Alan Ambrose
Everything posted by Alan Ambrose
My experienced helper says we should not work within 1m of the road. This is a single track country road but does have occasional traffic. One planning condition tells us we must construct a driveway apron with concrete edging installed by us next to the road side before our driveway starts: Do we need a road closure? Interestingly Essex & Suffolk Water ignored this 'rule' but UKPN are insisting on it.
OK I just paid my surveyor's invoice with VAT for laying out the dwelling on the plot. Sounds like that should have been zero VAT. Presumably, that was 'closely connected to the construction of the building'. >>> It’s not possible to produce an exhaustive list of services that are closely connected to the construction of the building, and each case not included in (a) and (b) must be looked at on its own merits. OK maybe I should use my own judgement then.
>>> The line is quite simple, a professional service provides advice, expertise, design, and reports/documentation. A contractor makes /modifies stuff. So an electrician or drainage guy doing a design for you is 'professional'. The same guy installing stuff is not? p.s. I'm not being argumentative, just trying to get my VAT right.
I see that Artisan Electrics are installing Sigeenergy equipmwnt currently - which is a good sign as Artisan generally install high-end. Their content is a bit light as they don’t fully explain why. Am I right in thinking that with the rate of innovation and the inevitable industry consolidation that choosing a brand based on, say, their current app features is a bit fruitless? Has anyone done the homework or have the experience to be able to differentiate well between the brands?
You might have to do a bit of leg work. Either existing planning applications and take the data off the block plans. Or, maybe better, a custom mapping extract of the area you want and do the same. Estimate floor area by counting floors and multiplying. I did something similar for my D&A statement with ridge height, roof pitch, wall & roof materials, road/sun orientation. It was not obvious that anyone ever looked at it as one ever commented - so you may or may not want to bother. There are some apps that let you read dimensions from pdfs. Similarly on Google maps etc. For comparison, there's also an estimate of floor area on EPC docs, which are on the .gov site. It doesn't actually take long, depending on how many dwellings you want to cover, of course.
Can I start a thread on VAT 'edge cases' i.e. the stuff which isn't so obvious. I've a couple now: Layout of plot outline etc by surveyor with total station - is this professional services (VAT) or just services (no VAT). Is there a hard line between one and the other? I've a question re site set-up. I'm buying electrical stuff for the kiosks etc (VAT reclaimable as 'incorporated into the building') as well as bits for the site hut (not 'incorporated into the building'). I didn't think about it at the time (electrical is electrical after all) - but does this mean that people are going through their invoices re VAT reclaim line-by-line? Jeez, VAT 708 is a dogs dinner.
Backing board for CU - ply allowed?
Alan Ambrose replied to jfb's topic in Consumer Units, RCDs, MCBOs
Interesting, who knew? MDF with some 'retardant'? Cement board would be a thing, but the GRP kiosks I bought all came with thick-ish ply. -
I had two in at once, can’t quite remember why now. On the positive side, I think this naturally gave the LPA, parish council etc a ‘choice’ - which seemed to me to be positive i.e. they could have been against both but they seemed to naturally fall into ‘choice’ state-of-mind. It might depend how much time you’re prepared to wait - I think next time I might put in a bunch of applications in parallel, some going to appeal etc, and see what shakes loose. Some here on Buildhub, not subject to CIL, have started on the smaller approved application while they took the larger one to appeal, and then switched when their appeal came through. I won’t bother with a pre-app next time. Pre-apps seem to be given to the juniors at my LPA and don’t have any formal decision value anyway. We eventually got exactly what we specified in our pre-app even though the junior gave us a few reasons in our pre-app why ‘it would be refused’. I also think it’s a mistake assuming there’s joined-up thinking at any LPA - my LPA seems particularly capricious and applications are subject to the whim of the officer involved at any point in time.
Connecting drains at multiple levels?
Alan Ambrose replied to Alan Ambrose's topic in Rainwater, Guttering & SuDS
I suspect so. -
I thought the gas peakers were there precisely because they could be started and stopped quickly.
Thanks for the example, it seems that once you get a tiny bit out of the ordinary and the dozen or so standard parts, it’s fabricate your own system time? So, where I’ve got my big old 450mm diameter IC, and ignoring the silt requirement for the minute, I could just go into the side of it at various levels? -
Ah, I hadn't thought of that, thanks. Key word is 'drop chamber'? Sounds a bit tricky. I also came across this (below). The whole area seems sufficently complicated, that I think I might need someone (rather than me) who actually knows what they're doing . -
There is a school of thought here on ‘t ‘ub that structural insurance policies will never pay out and will want to sue everyone in sight with PI for their contribution. I don’t think we have enough data to tell whether this is true, but if you look at the ‘insurance’ as just giving your prospective buyers’ mortgage company (between years 3 and 10 years out) a warm feeling, then you’ll probably be fine.
Hi, I’ve a 300mm culvert pipe at about -1.5m invert level that I want to drain a bunch of stuff too. I put in a big inspection chamber which has 160mm connectors at 90 degrees. I’ve new 100mm perf pipe land drains to put in, which I was going to put about 250mm down; rainwater drainage from gutters about the same level; drains at the bottom of the raft foundation about 900m down; PTP outflow maybe at 400mm (EA has approved this). The culvert is a bit silty and I was going to put in a silt trap to avoid exacerbating the situation. 2 questions: (1) how do I connect in at multiple levels? And (2), should the PTP outflow miss the silt trap?
Yeah, it wouldn’t be good to be entombed in your own foundations.
Replacement dwelling into existing (combined) sewer connection
Alan Ambrose replied to Woodview's topic in Waste & Sewerage
Part of a farm, but doesn’t have any ditches to drain to? -
>>> in perpetuity OK that’s all future owners and even when we’re all using nuclear fusion-powered roller skates to get around. How sensible. It would be nice if they spent even 5 minutes thinking about these conditions.
Advice needed on French drain
Alan Ambrose replied to Omnibuswoman's topic in Landscaping, Decking & Patios
FWIW - there’s a membrane under our gravel grids and we still get weeds. Weeds are very tenacious.
