + Lock in to a range of panel sizes when renewing in 20-30 years / possibility trays have degraded by weather or UV and need replacing,
OK, supposing in December you use 90% of your proposed 40,000W / 175A supply. There are 744 hours in December, so thatâll be 744 x 40 x 90% = 26,784 kWh. At, say, 20p per kWh, thatâll be ÂŁ5.4K for December. Maybe ÂŁ30K of electricity a year given that youâll be using far less in the summer? Is that what youâre expecting? No? Why not? So, perhaps you wonât be using that much electricity and maybe you donât need that big a supply. Search for âVeyronâ on the forum and youâll see related discussion around this subject.
