Alan Ambrose
Everything posted by Alan Ambrose
>>> New guys argument was they could be accidentally hit. Our smoke sensors here have only gone off when being tested with the aerosol stuff and when someone was vaping underneath them. So, clearly useless. Sorry, I realise that's not much help.
I wonder whether it's still sensible though? I organised a bunch of extinguishers here, which were fine until some dumb 'management company' took them out with the theory that people might be more inclined to hurt themselves. Yeah, don't bother to try to put out your chip pan fire ... let's just let the building burn down.
Self build warranty rebuild cost
Alan Ambrose replied to PSC88's topic in New House & Structural Warranties
A related question. Do the standard providers allow for inflation? - (say) £600K rebuild cost now may well be double that in 10 years time. -
First timers attempting an ICF and Oak Frame house in Devon
Alan Ambrose replied to MCoops's topic in Introduce Yourself
>>> Yes, we are essentially building the house twice. This gets trotted out fairly frequently on BH. So, conventional brick & block isn't? Something else covered with SIPs isn't? Yeah, don't worry about it if it works for you. The other one usually raised is 'green oak expands contracts all over the place, how will you keep it airtight'? Err, steel beams do this too, maybe steel doesn't have a great thermal expansion coefficient. Is this a problem in practice? So conventional softwood stick built doesn't move with moisture? Green oak will move across its width but an irrelevant amount on length. It'll also settle down very quickly. >>> We did speak to Oakwrights about it, but their costs were eye watering FYI - I'm having sensible conversations with them re frame supply only. You can get a rough number for retail oak in £ / m^3 from online suppliers. (Last time I calculated it was £2.3K/m^3.) Then see how much the joint work and erection adds to the quoted price and check whether it's honest. I figure the oak frame guys should be charging about 3x the retail cost / m^2. -
So, this holds the slab while it's setting and effectively makes a void later, protecting from heave? This assumes the trenches are deep enough, secure, never move, and are strong enough to handle differential movement?
I called into The Crown, Stowupland on Sat - purely for research purposes you understand. Had a word with the publican, Mike and booked a table for us in the quieter bit. I'll probably eat, but he said he's happy if not all do. Give me an idea of numbers for Thurs so I can expand the table if we need. I thought we could each spend a coupla minutes giving a sense of where each of us is in 'the journey' and what we're building and go from there. Drawings, pictures etc would be great.
Has it always done this, or is this a new thing? Suggest checking the obvious things first - backup battery, tightness of all connections at panel and at all call points. Also scouring the fire alarm forums … assuming those kind of forums exist. If it’s been doing this from the start it may be a Honeywell design issue. Easiest thing probably is to get the lot replaced - probably not v expensive. Yeah, you could try and do a proper diagnosis, but intermittent faults are notoriously hard. Also, while personally I’ll try to do anything and everything as DIY - making a modification to a fire system, in a rental, even if the manufacturer has screwed up the design, is probably something even I wouldn’t do .
Architects, ballooning fees and estimates
Alan Ambrose replied to Drellingore's topic in Costing & Estimating
A couple more thoughts: + a lot of small businesses are not great at the client stuff. In some cases, you have to manage them. Maybe the quality of the work is so good that you’re prepared to do that - including negotiating their fees. + it may be that they don’t really want to do the next bit and this is their way of telling you ‘we’d rather not’. + 440m^2 is huge even if you’ve got 8 kids. Maybe you won't actually like to live in something that big. + we have a ‘two-barn’ design too - one with bedrooms and bathrooms, one with everything else. It’s occurred to me recently that it would be better to have two smaller plant rooms with the relevant plant in the right place - all DHW, for instance, in the bedroom barn. I also plan to use multiple CUs, hubs etc. + stage 4 is tech design? It’s worth probing what level of skill your architects have in this. Maybe go out for competitive quotes with other tech designers? -
>>> Then it sounds like one part of the council is telling you to do something … without warning you that another part of the same legal entity is going to try to profit from it. Strong letter to head of council suggesting unethical behaviour to start with as such behaviour could be interpreted as a revenue scam. Well that’s a reason in itself. LPA’s may act in a fashion that’s not joined up - but that’s their problem, not yours. Lawyers can also find a couple of reasons that you probably never thought of. Even their engagement will make the conversation take a sensible turn. I think there are a couple of specialist CIL lawyers that have been mentioned on here - a general purpose solicitor may be learning on the job. There’s also a barrister direct access scheme and it may be best to go straight to the horse’s mouth.
You could also have a calm exploratory meeting with the architect to see what you can learn: + your original estimate was xxx. Was that finger in the air or based on a calculated estimate? How exactly did you arrive at that figure? + ditto the recent estimate. + how do they explain such a difference? Is the 2nd figure unreliable also? Are there features in the final design that vastly increased the cost? If so, why were these not communicated at the time? + etc etc etc In any event, it’s careless and bad client handling, which says a lot. I once had a medium experienced solicitor who suddenly wanted to double my bill, without any explanation, for some (already not cheap) conveyancing. I talked to her boss and we came to a compromise. But those solicitors are firmly crossed off my list now. -
Suggest - finish getting the look and feel through planning. Close up the architect’s contract. Keep them sweet in case you need anything else from them later. Then engage an SE, and a technologist to draw the BC stuff and use one of the QS services to cost it up. You can ask the QS what info they need and work back from there if you want. Then go out for actual quotes. None of that will cost much and you’ll have a firm-ish idea of costs at that point. -
There’s not so much love on ‘t ‘ub for oak frame. There are a bunch of oak frame companies in business so someone is clearly buying their products. But those buyers are not on here. Similarly Baufritz houses etc. I have a design with a structural oak frame ‘clad’ with larsen-truss style insulation. Makes a lot of sense to me. The self-build magazines have loads of oak frame builds. Some have brick skins, some clad in other materials including render, oak featheredge etc. SEs who understand oak frame are fairly rare, but some get it. I think it’s fairly common for the frame to support the roof directly, and the walls to be self supporting. The 4 big guys - Oakwrights, Carpenter, Welsh and Border have loads of experience with all sorts of configurations - so pick their brains. You can probably go through planning without making a final choice of ‘cladding material’ - just the look and feel (and constraints imposed by the oak frame). We live in a barn conversion currently and want to get the feel of raw oak (and other earthy materials) in the new build. -
>>> That's US news Yeah, appreciate that, but what happens in California or Germany energy markets may eventually happen here. I appreciate there are some local differences, but the trends e.g. increasing solar and wind / general shift from fossil to renewables / greater electricity consumption / increasing number of big energy-sucking datacentres etc etc etc are similar.
>>> The problem with large panels on domestic properties is fitting, hoists and cranes may be needed because of HSE. Maybe this is also limited, in practice, by the size of the largest trays.
@sgt_woulds - thanks for your thoughts re panel sizes and suppliers. So, do you think we're trending to one panel size now, and, if so, what is it ?
So...I'm about to do Rainwater Harvesting
Alan Ambrose replied to mike2016's topic in Rainwater, Guttering & SuDS
Sounds like a silt chamber is a really useufl addition to RWH. -
Ah here: https://apnews.com/article/power-electricity-amazon-microsoft-power-plants-data-centers-grid-f4763f73bc112425e18f30618dff0039 Interesting, so 2 markets for power: us (everyone else) and the direct attach datacentres who (a) will want a great deal for steady power use and (b) won't want to pay for the network. Yeah, Amazon again...
150mm? Jeez. >>> If I remember correctly it was the way the two materials behaved after they get very wet and how they dry out. It could have been propaganda from either side. Very hard to find honest brokers in materials science. Yeah, I'll write up my research on this one day. Both sides, particularly the EPS guys, are quoting 'research' that is misleading. I gave the casting vote to Glatthaar Keller, who use XPS.
>>> If it's an in roof install then I guess its the detail of how the mounting trays are fixed on the edge of the roof?? Ah good point.
>>> Many BCOs won’t sign off a woodburner install FYI my install was one on an existing dwelling rather than a new build and with LA BC. I sent in some drawings, highlighting the safe distances, materials, suppliers etc. Installed the stove. Sent a doc with narrative & photos, testing etc. BC guy visited, asked me about the CO detector, and signed it off. I do agree though that BCOs are moving to the stage where they don't check or sign off much at all. They just check that someone else has signed it off.
I have seen one supplier that does a 100% panel roof - no tiles at all. Looks great. But … does this not generally fall foul of the general installer guidelines? That is, are you expecting to have ‘tiles around the edges’?
What did your build cost come out at 2024/25!
Alan Ambrose replied to PSC88's topic in Costing & Estimating
You probably need to be specific about what is included - architect? planning? SE? BC? SI? Foundations? Utilities? Finishes? Kitchens & Bathrooms? Drainage? SUDS? PTP? Loxone and other geekery?
