Alan Ambrose
    15
Everything posted by Alan Ambrose
  1. What I don’t understand from the deed is (a) what you’re gaining from the deed (the permission?) and (b) in the event that you both die and your only remaining relative living in Australia doesn’t want to move to the UK (or some other possibility) … what the penalty/result is? Would be interesting to ask a mortgage company what they think about having this charge on the register. Another waste of resource for us and the LPAs - it’s not as if either party is short of resources, huh?
  2. So, for a S78 appeal, we had: We lodged our statement - day 0, month 0. It took us maybe a month to write it. 2.8 months in - it was 'validated'. 5.3 months in - the appeal was 'started' which I think means assigned to an inspector. 5.5 months in - the LPA filed their questionnaire. 6.4 months in - the LPA filed their statement - this was the first time we got to see their exact arguments at appeal 6.9 months in - we filed our comments in answer to the LPA's statement. The LPA didn't file (presumably as they didn't have any extra info). I figured the decision was due about 9.6 months in. I was wong. 12.4 months in - the decision arrived.
  3. Yes, they will file a questionnaire and statement. I think they get copied to you by the appeals system (can’t quite remember). They may or may not file final comments, probably not, because they won’t have any more information by then. You probably will want to - to counter their arguments and that’ll be the first opportunity after you have seen their case. I remember though that some docs didn’t get copied to us, so look out for updates on the LPA’s site.
  4. I wonder whether @craig has any thoughts? Also how you tell a good window from a bad one? We were at the Farnborough housebuilding show yesterday and looked at windows from Internorm and Norsken. I remember Internorm being on Craig’s good list, but actually we preferred the look of the Norsken ones. The question we had in our minds was ‘what makes the Internorm ones better’? Something with the mechanism or seals or insulation?
  5. Yeah the Lizzie line is very good. Someone was smart enough to use trains and tunnels bigger than the standard tube line and not to stop every 1/4 mile. Fantastic work. Victorian in its boldness and quality.
  6. This is specific, but the '20 questions' nature of planning (and now BC), is ridiculous. LPAs get more revenue that way, but it slows the process enormously. Will this work ... many months delay ... no. OK, will this work then ... many months delay ... no. etc Some LPAs and case officers are more sensible, but this is the default state.
  7. >>> I'm going to prepare for the worst though and continue trying to get a response from the LPA I'm guessing that the LPA shelve your application as soon as they know it's gone off to appeal. For 'non-determination' I expect. Others should comment, but I think there's nothing to be lost by submitting the same (or a very similar) application to the LPA. That way, you have both in parallel rather than sequentially. Next time I do planning, I may do 3 or 4 parallel applications simultaneously.
  8. >>> it needs to be much, much thicker This is my material crib-sheet. It suggests, that for the same U-Value, Foamglas needs to be twice as thick as, say, PIR.
  9. Can I ask - are you planning to replace this later, or will it be your driveway base in future?
  10. Worth it just to see their eyes light up
  11. OK hold my beer.... Get your sparks to disconnect and measure the cold resistance of a heater and the voltage you actually have there on no-load (or if they're lazy, just assume 230V). Divide one by the other and that's your inrush current. If you've ever seen an old fashioned resistance heater heat up, you'll remember it takes a minute or so to do that. That is, much longer than any RCBO curve, which are designed for machinery in-rush currents. While it's heating up, the resistance goes up and the current goes down ... until it reaches a steady state. Measure the current at this stage with a clamp meter and you'll know the steady-state current (and hot resistance come to that). Now you've got inrush current and steady-state current. Just size your MCBs/RCBOs accordingly to fit the inrush current (actually cold-state current - there's not really an inrush currrent - that is usually associated with sub-1s timescale). Yeah, probably 20A, but worth checking to avoid further problems. BTW, worth the sparks checking the nominal power of the heaters - on a 16A trip, each is probably 3kW. Yeah, I appreciate they probably dont glow...
  12. I think in practice you may get cracking around the edges, probably not a problem. There's a chance the cracking will venture away from the wall, again probably not a problem. I think you normally put foam e.g. in doorways, to control where the cracking is. Maybe down to thermal, maybe just slight differential movement. Precision machinists have a saying along the lines "everything behaves like rubber in the end" - meaning however stiff you think the part is, it'll bend a bit when you machine it, even if only by microns. If that doesn't bother you, fire ahead.
  13. How the revised formula for assessing housing need is set to leave more councils vulnerable to speculative development The finalised new formula for calculating local housing need has boosted levels in many areas of England, leaving increased numbers of authorities without the required five-year housing land supply and therefore vulnerable to speculative planning applications. And I thought all applications were speculative.... It obviously means something specific?
  14. Interesting ... would you mind reporting back when you're done. Bear in mind: "The pitch used for sett jointing is a specially modified bitumen, intended to be stiffer and more resistant to penetration by spiked heels than a standard bitumen." 😁
  15. >>> the windows can have bats fitted Suggest much easier without bats, newts, otters, voles, crayfish, owls, badgers etc.
  16. >>> I'm fairly sure that the case officer will have to arrange a site visit as the area in question can't be viewed from the road but I have no idea when this will be - will it be after the final comments? Believe so. I think if you say 'I need to be present' then at least you'll know exactly when the visit is. >>> Can anyone suggest when a decision might be made after the final comments? A couple of data points - my householder appeal decision was 2.3 months after final comments (9.3 months after filing), my 2x S78 full appeals were 5.5 months after (12 months after filing). I've no idea how representative they were, but they were not very complicated.
  17. Nice idea for kids . Hmmm, bolts in shear, preferably into steels? Yes, SS if you like, they are used in high load marine environments. If no calculations are done, you could always load, say, 3-5x the kids weight onto them (you and the missus?) and then dynamically load (jump?) to check they're sound.
  18. Yep, I understand the pragmatic approach and therefore just observing and living with the 'rules'. But ... sooner or later you might have the time & energy (or need) to consider who makes the 'rules', who they impact, how they are 'policed' and whether the 'rules' are well made or need changing. I guess that's called politics. In this case I think the CIL laws (The Community Infrastructure Levy Regulations 2010), like a lot of housing 'rules', were made by central government and heavily influenced by the LPAs and big housebuilders to suit themselves. I think CIL impacts the small builder most. I don't know whether they apply to the big builders or whether they get negotiated away in S106 agreements. Maybe someone else can comment. You can bet that small builders and self-builders had little or no influence or consideration. It would be interesting to find out how the self-build CIL exemption came about.
  19. 1.5 weeks now and they still have not corrected the CIL figure that they made in their favour by 9%. How did they do that? Oh, by measuring external area, that's how. Any only other people or organisations who would say 'you have to sign this promissory liability note and then, maybe if you play your cards exactly right, we won't charge you?' 'And f... any little thing up, and you can be sure we'll nail you?' The mafia maybe? Drug dealers? Loan sharks?
  20. Thanks. Was that LA or private?
  21. That's it really. I was hoping to use a phased approach where we sorted the structural and fabric stuff (say to watertight stage) first. And leave the MVHR calcs etc to later. Also, what is there to say about, for example, Part P except use a P-qualified electrician, Part Q except use off-the-shelf doors & windows etc? What have other people done? Does anyone have a good approach to this with a definitive list of BC docs - it all seems a bit vague to me.
  22. @saveasteading 'whomsoever' 😁 You've been reading Dr Johnson's original dictionary?
