Alan Ambrose
Everything posted by Alan Ambrose
So groundwater potentially has more silt in it.
Unvented Expansion Vessel Pre Charge
Alan Ambrose replied to Mattg4321's topic in Boilers & Hot Water Tanks
If it helps: I’ve not seen a small weep in a PG develop into a full leak. Useful to put them on isolating valves IMO to allow for easy swap out out though. -
I think this is a general loophole. In theory ridge height is from GL. Where’s GL? Unless it was specified on the PP drawings (not required by many LAs) it’ s the highest point around the proposed building outline on your topo. But the topo doesn’t cover every point on your plot, only some representative points. Once the topsoil has been stripped and the ground generally mangled by heavy machinery, where was it again?
Ah, groundwater.
Surface water flow attenuation problem.
Alan Ambrose replied to G and J's topic in Rainwater, Guttering & SuDS
>>> A couple of phone calls identified quickly that the requirements for a tank under the drive meant that any tank would be way too low to drain into the sewer without a pump. Well, according to your drawing, your foul pipe is planned to drain that way, and the surface water need less of a fall, so it must be possible. >>> too low to drain into the sewer without a pump As above, not sure I agree. A pump is not ideal, but not impossible either - I'll have at least a couple in my build (and also a suds / rwh tank). >>> far end of the garden being circa 1m lower than the road Be interesting to see (maybe with a hosepipe) what happens to rain when it drains it that direction - it must go somewhere. A percolation test at the back of the plot? -
Sorry, not uksuds.com, actually (believe it or not) 'freeflush' ( https://www.freeflush.co.uk/products/suds-attenuation-sizing-design ). Cost is £120 now. The calc looks something like this (I think they have updated it now). The key output number is the 'tank size' (the 95% is assuming a tank made from typical crates which are 95% void / 5% plastic). The 'tank' can be any shape, of course. The key inputs are your location, the allowed drainage rate (1.9 l/s in my case), the horizontal area of your roof and any 'non-permeable surfacing' e.g. concrete driveway. Actually, for a quick and dirty calc (as we're in a similar location weather-wise) just pro-rate my numbers using your own roof area etc. -
What’s the fall between ground level at the house and invert level at the pipe? Suggest you need about 1 in 100 on the pipe plus about 20cm for rainwater gullies. Maybe get a suds analysis (uksuds.com) as the 1 l/s thing is a suds requirement. That calc uses your roof area and any non-permeable hard standing (so plan to have a permeable driveway), weather data, allowed drainage rate (2 l/s in your case), some climate assumptions and a bunch of stats to figure out the tank size you need. If you have the fall and room (under the drive maybe) you can use a suds tank. If not, above ground storage like butts. It’s possible your ground even in winter maybe take some water too. Storage can be an actual tank, crates, dug hole with shingle in (at 30% volume) etc. I’m using a permeable drive as part of the ‘tank’. Any place to drain at the rear of the plot too? -
Very good, extra brownie points for bank holiday working 😀.
For french drains / perforated drainage pipes in clay - would you geotextile (and have this possibly silt up) or not (and have the drain possibly silt up)? A quandry / puzzle / dilemma?
1400mm stone? That is, 1.4m diameter boulders This is under suspension bridge piers?
Something went right then....
Alan Ambrose replied to Post and beam's topic in General Self Build & DIY Discussion
Nice work:) Mm accuracy in building work is impressive. Care to share a few tips? -
Suggest this is the time to go full beans: Hassle the planners for more info. What did the consultees say? Hassle the architects to bug their contacts and ask them to talk at the meeting. If there’s any doubt, pull in the cnsultants too. Otherwise you might be looking at a planning strike against you and, maybe, 1-2 years delay. I’ve done that and it’s no fun and a complete waste of time and resources.
Also ... + how do people generally seal the ends of ,say, an armoured cable in a 63mm duct?
Also, where there's several power lines that run parallel for a bit - do they need 100mm separation too?
Coupla questions I couldn't find an answer for: + can I run a MDPE water pipe below a 110mm rainwater drainage pipe in the same trench? I plan to put a bunch of power / network stuff above that lot too (in their own ducts). For instance, Essex & Suffolk Water has the diagram below, but doesn't show drainage pipes. + when I cross an open ditch do I need to be way below the bottom of it (UKPN docs suggest 1m) as though it was level ground? Simiarly under a piped culvert?
Ah, to report back - I was recomended a QS as a way to solve the 'am I getting a reasonable price' problem. That's where there were few apparent takers for the job. That worked a treat. The QS thought the bid from the single contractor was fair.
I think you'll struggle to get qualified because of the apprentice / proof of work accomplished element. There is an episode, I think, of Artisan Electrics where one of their clients got qualified - so it's not impossible. As an ex-EE consultant, I would love to find a way too. You might be able to do a deal with a sparky where you do all the dumb and time consuming cable pulling & practical installation work and they do the 'intelligent' work - wiring up, testing etc.
Thurs 8th maybe?
@Gus Potter - as Buildhub royalty, I'm sure we would convene an appropriate celebration if you visited our conrner of the world. A little short of the Pope's funeral, but not by much .
Rated people and about £99 should cover it - but the money is made from fixing the faults.
Feel free to carry on without me - sun’s out, kettle’s hot etc. @lsb - sorry to hear about your mishap, there’s always something,..
Duh, I just discovered that the better 1/2 has booked us to see Dara O'Brien next Thurs, so I will have to miss which is a great pity. I like the idea of visiting someone's site and local though. Mine's a (part) driveway and nothing else much atm .
Does the Kubota red key thing not work? You can get a keypad fitted that needs a PIN entered for £300.
