Alan Ambrose
    15
Everything posted by Alan Ambrose
  1. That style of roof is just calling out for blown in cellulose / eps beads / wood fibre no? What is the wall structure out of interest?
  2. +1 for PoE - no batteries to replace, don’t have to grapple with unreliable wifi and only one cable. I have a bunch of Reolink cameras and they’ve been reliable. I saw some criticism of a non-standard onvif feed but I’ve not experienced any problems myself. I don’t use their cloud but do use sdcard storage - which if you’re recording events only rather than continuously, works fine.
  3. Thanks
  4. Thanks all re BC - I'll let you know who I go for. >>> They have also added in that I need to sign up to an app to submit the photos needed for the calculations. @JohnnyB - do you know which app that is? I see 'Timemark' is quite popular.
  5. Speaking as an asthmatic I vote for the good quality 3M products - much better and cheaper than having to get your lungs fixed. BTW I don’t think you need a forced air respirator for plaster if that’s what you were considering. Worth getting some tested for asbestos?
  6. Can I ask - does anybody recommend their local approved building control people? I'm looking for an organisation with a bit of intelligence and flexibility . Preferably one that will accept PHPP calcs for Part O. I contacted Vantage in 2023 and they said they would. LA wouldn't. Similarly design stage SAP people?
  7. Energy network owners have made £3.9bn ‘excess profit’ from higher bills, says report | Energy industry | The Guardian The companies may have made up to £3.9bn more because Ofgem overestimated their borrowing costs as interest rates began to climb, the report calculated. It found that Ofgem allowed regional network companies to recover these costs from household bills even though many were able to secure fixed-rate terms on some of their borrowing which helped them to avoid the impact of rising interest rates.
  8. For PoE the (usually) 24V comes from the router or hub and can often be switched on of off in software. I have the Reolink doorbell which does this fine if you’re not determined to have the Ring. There are probably other makes too that support PoE.
  9. I thought those gaps were more like 5-10mm no? And I think I remember that they’re also specified by the window supplier - I guess they have their build tolerance too. Also smaller for installing into timber frame as presumably that can be made more exact (and adjusted mored easily).
  10. V good analogy.
  11. >>> The system we have at present for electricity pricing is a scandal! It's a bit simplistic but I guess the gas peakers, which are important to the system, wouldn't bother to turn their stuff on unless they were making a reasonable profit. Maybe some longer term pricing arrangements than tomorrow's 1/2 hours would help?
  12. A PoE doorbell, if you can run a cat5 cable to it, will give you power and direct network so you never have to think about it again.
  13. >>> We could have easily added them to the PP A quick non-material amendment?
  14. I guess it can be converted to gas or ASHP fairly easily - at least in theory. I think a lot of people here are assuming that electricity prices stay high - it could be that electricity becomes very cheap in the 3 seasons except winter.
  15. I don’t think it’s much of a practical problem - except for running cost depending on the insulation. Plenty here have ‘willis heaters’ with wet UFH and good insulation - so same principle. Worth visiting while the weather’s cold and seeing whether there’s enough ooomf to get to comfortable temperature. Also maybe the size of their dec/jan elec bill. We have UFH with an elec boiler, one of the smaller things on this page: https://www.heatraesadia.com/products/heating-and-ventilation/electric-flow-boilers Works fine, but a bit expensive to run considering the insulation is not PH standard. Also a bit slow to heat the place from cold.
  16. I’m interested too - planning to start with what the warranty companies will go with - if anything.
  17. This is one possibility - ‘ev ultra cable’: https://www.tlc-direct.co.uk/Manufacturers/DC/SyncEV/index.html I think probably ok for trenches but check. As far as I can see, armoured cat5 plus armoured power would work as well. Probably some separation regs for the various cables in one trench.
  18. +1 for doing this carefully. We had a mouse last winter and on investigation I found there was no mesh at the bottom of the cladding on our barn conversion. So, a hard job down on my knees for a few days and digging part of the earth away from the brick plinth in parts (the house is on sloping ground). Used ss mesh as images above and also ss brillo pad stuff for smaller holes - as it’s an old barn everything is a bit uneven and all over the place.
  19. >>> Lots of my adversities have died ( not guilty my lord ) , so they can never apologise . Hopefully there are not many police constables here on BH. It’s a bit extreme … but somehow understandable.
  20. >>> your new neighbours are spiteful. You have not seen anything yet - want to swap neighbours with me?
  21. I would expect your SE (and maybe your architect) should have sweated all the structural / thermal / barrier detail?
  22. Errr, I think we might need a picture/drawing and an indication where you are in the design/build process. What have you decided / designed / built already and exactly which bits still need to be designed?
  23. @saveasteading Wowee, that's good. So good that it's worth listing 😀.
  24. Yeah why not insulate it. Check out recent edition of Harry’s Garage on PV panels. He fesses up that he has UFH in there! I’m enough of a wuss that I may not go out there in the middle of winter and will put off the job till spring. Wall mounted blow heaters are good for getting the air temp up quick.
  25. >>> Additional air requirements are mandatory for stoves above 5kW in older houses, and for any stoves in newer houses (post-2008) or houses with an air permeability of 5 m3/hm2 or less. Can I ask where that came from? I installed a stove in ~2019, signed off by BC, and this wasn’t a factor as far as I remember. You’ve done a v thorough analysis. In my simplistic mind it just boils down to ‘if passivehouse levels of air tightness (and therefore MVHR) then piped in air, otherwise room air is fine’. Ours is in a not particularly air tight house, doesn’t have external air, and It’s been difficult for me to notice a draft when the thing’s pumping out serious heat (5kW). We also have a Nest CO and a PM detector and the internal air is good.
